Question about Toys
Is there 1 or 2 rotor strutrods on mini Helicopters
Top rotor will not spin
I have the same problem. I have two of these helicopters and just recently brought them out of the closet. On one of them, the bottom rotor spins but the top does not. On the other, it Ian the other way around. It seems like the shaft is not catching the rotors properly, anyone have ideas?
Dec 25, 2013 | Brookstone uControl Cloud Force RC...
What is the tail rotor in helicopters?
The tail rotor is a piece at the back of the helicopter that keeps the helicopter from spinning by blowing air sideways. It also helps the helicopter to turn.
Aug 29, 2012 | Champion Sport & Outdoor - Others
Is it normal for helicopters to recieve mid air refuelling
Actually No. Only certain helicopters are equipped for mid air refueling almost all are military craft.
This is usually done through use of an extra long probe that reaches out far enough that it clears the rotor blades
What, may I ask, does this have to do with watches?
Feb 27, 2011 | Watches
One rotor spins faster than other, so chopter flies only forward
We are a family that bought one of your helicopters. We immediately had a problem, the top rotor stopped spinning after a crash. We found out that when the helicopter crashed I wasn't paying attention(I am 10 years old)and I was still pushing the throttle while it was on the top rotor. Big mistake,when I tried again it Didn't lift off the ground. We then put crazy glue in between the top rotor and the shaft and tried it again. It worked! Both rotors spun! Good luck!
-Bryce
Dec 25, 2010 | SYMA Toys industrial Syma S026 Chinook Rc...
Why won't my havoc heli's main rotor spin
i would try to look for hair stuck in the main rotor
Mar 09, 2010 | Air Hogs Havoc Heli Helicopters
Hi, the main rotor of my havoc helicopter is spinning in an unbalanced way and causing a high level of vibration making flight impossible
Look on the underside of the rotor. You may be missing one of the small metal weights that balance the rotors.
Jan 08, 2010 | Air Hogs Havoc Heli Helicopters
Helicopter is unbalanced
Hi. This is called "talk" its when the helicopter starts spinning instead of the blades, remote control helicopters and real ones.To stop this from happening you need to make sure the tail Rotor is going correctly OR probely the best thing to do would be take it back to the shop and get a hole new one.
Aug 15, 2009 | Sky I Blade Mini IR Helicopter W/ Remote...
Har is stuck in my back rotor
pull the blade offf then slide the hair off no biggie
Jul 07, 2009 | Air Hogs Havoc Heli Helicopters
Toys Logo
308 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
