Which way do the Blue and the Grey wires go on Hitachi SF-6500PX drain pump? I am looking from behind pump
There was heaps of yellow corrosion, which has been cleaned off. I can't remember which one goes where.
  • 3 Answers
It doesn't matter what wire goes on which terminal as the only way to reverse the direction of the pump is to turn the stator around.
Posted on Dec 03, 2014
    New Friend:
The Blue is neutral. The terminal on the top left has an "N" on it, The Grey is Active, the terminal on the top right has an "A" on it.
Posted on Mar 29, 2015
Hitachi sf 6500px washing machine
If this is a spelling error and your not getting HOT water, I suggest you check the wiring or wire plug connection to the 'water inlet valve' assembly. 1st-unplug the AC power. 2nd-turn off both water valves.3rd-prepare for spilled water on the floor.4th-carefully use a wide(app 1 to 2 inch)flat chisel(BIG flat blade screw driver)and pry the top assembly up.5th-it should open like a large tool box. Look down inside the back to see where the valve assembly is mounted. Now option #2 is turn the machine on its side to see if you can reach the valve assembly from the bottom with out having to open the top. Good luck on the job.
Mar 29, 2014 | Washing Machines
Wiring a d2 eberspacher diesel night heater up
how much it coast black & decker Heater product model no . or07d
thank you
Dec 22, 2013 | Heating & Cooling
Hitachi sf-6500px error
Possible error on the program due to a memory issue. After resetting, if the machine has the same fault with all the selected programs, then it is possible that the motherboard is faulty. Please check the INLET flow to be good and the drain pump to be clear.
Jun 25, 2013 | Washing Machines
Manual for sf-6500px
Google the company. Sometimes you can go to customer support and download it.
Feb 19, 2013 | Garment Steamers & Presses
Location of feul pump relay
The fuel pump relay is located on the frontof the engine compartmant on the passenger side of the radiator support. they are right behind the right side headlight. they are the oval looking style relay with a white diagram printed on top. The fuel pump relay will be he one with a black,green,grey and red or orange wires going to it. if you suspect it is bad check the wiring in that vicinity first for a break in the insulation usually accompanied by some green corrosion. The grey wire is the wire that goes to the fuel pump. The green wire recieves a ground signal from the computer for 3-5 seconds when the key is turned to the on position and is ground all the time that the car is running. the fuel pump fuse is also located near the relays. you have to remove the fuse from the holder to check it. Good luck! Scott
Oct 03, 2011 | 1993 Oldsmobile Cutlass Ciera
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
Apr 14, 2011 | 2002 Mitsubishi Lancer
Hitachi SF-P95FJ WASHING MACHINE ERROR CODE F9
if you have Hitachi nw-d8ax f1 error check water sensor f3 error check rinse filter f9 error do not know where the error but I did repaired, remove back panel and right hand side inside polithine cover find blue connector its with 2 wires remove it and switch machine it will give f3 error with sound reconnect the socket its started working
mail me if yours working I will give you more tips nava@netintec.com cheers
Oct 29, 2010 | Washing Machines
2001 vw golf 1.4 wiring details for towbar plug/socket.(colour coding)?
Left indicator - Yellow to Black/White
Right Indicator - Green to Black/Green
Left Tail - Black to Grey/Black
Right Tail - Brown to Grey/Red
Fog - Blue to Grey/White
Brake - Red to Black/Red
Earth - White to Brown or Body earth above/behind Left hand Light
Oct 02, 2009 | 2001 Volkswagen Golf
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
