If your system issues are not properly working, you may have to purchase another system or system motor. Make sure you disc you're using has no scratches or finger prints. Good Luck.
sounds like your laser is failing. You can find tutorials on how to adjust, clean or replace your laser. Do a google search for " ps2 disc read error " it will give you a choice of plenty of tutorials to follow. Good luck
What you need to do is take you ps2 apart and clean it out and clean the laser lens that reads the cd's...you should be able to google ps2 disc read errors and get videos to help you through it.
Disc Read Error is mainly due to worn-out,dirty lens and it can also appear because of the disc that you have inserted in your PS2...... Try following to get rid of DISC READ ERROR:
Clean your PS2 lens:
Watch this video first
This will help you in cleaning the lens.You can also clean your PS2 lens by some lens cleaning DISC.Make sure not to touch lens with your hand.
If Wii gives Disc Read Error, first step you need to check is to try another
disc or clean the exisitng disc. This will confirm that problem is with either
Wii or Disc. If the console itself is giving disc read error then it needs to be
repaired. You may check out DIY Wii Fix Guide, that
will show step by step information to fix the problem yourself. It also gives
information on fixing many Wii Related Problems, so its a kind of Wii Problems
Reference Fix Guide...
Made a video showing how I fixed this problem on my Wii. I show how to troubleshoot, take it apart, clean the laser and replace the DVD ROM if needed. Cleaning the laser didn't fix my problem but most of the time it will.
Now this is strange PS2 hangs up..............!!!wHich pS2 u have.........???slim or the old fat one.........???As far as disc read errors are there, u should clean ur lens by using some lens cleaner CD or do it manually[for fat one] urself it not a big deal........becarefull while opening the cover....clean the dust on lens with the tissue or any other light material......the problem can also b with ur disc change that also...........
