Question about Watches
What battery fits g85863g watch - Watches
  • Jezneca Dec 03, 2014
    a Guess Waterpro?
    Problem Solver:
  • 17 Answers
A 365
Posted on Dec 03, 2014
What size of battery fits guess steel
Just take it to a local jeweller and they will change the battery whilst you wait for $6 to $8. There are so many batteries and usually you can't by just a single one in the small sizes that watches use.
You often need a special tool to get the back off, and a jeweller's eyeglass to see the tiny screw and the right screwdriver to fit it.
May 20, 2016 | Guess Waterpro Bracelet Watch
I need to get the back off my new ice watch to replace battery but I can't? Anyone know how please?
Waterproof or water resistant watches usually need a wrench to unscrew the back. I use a pair of 90 degree circlip pliers. A jeweller would remove the strap and fit the watch into a holder before using the wrench.
Few jewellers would guarantee the water resistance of a watch after fitting a new battery. If it is required a watch be returned to its original specification it must be returned to the manufacturer or an agent for battery fitting and pressure testing.
Some watches have a back that is pressed into place. Fairly easy to prise off but very difficult to replace without the tools. This type does not have the grooves a wrench fits into.
Apr 10, 2016 | Ice Watch Watches
Need new battery, last owner took original battery out.
Take Watch to Watch shop for them to fit new battery .. As you don't have original battery in your watch, you would not what type to buy if you wanted to fit it yourself.
Mar 13, 2015 | Fossil Watches
Mens Armani Watch AR-0659 What battery fits this watch
I don't know the battery type for your watch but I would suggest you get the battery change done professionally. They can replace the seal and guarantee its continued water resistance on your particular model. Sadly I learnt the hard way and after the DIY battery change on my (now deceased) Armani watch it filled with water on my next visit to the swimming pool!
Dec 24, 2014 | Watches
What battery fits a Marc Ecko E22569G1 watch?
http://www.bigapplewatch.com/battery.asp?prod=battery&watchnumber=MARC%20ECKO%20E22569G1
Dec 05, 2014 | Marc Ecko Watches
WHAT BATTERY SHOULD I USE FOR MY GUESS WATCH
the battery 365,but it s hard and dangerous to open these and you need a press to close it. inside there is a clip and if it is broken you can break the movement.it needs to be resealed too so it is water resistant. i can do for 10.00 see site.www.watchbatteryrepair.com
Mar 22, 2012 | Guess Waterpro Dial Bracelet #G85863G...
How long should a bulova watch work ---my husband bought me a bulova watch 7 years ago ----it stopped working & I thought I just needed to replace the battery ----so I did but less than 3wks later the...
I would expect the battery to last more like 3 years than three weeks.
Did you replace the battery yourself? If so, are you sure that it's the correct one correctly fitted? Did you use a quality make of battery?
I've known people to use metal tweezers to fit batteries - the risk of shorting the battery is very high with the result that battery life is seriously reduced.
Look at it this way - the watch cost you over 300 bucks, so it's a decent quality watch. Take it to a professional to have a battery fitted - it's not worth the risk doing it yourself if you're not completely sure what you are doing, and if the battery they fit fails then you can just take it back to them to sort out. Having a battery fitted for you should not cost a lot of money - but if you have somehow damaged the watch by trying to do it yourself then it will have been a very expensive way to save a little money....
Oct 14, 2017 | Bulova Diamond Watches
How do you change the battery in a black dice flow watch
You need to open watch case back using appropriate tools. There are two batteries in this model - one for each watch movement. Unscrew/un-clip battery contact. Memorize polarity (+ and -). Take the battery to your nearest watch battery shop or watch repair shop and buy the same one. Fit new battery back in watch (remember polarity!). Fit back contact as it was. Close the watch case back. Set the time. Done.
Feb 25, 2011 | Black Dice Industries BD04101 Flow From...
I need to replace battery
All you need is to open watch case back, remove the rubber seal and unclip the contact. Take the battery out (memorize polarity: + and -) and buy the same one. Fit new battery in the right way back in watch, fit the contact, place back rubber seal and refit watch case back. Reset the watch. Done.
Feb 25, 2011 | Polar M32 Heart Rate Monitor Watch
New battery needed and fitted to a Polar heart rate monitor
This is really easy to do yourself. Get a CR1632 battery, unscrew the four screws on the back (dont tip the watch as there is a small spring in the watch), unclip the metal band holding in the old battery noting the way 'round the battery is in (minus side up), pop in new battery and push clip back down, when re-fitting the back make sure the spring mentioned earlier lines up with the white sticker with a hole in it on the inside of the watch back, screw down the back. After you have re done all your settings you may need to re-aquaint the watch with the strap, to do this put on the watch and strap, set the heart monitoring going, bring the watch up close to the 'Polar' logo on the chest strap until the time is displayed, should now be all set up.
Andy
Oct 28, 2009 | Polar F4 Heart Rate Monitor Watch
Watches Logo
20 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
