Question about Adventure Power Honda NPS50, S Ruckus Battery 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010
Will the CDI from a Chinese Roketa GY6 250 fit or change with my Ruckus 50cc, what about the variator does it interchange, interior gears, carb,?? anything Please No Guessing
My o3 Ruckus only runs with the carb drain open,,, why is that??? please help
Hi, Bryce and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
8. Damaged petcock diaphragm allowing fuel to flow through the vacuum line into the combustion chamber.
9. Contaminated fuel tank.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Carb overflow is pouring out gas
Carburetor Carb Leaking Gas How to Fix Repair it Motorcycle Honda DIY...
Honda 2003 NPS50 Ruckus Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda NPS50 RUCKUS 2009 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jul 03, 2017 | 2007 Honda Ruckus
150cc stator
Chinese Junk I am sorry to say. All made as cheaply as possible.
ROKETA MC-19 STATOR
www.roketapartsdept.com/products/ROKETA_MC_19_STATOR-16828-579.html
  1. Cached
Part# MC-19-150-06-01-09. Roketa MC-19-150 Replacement part. May Fit Other Makes and Models.
MC-19 ENGINE PARTS: Roketa Parts Department
www.roketapartsdept.com/catalog/MC_19_ENGINE_PARTS-579-1.html
  1. Cached
ROKETA MC-19 BREATHER HOSE CONNECT. Product ID ... ROKETA MC-19 ENGINE OUTPUT SHAFT. Product ID ... ROKETA MC-19 STATOR. Product ID ...
Roketa 150: Parts & Accessories ' eBay
www.ebay.com/bhp/roketa-150
  1. Cached
  2. Similar
Find great deals on eBay for Roketa 150 in Scooter Parts. ... MAGNETO STATOR 8 COIL POLE GY6 125cc 150cc SCOOTER ATV GO KART ROKETA TAOTAO ...
Roketa Scooter Parts - All Street Brands - Monster Scooter Parts
www.monsterscooterparts.com/scooterparts/street-brands/roketa
  1. Cached
Roketa MC-16T-150 Scooter Parts. Roketa MC-17-50 (Sicily 50) Scooter Parts. Roketa MC-17-150 (Sicily 150) Scooter Parts. Roketa MC-19-150 Scooter Parts.
Roketa MC-07-150 (Bahama 150) Scooter Parts - Monster Scooter Parts
www.monsterscooterparts.com/scooterparts/street-brands/roketa/roketamc07150
  1. Cached
Items 1 - 6 of 6 - 8 Coil Magneto Stator with 3+2 Wiring Connector for 125cc GY6 152QMI & 150cc GY6 ... 19 99. G07-1459. Medium Weatherproof Cover for Roketa Scooters ... Quality replacement parts for the Roketa MC-07-150 scooter.
Roketa Scooter Parts - Chinese Parts
www.motopartsmax.com > Roketa Parts
  1. Cached
  2. Similar
Roketa Scooter Parts By Type ... Air Filters & Intake (19) · Intake Pipes & Water Pipes · Air Filters · more · Cables (16) ... Roketa MC-19-150. Parts List · MC-20-150. Missing: stators
And TAO TAO
tao tao powermax Google Search
Dec 29, 2016 | Motorcycles
Starts and runs but will only go 25 top end and 10 going up a hill. I cleaned carb, and changed plug. Filter good. Any help about how what to try next?
Dennis, Write up found in scooter guide.net link below.This scooter was restricted to 25mph via a series of restrictions to the variator, ECU, intake and camshaft. 2009 was the last model year for this CHF50 in Canada and the USA, although this scooter was available for a few years after this due to excess inventory from the 2009 crash of the scooter market.
You can have it modified at a shop probably $$.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.motorscooterguide.net/Honda/Metropolitan/Metropolitan.html
honda metropolitan top speed test run
Honda Metropolitan Jazz Ruckus Resource page
The Fastest Upgrades for Metropolitan Scooter eHow
Apr 25, 2016 | Motorcycles
Oil for lexmoto gladiator
Hi, Anonymous for more information about your question and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Oil for Lexmoto Gladiator Gladiator 125 SB125T 23B 2007 and after Which...
How to change your oil on Chinese Moped
Changing the Gear Oil on Chinese 50cc Scooter
Haynes Chinese Scooter Service Repair Manual 4768 for Lexmoto Gladiator 125
Mar 27, 2016 | Motorcycles
Need repair or parts manual for a Na Za scooter ithink its a 50cc? i think its made in china?
Look on the engine most to all china made scooter's have these engine's (136qmb)(gy6) and other variants of these motor's for wire's they follow the frame once you take a good look where every thing goes I recommend finding the CDI it's a little box with about 6-8 wire's plugged into it this is the brain of you're scooter if you want part's just search (50cc chinese scooter parts) and most if not all the part's will fit you're motor.
Oct 23, 2017 | Sport & Outdoor - Others
2012 Honda Ruckus with 2000 miles - sometimes at start-up the transmission seems to slip and I have to rev the engine to get it moving.
definitely time for a new belt but you should consider getting a Polini Variator voted best on/by many Ruckus riders and it sounds like your Variator has some bad rollers that will make it go bad anway.
Bonus is you will get like 2-3 more miles a hr. with the new Variator
Sep 24, 2013 | 2012 Honda Ruckus Base
Can i deristrict my 2012 honda NSC vision 50cc
It's not so much a derestriction but is about the only thing you can do to make this ped faster. Using a malossi variator kit. http://www.psntuning.co.uk/scooter_parts.php?prt_id=2411
Apr 05, 2012 | Honda Motorcycles
Ok i have a kingring 4t 50cc scooter and its only
does it still wind out normal? if it has a centrifugal clutch, it could be slipping. check springs in clutch.
Mar 31, 2010 | 2005 Benelli Velvet 125
Can i swap my 50cc engine for a 125 or 180 easy enuff to fit in my runner
You can fit a 125 or 180 but you will need grind the engine mounts down - you'll also need to change your wiring loom along with the cdi and ignition unit - your better off putting a big bore kit on your 50 and change the variator and rollers etc - if it's speed your looking for i'd go with the big bore option - if set up correctly your 50 will kick the *** off and 125 - 180
Mar 30, 2010 | 2005 Gilera Runner VX 125
Adventure Power Honda NPS50, S Ruckus Battery 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010 Logo
44 people viewed this question
Top Adventure Power Electronics - Others Experts
Are you an Adventure Power Electronics - Other Expert? Answer questions, earn points and help others
