Wat is the PCB....? - Office Equipment & Supplies
    New Friend:
  • 125 Answers
PCB stands for Printed Circuit Board, it holds the electrical components and also forms connections between components.
Posted on Dec 03, 2014
Testimonial: "wat is the replace the DC controller PCB....?"
Wat is error 000100 0001 on canon ir 2230
E001-0001 The temperature of the fixing assembly is abnormally high.
The hardware circuit detects overheating of the main or sub thermistor for 200 msec.
To fix it: Reset the condition in service mode: COPIER>FUNCTION>CLEAR> ERR. If this not help you need replace the DC controller PCB.
May 05, 2016 | Canon Office Equipment & Supplies
Fault Code F8
f8 coming up wat solution I changed pcb and fan
Oct 20, 2013 | Heating & Cooling
Hot water does not always come on......getting berror 24
there is a malfunction of operational switch
you will have to press the max button on PCB to reset
and Press min button on PCB to reset
if that does not work you will have to get the PCB replace
Aug 25, 2010 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Canon error code E000000-0000
Some of possiblle causes:
The heater has an open circuit.
The thermal fuse has blown.
The High-voltage PCB has a fault.
The DCNT PCB has a fault.
FIRST:
under service mode * 2 8 * :
COPIER-FUNCTION-CLEAR-ERR-OK
Turn off and on.
if that doesnt help replace fixing film assy.
Jun 28, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Wat the to solve E0000-350-1
Error 351 is main PCB problem, you may have to replace main pwb
Oct 06, 2009 | Canon imageRUNNER 2200
Toshiba dp6750 paper trays not working
check connectors on pcb make sure everything is plugged in
Apr 01, 2009 | Toshiba Office Equipment & Supplies
Keep washing never stop.
either the heater is faulty or pcb corrupt.. have you any flashing lights as these are fault codes.
Feb 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
Insignia 32 in LCD TV: no signal
No signal.does it means in all modes...tuner, A/V and all other sources. If it does, you may have a faulty main pcb board. Call a technician.
good luck.
Jan 25, 2008 | Insignia IS-LCDTV32 32 in. Television
2 red lights after x clamp replacement
It means basically that the xbox is starting tio overheat fast. what sometimes happens is those x-clamps have to be tightened in a sequence and tight as possible but not too tight to crack the board or cut the small PCB traces. Open up the console again and just have a look underneeh the motherboard make sure there are no torn green pcb traces ( put simply green lines that connect to a silver blob of solder ) and make sure the screws are tight enough.
Dec 11, 2007 | Microsoft Xbox 360 Console
k24674
jasbo
jasbo
