Question about NEC Multisync Lcd-1760vm Monitor With Adjustable Stand/swivel Base
Power supply diagram of NEC lcd monitor model lcd1760v (l172en)with components numbers
The trouble is back light remains one second after power on.I want to verify the part no d810 and also want to get know is it correct if I use fmx22s for d810.
PaulRepair
  • 66 Answers
SOURCE: NEC MultiSync lcd 2010 monitor blank screen
This is the common bad capacitor problem. The caps have died inside, and they can be replaced. If you have basic electronics skills, you can go in, order replacement caps, and unsolder and resolder. If you can't do it yourself, you can take it into a shop.
Here is a link to the Cap plague that explains what happens in detail. But I repair these all the time with that symptom.
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 02, 2009
  • 644 Answers
SOURCE: how do you restart a nec lcd monitor, had power
The power surge probably blew the fuse inside the tv, first check the fuse inside the mains plug, if that is good then you will have to take the back cover off the tv, you are looking for the power board follow the mains cable into the tv and you will find it. Look for a fuse on the board, pop it out of the fuse holder, if you have or can get hold of a multimetre check the fuse for continuity if it hasnt you will have get hold off another fuse, you can normally get them from your local electrical repair shop, they dont cost much and the liklyhood is they will probably give you one free of charge.
Posted on Feb 04, 2010
budmrtn
  • 11361 Answers
SOURCE: NEC MultiSync LCD1765 won't power on
Look for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps (after about 2 years): http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 15, 2010
  • 8 Answers
SOURCE: nec multisync 2080 monitor
I got a similar problem with my NEC 2080UXi. The power led indicator is lit as soon as I plug in power. No back light ever comes on. Capacitors appear to be fine. I did notice that a resistor did burn up and appears to be a small wattage from size of the leads. Does anyone know what resistance R915 is? It's located under the middle heat sink on the power supply board (the brown coloured board).
This may be the solution.
Posted on Apr 08, 2010
  • 395 Answers
SOURCE: My NEC 1765 monitor seems
Robb,
The 12V ac adapter could be the bad one. I have seen it was bad before. I don't whether you have a second adapter to test. That is what I am guessing for now, it is adapter because I have seen it happened to my clients before.
Thanks
Posted on Jul 20, 2011
I Need a power supply for a NEC LCD 65 Series Monitor. The power supply converts 120-240 AC to 12VDC. I don't have a part number as it is not listed in the Owners Manual
Do you have the full model number?
Otherwise try here:
http://12vadapters.com/
You can get higher current rating but not lower than what it is printed on the back of the monitor but not higher voltage.
Oct 10, 2011 | Computers & Internet
I have 2 of these monitors with the same problem. On power up the green led will light & remain on but the screen remains black. On one of the monitors the screen will light up for a few seconds then...
The inverter that turns on the back light may be bad - it's suppose to create the high voltage pulses to fire the CCFL back light lamps. Apparently the back light turns on after a few seconds however, it cannot stay on because the inverter might be bad. If you connect a known external CCFL lamp to the to the inverter output you can isolate the inverter.
Dec 26, 2010 | NEC MultiSync LCD2010 20.1" LCD Monitor
The monitor (Gateway FPD1975W) turns itself off after a couple of seconds. I have tried rebooting a number of times - same problem. When I turn the monitor off and then on again it works for a second or...
This sounds like the monitors power supply is failing. (if the monitor is truly right off) Use a flashlight to verify the back-light is not just the culprit. If you can see faint image in the monitor with the flashlight, then this would point tothe LCD inverter is failing. Its most likely the power supply board within the monitor itself. Typically It takes 3 35v 470uf capacitors to fix and a little patience to get apart. Do a bit of googling on "replacing the caps in a FPD1975W" and youll see what i mean. Cheers.
Sep 01, 2010 | Gateway FPD1975W 19" LCD Monitor
Feb 15, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
I have a nec LCD2070nx Power light is on
Hi:
Your monitor has a problem on its inverter board. It is an electronic component failure, and often it cost's more to fix it than to buy a new LCD monitor .
Nov 23, 2009 | NEC AccuSync LCD71VM 17" LCD Monitor
Apr 02, 2009 | NEC MultiSync LCD2010 20.1" LCD Monitor
Dell LCD E207WFP (Switches on Briefly then goes Off)
two case trouble reason and need to do:
1) back light driver (inverter) works not stable and DC power protect. it near some component damage, should repair inverter by egineer.
2) back light (lamp) over life cycle so protect by the inverter, should change new lamp (regular parts)
3) DC power supply not stable or component over life( wave filter capacitor), should be replaced
Aug 03, 2008 | Dell E207WFP LCD Monitor
Nec lcd1560v+
http://www.necus.com/support/ go down to where it shows drivers and software, choose NEC MultiSync LCD ...
Download the NEC LCD monitor installer and run it, NEC shows your monitor supported by this software. :)
Feb 11, 2008 | Gateway FPD2275W LCD Monitor
Nec multisync 2080 monitor
You don't really need to replace the power supply, you can repair it by replacing the bad capacitors. I've done it to 2 Nec monitors and it works. However I do not believe its you power supply because you are getting the power on light.
Oct 16, 2007 | NEC MultiSync LCD2000 Monitor
My monitor not stay on
Very common for this model that top backlight globe goes faulty. Can be also inverter PCB fault. If you have couple spare lights connect them to your inverter instead of panel lights and see if fault remains.
Mar 28, 2006 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
NEC Multisync Lcd-1760vm Monitor With Adjustable Stand/swivel Base Logo
66 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
