Question about Dryers
My dryer starts yet wont do anything else than a light flashes and it looks like a tshirt checked filter
  • ElectroWill Dec 03, 2014
    Hi Danyel Escobar, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What is the make and model of your drier? Have you check the user manual, these kinds of things are usually listed in the manual.
  • Dryers Master
  • 5,323 Answers
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Posted on Apr 26, 2015
5 Suggested Answers
SOURCE: bosch wtl 5400 elect. condensation dryer
I have a WTL 5400 electric condensation dryer (bosch). All of a sudden one day, it would not turn on. The lights are on, the filters are clean. Please Advise.
Harriet Scannon
Posted on May 01, 2008
IrishDruid
  • 2712 Answers
Hello joeychacha,
Since your dryer is not working at all, I would check the following components:
1. Thermal Fuse (located on the air baffle) - Resistance reading of 0 ohms. NOTE: If the thermal fuse is blown, the drum light will not come on.
2. Broken Drum Belt - If dryer is equipped with a broken belt relay, this will shut the dryer down.
3. Broken Door Switch - If the door switch is broken, this will shut down the entire dryer as no power is applied to the start switch with the door switch open.
4. Bad Start Switch - If the start switch does not toggle close or stay closed when released, the dryer will not start.
5. Bad Timer - If the timer does not function the dryer will not start.
6. Bad Drive Motor - No Motor, drum does not rotate, heating circuits may or may not function. DOUBLE CHECK the CONNECTOR PLUG on the Drive Motor. I have found situations where this plug came loose for whatever reason and caused the dryer to either shut off completely or work intermittently.
7. Bad A/C Receptacle and/or Connector Plug - If you aren't getting the proper voltage to the dryer, it will not run.
Also check the ventilation ducting to ensure that it is not kinked or clogged. Poor air flow is the number one cause of dryer failures. Not to mention it can cause fires due to lint backing up inside the dryer. If you've never cleaned the ducting, or your dryer is pushed all the way up against the wall causing the ducting to become kinked, you will have air flow problems. Periodic cleaning will go a long way towards preventing future clogs. Dryer vent rule of thumb: The SHORTER and STRAIGHTER the vent line, the BETTER. Everywhere you have a bend or kink is an area where you will create potential collection points for lint.
If your dryer has the lint screen on top of the unit, you will need to remove the back panel to get to the heating circuits. If your dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by pushing in on the release tabs with a putty knife. They are located along the front seam about two inches in from each side. CAUTION: It is recommended that you unplug the dryer BEFORE servicing the inside or cleaning. There are still dangerous voltages present even with the machine turned off.
Hope that helps!
If you find that the solution/answer I provided led you to, or resulted in a fix, please take a moment to close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
PSITECHNICAL
  • 71 Answers
SOURCE: check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
Posted on Dec 23, 2009
  • 311 Answers
SOURCE: dryer wont heat and check filter light is on but
This could be caused by a venting restriction. These dryers have sensors built in to check airflow temp differences. Take the vent off the dryer and run it and see if it heats. If it does then you know the problem is with your venting. You will need to either clear the vent or replace it.
Hope this helps _MJ_
Posted on Feb 01, 2010
The clean filter light was flashing but it stopped after I cleaned the vent but still won't heat, Is there another vent/filter in this dryer?
the blinking filter light is just a reminder, not connected to anything. goes out when you start cycle. however, if the dryer overheated then it may have blown the thermistor fuse. check out appliancepartspros.com or repairclinic.com for how to videos and parts.
May 23, 2016 | LG DLG5988 Gas Dryer
LG dryer DLE2140 error CL clean filter which I have done and even used vaccum dryer still wont come on
the clean filter just blinks at start of a cycle to remind you to clean it. there is no lint filter sensor or anything like that. it goes out after you program your cycle and hit start. if dryer is not coming on, there is another issue. any fault/error codes?
Mar 10, 2015 | LG Dryers
My samsung whirlpool dryer turns on and beeps like it wants to start, than nothing and a little light with no code it actually looks like a little tshirt starts blinking in red not sure what that means
Hello Danyel;
My name is Peter. I am a retired field service appliance technician.
You did not provide a model number. The model number is usually on a label see after you open the dryer door.
I would first start with the thermal fuse. It may be blown. But I do not know if you have one since I do not have a model number.
If you do not have a meter to check the thermal fuse you can use a 12 gauge wire and by-pass the fuse to see if the dryer will start. Remember to unplug the dryer first, and that the fuse is a safety device and must be replaced. Generally the following fuse is in the back of the dryer:
Dec 02, 2014 | Dryers
Light flashing says check filter. Dryer wont heat up? What filter and where is it located
The filter screen check light is just a reminder indicator. It will always come on whenever you turn on the power. As for the heat, you didn't state whether it's electric or gas.
Jul 15, 2011 | LG Dryers
Turned on dryer & tried to start but it gave a load thud noise & wouldn't go. Stop it then re-started a light came on stating clean filter. Clean filter & look inside that area to see if...
there is a sensor located beneath the lint filter, more the likely the dryer sheet residue is on it, gently brush it off, it has two screws. As far as the loud thud noise is/may be a problem with the drum/rollers/glides/belt/idler arm/motor Here is a website that will assist you, once the filter light goes off and the drum will not turn.Good Luck Tim
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 05, 2011 | LG DLG5988 Gas Dryer
Dryer wont turn on, start light and lint filter light flashing
take off the back panel and try to reset the fuses in the cabinet also make sure to check the switch near the belt tension pully make sure that is is pushed to the right so it is reset
Aug 01, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Brand new condenser vhc 680f starts cycle and then stops after ten seconds and lights flash. checked filter
Hi my dryer was the same. Apparently condenser dyers wont work under 5c, with all this mega cold weather my utility room was freezing brr and the dryer stoped after 10-15 sec and started flashing checked everything but still wouldn;t work. Found a swedish website (after spending DAYS looking for an answer) that said it mght be to cold so I brought the dryer into my house and wa hey its working again. Hope this helps xxx
Oct 18, 2009 | Mattel UB FUNKEYS Dream State Dyer and...
Dryer won't power up, says check filter
Check the door switch first.Than look for possible thermal fuse has cut off.
May 22, 2008 | LG DLE2514 Electric Dryer
Bosch wtl 5400 elect. condensation dryer
Harriet Scannon
Feb 18, 2008 | Bosch Axxis WTL 5400 Dryer
Front loading dryer
The check filter light is just a reminder light and cannot be reset.  Nothing to worry about.  Just keep the filter clean before each use.
Nov 21, 2007 | LG DLG2524 Gas Dryer
Open Questions:
Dryers Logo
Top Dryers Experts
