Question about Mercedes C-class C230 C240 C350 C55 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2005 2006 2007
Car cranks but will not start
Have been working on this issue for the last 9 days now. 2005 c230 Kompressor Car started to idle rough and kept shutting off. Than cranks and does not Start. Mechanic and I started to try to figure out what is going on. We put odb2 scanner in and read the codes as camshaft and misfire We than removed the valve cover took out the coils and noticed there was oil leaking into the sparks 1, 2 Ordered new sparks, replaced gaskets, cleaned and check coils that were producing spark. Tried to start car. Still cranks no start We than ordered two cam adjuster magnets and replaced them. Still crank no start After doing more research we than ordered and replace the Crankshaft Position Sensor. We hooked up back the odb2 and all codes and faults were gone except the overhead control which is the sunroof. Still cranking and not starting
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 65 Answers
Maybe you're looking in the wrong area. You said it started to idle rough and kept shutting off. That could also be a fuel related issue. Possibly a clogged fuel filter or weak fuel pressure from the pump going bad. Check your fuel pressure. If you discover that the fuel pressure is correct, then make sure you have a strong blue colored spark from each coil by taking a good plug and plugging it into each coil while its out of the cylinder. Have someone spin it over and watch the color of the spark. A dull orange colored spark could mean bad coils or even the computer itself.
Posted on Dec 06, 2014
5 Suggested Answers
Mr BrokRench
  • 1623 Answers
SOURCE: 02 c32 cranks but will
Hello Joe, i would suspect the crank position sensor has faulted...this is the most common cause for a no start condition on your model MB.
I hope this helps.
Posted on Jul 16, 2011
SOURCE: I got a 2002 C230
i have the eaton suppercharger in my garage that came from a car just like yours'. brand new.
Posted on Dec 03, 2011
  • 18 Answers
SOURCE: I changed the battery on my 2007 ML350 and now
That could mean that your alternator is bad. If you have a volt gauge on your dash check it. It should be reading about 14.4 volts. If it is reading closer to 12 volts then your have a pooched alternator. if you are reading the right volts then pull out the manual and look up the symbol. It should tell you what it means and might get you closer to the solution.
hope this helps.
Posted on Sep 21, 2013
caterpillerc
  • 45 Answers
SOURCE: how do i set valve timing on a benz C180 kompressor with twin cam and a chain
how many cylinders do you have because other wise i can not help you and may i please have the firig order
Posted on Nov 28, 2013
2005 Saturn vue wants to fire but won't. Battery reads 12.2.volts prior to starting and drops to 9 volts when trying to start. replaced cap and it started on first try. it had a rough idle before...
Unfortunately the answers you have given for replacing a cap is too vague. Is it a gas cap, radiator cap, air conditioning service port cap.... Look the battery needs charged that is why the battery drops to 9 volts, a good charged battery should drop to 10 volts. Check your battery terminals or cables for corrosion. Do a voltage drop tests on both positive and ground cables. As far as not starting any more...do you mean not cranking as in no starter eengagement or cranking but not running? If it is not running listen to hear in the first 10 seconds to the fuel pump relay if it engages or listen for fuel pump...is the car getting spark?
Feb 27, 2015 | 2005 Saturn VUE
2005 c230 Kompressor = Crank no Start
You have to go back to the basics to find out what systems aren't working. Fuel/Fire/Air. Is it getting fuel, is it getting spark, how is the compression? Once you figure these things out then you will be heading on the right track.
Dec 03, 2014 | 2005 Mercedes-Benz C-Class
2005 Taurus rough idle and engine light
you have a possible vacuum leak somewhere or maybe clogged egr
Aug 15, 2017 | 2005 Ford Taurus
Fuse box diagram for 2005 C230 kompressor
i drop a dime inside the hole of where the lighter goes, and now my new car charger will not work. where is the glove box? In what order do i replace the old fuse so i can get a new one!
Jun 19, 2010 | 2007 Mercedes-Benz C230 Sedan
I have a 2000 Mercedes C230 Kompressor. During
no their isnt ,sounds like they fitted a second hand unit
Nov 25, 2009 | Mercedes-Benz C230 Cars & Trucks
Reset alarm on 2000 Mercedes C230
Disconnect the battery lead at the starter motor.Leave off for a few hours then reconnect it.It should reset it for you.
May 12, 2009 | 2000 Mercedes-Benz C-Class
Check engine light,engine miss,loss of kompressor power
might have a vacuum leak. 2005 c class 230 kompressors have issues with the engine vent hoses under the intake manifold deteriorating and coming completely apart. This will cause mixture adaptations to max out and can cause missfires. Usually it sets a check engine light when it gets bad enough. There is a factory recall to replace these hoses, so check with mbz to see if your car has an open recall
Mar 12, 2009 | 2005 Mercedes-Benz C-Class
Got 1999 C230 Kompressor key. Do I need to program?
this should work straight away, but i would first put the key in the ignition, and put the ignition on for 30 seconds to a minute, then start it up
Feb 17, 2009 | 2007 Mercedes-Benz C230 Sedan
Mercedes C-class C230 C240 C350 C55 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2005 2006 2007 Logo
133 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
David Burbee
David Burbee
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
