Ws-55411 flashes 1-2 code 5 x's will not come on?
Wont turn on & fuse above power cord shows good. it shows 3 other fuses, but cant see them on top side of the 2 boards. unless they arte not reg. fuses ?
    Sergeant:
  • 233 Answers
This sounds like a power relay has failed. Sounds like it gets enough power to tell you the error code, but not power on the t.v. many times fuses can be hidden inside a layer of heat shrink tubing and these are what are called through hole fuses. They will normally look like a large resistor on end without and value markings.
Posted on Dec 03, 2014
Ws-55411 getting a code 22 short circuit were do i need to look for with this problem do you have idea ?
Check the pico fuses on the board. If one or more tests open, then likely the STK chips need to be replaced. This would mean a convergence failure.
Feb 19, 2011 | Mitsubishi WS-55411 55" Rear Projection...
WS-55411 What seven capacitors need replacing? 2-3 code Problem
U check the power supply board,check all cap,and replaced it?Ur tv make buzzing noise when u turn on power?Ur flyback is dead.
Mar 17, 2010 | Mitsubishi WS-55411 55" Rear Projection...
TV wont turn on, the power light turns green for a second then blinks three times and turns off?
That blinking light represents an error code,give Mitsubishi a call they will help you troubleshoot and diagnose your problem and if needed help you set up service. 1-800-332-2119 Good luck !
Nov 29, 2009 | Mitsubishi WS-55411 55" Rear Projection...
Turn on the power and the green LED blinks on the front for a second, but tv does not power on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Jul 30, 2009 | Mitsubishi WS-55411 55" Rear Projection...
Do have power and sound, do not have picture
this unit has a self test check you can do
when the set shuts down or when the set is turend off.
press and hold , onthe front of the set the input or device button, and hold the menue button for bbout 5 seconds.
the set will flash a 2 digit blink code at you.
12 blik = no problem
21 blink = xray protect
22 blink = short protect
23 blink = loss of deflection.
regards,
daniel.
Jan 15, 2009 | Mitsubishi WS-55411 55" Rear Projection...
Green indicator light flicks about 3-5 times
The power supply has likely detected a short circuit. Hold the front panel INPUT and MENU buttons down for 5 seconds then read the code from the green light. If the light flashes a 2-2 code (2 flashes, followed by a 1/2 second pause, followed by 2 flashes) then pico fuses are blown. A 1-2 code indicates that nothing is wrong. The likely cause for blown pico fuses (FA904 & FA905) is a bad convergence driver IC. The PC board must be resoldered to replace the ICs and fuses.
Aug 09, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi turns on for 3 seconds then shuts off..after power surge
try holding in the menu and input buttons together on the front panel for about 8 seconds to see if the self diagnosis feature will blink a two digt code then let me know what happens
Jun 05, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi WS-55411 55 in. No Power up
Error code 12 means normal operation. On these models we have found that a switch is bad on the control panel not allowing the set to turn on. Disconnect the control panel. You will be able to use the remote on set. To find the plugs for the control panel: Remove the speaker grill and front panel, then follow the wire to the connection. You can use an ohm meter to find the bad switch.
Jul 04, 2007 | Mitsubishi WS-55411 55" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
