Question about Top Irons
I am unable to twist off the top of the iron in order to put water into the steamer. I have tried twisting it clockwise and counter-clockwise as instructed. I
  • ElectroWill Dec 03, 2014
    Hi lori tarlow, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What is the make and model of the iron that you are having an issue with?
Please let me know the make and model of the iron. We have a Delonghi Pro300 and I fashioned an opener out of a 2 inch pvc t that I purchased at Lowes. It allows my wife to open the steam reservoir with no problem.
Posted on Dec 07, 2014
3 Suggested Answers
  • 5 Answers
SOURCE: OMNI STEAMER GENIUS 2000 STEAM IRON HAS STOPPED
check the connection. Most probable the heater connections are rusted due to water seepage or melted due to overheating.. If you can dismantle and check the connection.
Posted on Jun 11, 2010
bunnydawg
  • 5158 Answers
SOURCE: Electric cord on my Rowenta
replace it with a lighter gauge wire or a coiled power type cord if you can find one....
Robert
Posted on Sep 06, 2008
How do I put water in the steamer?
it turns counter clockwise .
Nov 27, 2015 | Irons
Why does cord on steam iron always twist any help suggestions ? What is the little thing for on the cord ?
The cord twists constantly because it is the wrong type for the intended use.
The little thing on the iron end of the cord prevents twisting at the point where it enters the iron.
Feb 26, 2015 | Irons
I tried to bring the inferior thread up after put in the bobbin but the needle do not pick up and stopping me for sewing
Is the bobbin put in right? Make sure the thread is coming off the bobbin in a counter-clockwise direction. Also make sure you're leaving enough thread coming off the bobbin for the top thread to grab hold of to pull up.
Feb 18, 2013 | Singer 8763 Curvy Electronic Sewing...
My rowenta steamer is not producing steam but tubing getting hot when I turn on steamer. Suggestions?
see this causes and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Feb 03, 2013 | Rowenta Commercial Garment Steamer - White
Hot hose but no Steam
Don't know this machine but if it has brass jets on the head stick a pin or a needle into them twisting while pushing in and out, some times these jet block up. other wise undo hose and blow through it hope I have helped in some way.
May 19, 2010 | Rowenta Commercial Garment Steamer - White
The cap is stuck unable to open to fill?
I had the same problem. I sprayed up into the bottom of the cap with liquid wrench, let it work for a while, then had to use large pliars to twist the cap off.
Jan 27, 2010 | Steam Fast SF-220 Iron
Conair steamer leaks water and wets my clothes.
When I use mine I hang the hand held part from my closet door, while I am waiting for it to heat up. When the hose gets too much condensation, from the steam, it leaks out... This will also happen if you try to use in the motion of an iron. The hand held part needs to be at a vertical position at all time to prevent leaking.
Jan 24, 2009 | Conair Compact Garment Steamer Iron
When using steam iron i am left with a puddle of water on the floor how do i control the amount of steam
I think is maybe the hose connections. You need to make sure both ends (by the T-nozzle and by the body of the steamer) are secure. You have to align the nozzle with the rod, and push down, and twist. Try watching instructions for connecting both ends on www.HandBookLive.com under appliances category. There are GS4 video instructions and GS10 (this one has just been posted yesterday)
hoe it helps. Otherwise I would return the steamer. Nowhere in the operating instructions does it say that you can control the amount of stream produced...
Laura
Sep 27, 2008 | Conair Compact Garment Steamer Iron
Drain screw
He, if the repair was done within their warranty period, try calling their service department. It should be covered...beyond that, I would say that someone either overtightened or cross threaded the drain screw. You might warm up (but not fully presurize) and see if you can loosen it 1/4 turn counter clockwise (no further) and let it cool before removing.
Aug 05, 2008 | Rowenta DG-980 Iron
Irons Logo
99 people viewed this question
Top Top Irons Experts
ray gallant
Tom Chichester
Michael McClure
Michael McClure
Are you a Top Iron Expert? Answer questions, earn points and help others
