Question about Bosch Refrigerators
Does anyone know how to reset ice maker and water dispense on bosch side by side fridge
  • Bosch Master
  • 4,655 Answers
You should always provide your model number with your questions here helps us determine what you have but knowing that you have this brand of refrigerator also means that you probably are going to have to talk to the factory they are the only ones that provide the parts for that that refrigerator at this point I think you have a bad electrical connection in the door or either the door switch
Posted on Dec 05, 2014
Master_Tech
  • 770 Answers
SOURCE: cold water dispenser on new whirlpool side by side dispenses lukewarm water...ice maker works a charm
there is a tank in the refrigerator section that hlds about 1.5 gal of water as you dispense it refills and pushes out the cold water. if your unit is new it will need a day to cool down the tank of water before you will get cold cold water at the dispenser
Hope this help explain how it works
Posted on Aug 01, 2008
Krazytech
  • 725 Answers
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Posted on Sep 07, 2008
SOURCE: GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Posted on Nov 17, 2008
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
arikrom
  • 528 Answers
SOURCE: Neff K3990 American style fridge ice maker is not producing ice
The ice maker unit give the command to the water valve to relese water for a short time.
you cna check with volt meter on the water volve that got the pip go to the ice maker unit if it getting 120V for short time when the fingers of the ice maker making full round.
if you get 120v the problem is the valve (the ice maker and the water have difrent water path so its difrent valve used) if you dont get 120v or the fingers of the ice maker not turning then its your ice maker unit need to be replace.
I hope you find this Very Helpful and best regards!
Posted on Jan 04, 2010
Testimonial: "Many thanks ,will give that a go and come back to you"
My Bosch ice maker has a problem. It has frozen over and does not dispense the ice cubes, the refrigerator thinks it has dispensed the cubes and so try's to fill the ice cube tray up again with wa
Ice makers have heaters that loosen the cubes when time for harvest. Sounds like the heater on yours is bad, or maybe the ice maker itself is just bad. Most likely will have to replace ice maker.
Oct 12, 2017 | Bosch Refrigerators
The ice maker makes ice and dispense water, but won't dispense ice. Cleaned out ice tray, not ice blocking any discharge area. When you try you can hear the ice dispenser door open, but the motor to...
i have the same fridge... same problem, except not only does it not dispense ice, it also dosent dispense the water too. i recently had a power outage, and when the fridge was turned back on the digital warmer and colder setting have been flashing 0 non stop making it unable to set temps... any suggestions?
Aug 22, 2011 | General Electric GSH25JSXSS Stainless...
Does anyone know how to fix an ice maker?
When the ice maker calls for water it pours for about 7 seconds if more will overflow and drips into tray , but the most common problem is the dual valve that leaks even after ice maker called for water (this valve is located in the back of the fridge at the bottom where the water line is hooked up.)
Aug 09, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
My GE side by side fridge/freezer is working, water dispensing ok, but not making ice. I switch off the fridge, than ice maker but still not making ice. I try all the hints from Manual but no luck. Water...
fill the ice maker with water manually, if you have ice in the bucket you know that the ice maker is working , after check the water valve if is opening , if it is replace main board
Jun 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana Side-by-Side Fridge Model SBD21VPSE Problem started when water stopped flowing from in-door dispenser and ice maker stopped making ice. I emptied fridge and freezer, left unit off for several...
Nov 29, 2008 | Refrigerators
Ice maker not working
what filter? drying filter? Water filter? Dust Filter?
Jun 24, 2008 | Frigidaire FRS26R4A Side by Side...
Water dispenser
wow that's agood one!!!! theres a short for sure, just a matter of where. somehow your energizing both sides of water valve at once, sounds as if it would be behind the dispensor, at the switches. would remove the dispensor cover and have a look for a bad switch or exposed wire
Mar 08, 2008 | Refrigerators
Ice and water dispenser
Has someone pressed the lock button on the front of the fridge just above the dispenser, next to the crushed & not crushed ice button, if so there is also an unlock button next to it.
Jan 04, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frigidare side by side Gallery fridge
sounds like you water is spilling out instead of going into ice maker... check the inlet spout for ice or other blockage
Oct 10, 2007 | Frigidaire GLRS237ZA Side by Side...
Refrigerators Logo
199 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
