Question about Radio Communications
FCC ID K7G T8500
Again, a little goofy. I've charged them up, have them both on channel 1, and they just make that "wheep" noise like they want to talk. I appreciate your help!
    New Friend:
  • 125 Answers
Make sure that the security/privacy codes/tones are turned off(or the same, but off is better), and also ensure that you never use them within ~5-10 feet of each other as it can damage the radios.
Posted on Dec 03, 2014
4 Suggested Answers
ALLEN CLARKE
  • 47 Answers
SOURCE: has static and cannot hear transmission
sounds like it is off frequency and needs retuning
Posted on Nov 27, 2008
eradiostore
  • 1654 Answers
SOURCE: Problem with Motorola t8500
Check your Qt filter setting. It works best in the "off" position.
Posted on Jan 19, 2009
driveallnigh
  • 89 Answers
SOURCE: We have 4 T8500 - only one can talk, the other 3 only recieve.
Can you tell if the radio is actually transmitting? Is there any sound on the transmitting radio or a light inditcating that it is indeed transmitting? If not maybe the PTT button is malfunctioning. Try to use a microphone plugged into the accessory jack and see if it works. Another option is if you have a radio scanner, search the frequency range while transmitting and see if you pick up that open carrier.
Posted on Feb 26, 2009
WHERE CAN I BUY ONE
Check ebay, search TalkAbout T8500.
Best regards.
Oct 16, 2014 | Motorola Walkie Talkie 2-Way Radio
Motorola fcc id k7gt8500 manual
Here is a link http://shop.giantintl.com/Manuals.asp
Choose T8500 from the pulldown to get to the online manual.
Best regards.
Mar 07, 2014 | Motorola Talkabout® T8500R Two Way Radio
Not recieving voice on FCC ID K7GSX900
Be sure the channels and codes are set identically on both radios.
Nov 06, 2012 | Motorola Walkie Talkie 2-Way Radio
Remotes suddenly stop working #85095-01, and FCC ID IN2TX13
1) clean the contacts batteries, with cleaner contacts
2) tight the spring contacts with pliers for better contacts
3) resolder the wires connector from contacts batteries
4) open the remote c, and clean the keypads with contacts cleaner
God bless you
Jul 02, 2012 | Hunter 27185 Remote Control
Not charging and no light saying it is
There is a possibility that the battery could not be taking the charge, but typically the light is red while charging and green when done. Sometimes if the is fully drained it can take up to 15 or 20 minutes before the red charging light comes on. Try leaving it charging for 24 hours.
May 05, 2010 | LG HBM210 Bluetooth Headset Wine Red Color
Radio Reset on PPT
The Battery Pack:KEBT-071-B was memory depleted. Just Try using Alkaline Batteries and test again, if the test results OK, Memory Discharge de Battery Pack Full Discharge and them complete the charge Cycle Again until the Memory Charge error disapear, or optional Buy a new Battery Pack.
Jun 12, 2009 | Motorola T8500 Two Way Radio
T8500 no recieve transmit vibrates when PPP is pressed
http://www.giantintl.com/ContentManage/manuals/Moto/T8500%20English%20only%20June5.pdf
Try checking the vibra call settings for your vibrating issue. Also, as for the radios not communicating with one another you should check the programming of the frequency, interference eliminator and the Qt filter. All radios must be identical to work together.
Apr 27, 2009 | Motorola T8500 Two Way Radio
Motorola T8500 Communication Problem
Check your interference eliminator code, and also your Qt filter. Try setting both to the off position (zero) and see if you have the same problem. Another thing to check would be your batteries and battery contacts.
Jan 25, 2009 | Motorola T8500 Two Way Radio
Jan 17, 2009 | Motorola T8500 Two Way Radio
Radio Communications Logo
42 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
