Nothing that I have pressed has helped. they said you have 14 days to cancel but I can't any help. it sounded so simple
Good Morning friend, thank you for your post!
Based off the information you have provided your Frigidaire oven, PLEF398DCH, has locked you out and you are unable to fix it. Sometimes a reset can fix this problem. In order to reset your oven you would need to flip the household circuit breaker off for roughly ten minutes.
If this does not help correct the issue you can perform a self-clean and right before the clean starts press the cancel or clear button. This should trick the oven into disengaging your door lock. Lastly, hold down the clear or cancel button for 10 to 15 seconds and that should release the lock. If you perform all this troubleshooting and the door is still locked it could be a bad latch and that may need to be replaced. I hope this information is helpful. -Matt
