Question about Dell Inspiron 530 Desktop Computer
How do I find the password for my dell 530 computer
I have unplugged it several times.I can't get in because it says it don't recognize my password
  • ElectroWill Dec 03, 2014
    Hi David Morrison, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Is this the computer BIOS password or your Windows User password?
    Novelist:
    Scholar:
  • 99 Answers
If you are referring to windows itself then the previous suggestions are appropriate. If you put a password on through bios then this is much more difficult. there are many tricks other have used from bypassing to opening the computer case and altering a few things. here is a link to something I can say does work if your problem is a password through bios not windows. How to Bypass or Remove BIOS Password Technibble
Sometimes depending on system and age you can use a default password through windows that is a backup a lot of people are unaware of..... Admin, Administrator or password. Are ones that usually will allow access. Re-installing your OS will only resolve the issue if it is not bios related and should be used as a last resort.
I hope this gives a little insight if nothing else.
Posted on Dec 05, 2014
  • 3 Answers
Boot in Safe Mode and run a System Restore which will take your machine back to the last time you signed in correctly.
After that, reset your password when the screen prompts you too...
Posted on Dec 03, 2014
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Dell Master
  • 906 Answers
If your Windows is not recognizing your password, you may need to reset the password. To do this, you can follow the instructions mentioned on the following webpage:
http://www.fixya.com/support/t24940481-says_am_not_putting_right_password
GuruAid.com
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 87 Answers
You could try starting it in safe mode and then deleting the password requirement. Another way may be to set a new administrator account, then go into the set up and reduce the existing account to the status of secondary account. Once that is accomplished, then remove the request for passwords. Sometimes these passwords are actually in the BIOS, then go into the BIOS and remove all password requirements.
Frankly after a "problem" with a password I stopped using them for the machine, however, I opened a second user that was password protected and then use that and all that was in the administrator files a copy of the password!
Children are extremely good at changing passwords for you!
    Cheetah:
  • 39 Answers
If nothing else works,you need to reinstall OS.
4 Suggested Answers
  • 3940 Answers
SOURCE: When I take the computer out of the standby mode
Try this:
  1. Update the BIOS and Video driver to the most current on http://support.dell.com
  2. Disable the screen saver
  3. Enable HIBERNATE instead of standby in Power settings, set the LCD to go off in 10 minutes, HDD to 15 and Hibernate in 20.
Select Shutdown, Hibernate
then try and restart
If no GO, disconnect all peripheral items except KB
Try hibernate again and restart.
If all works OK, add items back one at a time till you find item causing issue. If no go, replace power supply if issue still occurs, replace MB
Posted on Oct 14, 2009
StonerG
  • 16 Answers
SOURCE: Hello My Dell Inspiron 530 will
Offline NT Password & Registry Editor - Available as bootdisk or bootable CD, Offline NT Password and Registry Editor works to change or reset password of any users on Windows NT 3.51, NT 4, Windows 2000, Windows XP, Windows Server 2003, Vindows Vista 32 and 64 bit. It can also detect and offer to unlock locked or disabled user accounts.
http://home.eunet.no/~pnordahl/ntpasswd/cd080802.zip
Posted on Jul 14, 2011
SOURCE: During Startup, Dell Inspiron 530 computer goes into startup repair mode, have to run through repair mode several times, it will finally restart.
Did you install anything before you had the Repair Mode? You could hit the F8 or F9 key depending on computer and select 'Last Good/Known Configuration'.
Posted on Jul 03, 2012
Computer does not recognize the monitor. what should i do to fix it
First Thing to do is power down your computer. Run a virus quick scan and remove any threats...Before powering up again, unplug your monitor from the CPU...Power up and plug in your monitor, this should reload the drivers. You can then go to your display settings box and select your monitor, as it will be the only one to select...This should solve your problem...
Mar 16, 2014 | Dell Inspiron 530 Desktop Computer
I have forgotten my password to my windows vista Dell 530 Inspiron desktop
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
There is a free boot CD called Hirens. This one command prompt only.
Oct 14, 2012 | Dell Inspiron 530 Desktop Computer...
How to reset user password
  • Login as other user (if other user is availible) and manage users. Must be an administrator.
Sep 25, 2012 | Dell Inspiron 530 Desktop Computer
Jul 03, 2012 | Dell Inspiron 530 Desktop Computer
When i start my dell inspiron 530 desktop....
according to dell's documentation, 2 short beeps means a memory problem. try the suggested remedy in their site.
don't forget to rate me if I was able to help out. :)
Jan 10, 2012 | Dell Inspiron 530 Desktop Computer
Most of the time my INspiron 530 does not boot up. the screen is blank and the fan runs high. Sometimes it beeps 4 times. What could be the problem?
Sounds like you have hard drive problems !! Check the Bios and see if the hard drive is being recognized or it might tell you that it is faulty by not showing up at all.
Nov 01, 2010 | Dell Inspiron 530 Desktop Computer
I forgot my password and I can't use my computer.how do I reset my password?
you can try pulling the motherboard battery for 10 min.(unplug the unit first) also on your board should be a jumper to clear it. it can be labled as clear CMOS or PW or PASS or any variation. most of the time this works. if it is a BIOS bassword this probably wont work and you will have to contact Dell. you will have to show proof of ownership and jump through hoops.
Oct 19, 2010 | Dell Inspiron 530 Desktop Computer
Try this:
Oct 13, 2009 | Dell Inspiron 530 Desktop Computer
Dell Inspiron 530 Desktop Computer   Logo
95 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
