Question about Thermador Ovens
How do i make my convection fan turn off when i open the oven door
2014 48 professional dual fuel. When i open the door to look in the oven the convection fan blows 450 air right into my face. My old viking turned it off when the oven door opened
    New Friend:
  • 125 Answers
It sounds like there should be a switch on the door and it is malfunctioning. I would contact the manufacturer as it should be covered under warranty if it is malfunctioning. Especially for a $10,000 oven.
Posted on Dec 03, 2014
  • 87 Answers
SOURCE: convection fan not working
Check for a bad fan motor or a jammed blade.
Posted on Jun 14, 2007
bigg t
  • 640 Answers
SOURCE: 5 year old Jenn Air double oven
the door switch contacts are stuck closed causing the oven to stay on.if you can access the door switch try to wd-40 on it.if that doesnt help you need a door switch.
Posted on Aug 17, 2007
barkencoa
  • 3463 Answers
SOURCE: Oven is not heating...the convection fan blows, but no heat
If the oven is electric and fan assisted,then I would suggest that the oven fan element is faulty.
Plz rate this solution.
thanks.
Posted on Dec 17, 2008
SOURCE: Oven fan keeps running even after off and door open
3 to 4 hours is a long time. Get to the fans (behind the control panel) and check the screens for dust. Chances are the screens are clogged with dust and need to be cleaned so the fans can move air for cooling better. I had this problem on my GE JTP14, and after cleaning just one fan it can keep up with cooling the electronic area while the oven is running. It runs much less often.
Safety first! cut the breaker before removing anything with a nice conductive screwdriver! Hope this helps!
Posted on Jan 04, 2009
protek480
  • 1714 Answers
SOURCE: Kitchenaid gas/convection stove oven door locked & won't open
F5 - E7 Self clean latch will not unlock
Remedy:
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes.
Posted on Sep 17, 2009
Oven on lock. How do you unlock
most likely the door locked due to an overheat situation. It's a safety feature on most ovens made today. It may be caused by a fan motor not running properly thus allowing area above oven cavity to sense extreme temperature, blockage in air flow pattern, or a bad temperature control.
Whatever the cause, it's best to have a tech take care of this issue for you to prevent danger to you and your family.
Jan 29, 2015 | Kenmore Elite Stainless Steel 40" Dual...
What are the possible sources of the following problem? Our convection oven works fine when it's turned on in the morning. However, when you open the doors for too long, the fan needs a manual push
The oven is designed to turn off the fan if the door is left open too long. I think it is a protection to avoid injury to the user due to heat circulation. It might be best to turn down the heat setting when opening the oven for long periods whilst the cooking is on. If you want the manual it can be downloaded from this site. see page 23.
http://www.blodgett.com/wp-content/uploads/Zephaire-100-G-200-G-ES-man-english.pdf
Aug 26, 2014 | Blodgett ZEPHAIRE G SGL Gas Single Oven
Model TE2B garland does the fan run to move
The fan runs to circulate the heat inside the oven for more even and faster cooking...That is how a convection oven works :)
Jan 14, 2010 | Garland Convection Oven - MCO-NAT Gas
Bought oven second hand so no model no. it is a dual belling range with fan. the oven heats up but the fan has stopped working! single parent who hasnt a clue, please help!!!!!
most model numbers are located around the frame of the stove, inside the drawer area or on the oven door, call the manufacturer, most have a toll free number. Check to see if the fuses are okay first, if one is out, that could weaken the system. The fan is probably convection, and your controls will have a convection feature. If the fan has ceased to work, just use the regular bake mode.
Sep 03, 2009 | Belling Ovens
The blower fan does not turn off when door is opened
LETS SEE LOOKS LIKE A GARLAND CONVECTION OVEN OR BLODGET, ANY WAY THERE IS A DOOR SWITCH UNDER THE LOWER PANEL MAY JUST NEED ADJUSTING OR A SWITCH. MY ADVICE IS GO ONLINE TO THE MANUFACTURE AND LOOK UP YOUR MAKE AND MODEL AND YOU CAN GET A PARTS BREAK DOWN FOR THIS UNIT WITH PART NUMBERS
IF YOU HAVE ANY PROBLEMS WITH THIS E-MAIL ME YOUR MAKE AND MODLE AND I WILL BE MORE THEN HAPPY TO GET THE BREAK DOWN. tstewart1956@verizon.net
Aug 10, 2009 | Vulcan Convection Oven - VC44EC-208-1
Convection oven no longer works
Could be the fan trying to start, ,if there is a removable cover in the back of the oven, remove it and see if the fan is free to spin, could be a tight bearing , or it could be stuck with a build up of grease.
Jan 02, 2009 | Viking 30" Professional Select Built-in...
Frigidaire Gas Range with Convection--fan does not turn on
The convection fan is wired through the door switch make sure your door switch is o.k. before replacing the board or the fan. Please have a local service tech check unit if you have to get into any electical checks. good luck
Dec 02, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
71 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
