Question about Thermador Ovens
How do i make my convection fan turn off when i open the oven door
2014 48 professional dual fuel. When i open the door to look in the oven the convection fan blows 450 DegF air right into my face. My old viking turned it off when the oven door opened
  • 54 Answers
Door switch is stuck,clean or replace
Posted on Dec 03, 2014
  • pamandruss Dec 03, 2014
    I checked and there is one switch that seems to work as it turns the oven light on when i open the door
Bosch oven cooling fan is continuously on at the same speed and is on always no matter what the temperature is. Upper heating element does not turn red hot in broil mode.
The oven has internal fan at back of oven encircling the element that should get reshot when stat turned up high. Also there is cooling fan under lid to keep the wiring area cool.This should stay on for around ten - fifteen minutes after cooking finished. David "The Famous Forry"
Oct 16, 2017 | Bosch Ovens
Oven on lock. How do you unlock
most likely the door locked due to an overheat situation. It's a safety feature on most ovens made today. It may be caused by a fan motor not running properly thus allowing area above oven cavity to sense extreme temperature, blockage in air flow pattern, or a bad temperature control.
Whatever the cause, it's best to have a tech take care of this issue for you to prevent danger to you and your family.
Jan 29, 2015 | Kenmore Elite Stainless Steel 40" Dual...
It sounds like there should be a switch on the door and it is malfunctioning. I would contact the manufacturer as it should be covered under warranty if it is malfunctioning. Especially for a $10,000 oven.
Dec 03, 2014 | Thermador Ovens
What are the possible sources of the following problem? Our convection oven works fine when it's turned on in the morning. However, when you open the doors for too long, the fan needs a manual push
The oven is designed to turn off the fan if the door is left open too long. I think it is a protection to avoid injury to the user due to heat circulation. It might be best to turn down the heat setting when opening the oven for long periods whilst the cooking is on. If you want the manual it can be downloaded from this site. see page 23.
http://www.blodgett.com/wp-content/uploads/Zephaire-100-G-200-G-ES-man-english.pdf
Aug 26, 2014 | Blodgett ZEPHAIRE G SGL Gas Single Oven
Model TE2B garland does the fan run to move
The fan runs to circulate the heat inside the oven for more even and faster cooking...That is how a convection oven works :)
Jan 14, 2010 | Garland Convection Oven - MCO-NAT Gas
Bought oven second hand so no model no. it is a dual belling range with fan. the oven heats up but the fan has stopped working! single parent who hasnt a clue, please help!!!!!
most model numbers are located around the frame of the stove, inside the drawer area or on the oven door, call the manufacturer, most have a toll free number. Check to see if the fuses are okay first, if one is out, that could weaken the system. The fan is probably convection, and your controls will have a convection feature. If the fan has ceased to work, just use the regular bake mode.
Sep 03, 2009 | Belling Ovens
The blower fan does not turn off when door is opened
LETS SEE LOOKS LIKE A GARLAND CONVECTION OVEN OR BLODGET, ANY WAY THERE IS A DOOR SWITCH UNDER THE LOWER PANEL MAY JUST NEED ADJUSTING OR A SWITCH. MY ADVICE IS GO ONLINE TO THE MANUFACTURE AND LOOK UP YOUR MAKE AND MODEL AND YOU CAN GET A PARTS BREAK DOWN FOR THIS UNIT WITH PART NUMBERS
IF YOU HAVE ANY PROBLEMS WITH THIS E-MAIL ME YOUR MAKE AND MODLE AND I WILL BE MORE THEN HAPPY TO GET THE BREAK DOWN. tstewart1956@verizon.net
Aug 10, 2009 | Vulcan Convection Oven - VC44EC-208-1
Convection oven no longer works
Could be the fan trying to start, ,if there is a removable cover in the back of the oven, remove it and see if the fan is free to spin, could be a tight bearing , or it could be stuck with a build up of grease.
Jan 02, 2009 | Viking 30" Professional Select Built-in...
Ovens Logo
88 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
