All i have is an unresponsive black login screen that won't open. i just want that useless ubuntu mess gone for good. step by step instuctions would be VERY helpfull. please help. m.h.
Once you start installing Windows 7 from your disc, you will be able to erase Ubuntu simultaneously. To know how it works, you can refer to the following link:
http://www.wikihow.com/Erase-Ubuntu
The following link can be helpful while installing Windows 7:
http://windows.microsoft.com/en-us/windows/installing-reinstalling-windows#1TC=windows-7
GuruAid.com
Yes, when you re-install whatever OS you choose, it will give you the option to wipe the entire hard drive.
However I don't feel that Ubuntu is a horrible system. Most likely it's either just an older version, or was installed wrong.
SOURCE: issues with my compaq armada
Hello Mitchiko
This error message is often the result of corruption on your hard disk. Quite likely including the MBR.
This could indicate your hard disk is failing or just that there was a glitch in your system that caused your MBR to be over-written or corrupted. In any event, w/ an error like this, you're going to need to ...
(01) Test your hard disk to make sure it's OK
(02) Attempt to restore your MBR
There are some great (free) MBR tools HERE.
There's a nice article HERE on "How to Repair your MBR". The author does a nice job of explaining what the MBR is and how to repair it.
Please, let us know if this response was helpful for you or, of course, if you have more questions, etc. on this topic.
Thank you
BJ
SOURCE: Broken Screen!
If you dig around in google shopping, you can find replacement LCD's. Something similar like this maybe -> http://cgi.ebay.com/Acer-Aspire-3000-15-4-WXGA-LCD-Screen-Glossy-Grade-A_W0QQitemZ160233528611QQcmdZViewItem
SOURCE: Please help me with my COMPAQ ARMADA 1700
Double check to make sure there is no floppy disk or CD-ROM disk inserted when you boot. If there is definitely no floppy or CD, your hard drive may have crashed or been corrupted. You can try installing Windows again, but it might not work if your hard drive is faulty. If it's faulty, you'll need to head to the local computer repair shop or have a geek friend help get and install a new one, then reinstall Windows.
SOURCE: upon boot up, screen remains black,disk power up briefly
HOW TO FIX YOUR DV6000/DV9000/DV2000/tx1000/tx2000
All the Problems described are Graphics Related..
Faulty Nvidia Chip..Both Intel And AMD Based Motherboards..Though More Common on the AMD..
The symptoms of the Laptop Powering on and Shutting Off Repeatedly..Or.. Powering On and Having No Video...Or... Power Strip Lights Up, Beeps,Shuts Down...Or..No Power At All...Or.. Intermittant Loss Of Wireless/Video Goes In And Out/Touchpad Slows and Freezes..
To Fix this issue, You will need to Reflow The Graphics Chip.
I will Explain In Full Detail As To The Correct Method Below....
HP DV6000/DV2000/DV9000 Compaq v2000 Video Chip Reflow Instructions
First Step Is Complete Disassembly Of All Parts And Components..
Remove RAM, Remove CPU, Of Course Remove Heatsink and Fan assembly.
Next Step is Insulating the Motherboard... You need to Protect The CPU area, The RAM area, Cover any plastic Plug ports.
Try to leave 1/4 inch area around the edge of the chip free of insulation.
To Insulate the Board.. I use thick pieces of Tin/Aluminum, you can fold up some aluminum foil (tin foil) About 4 folds thickness....
Now that you have your Motherboard Insulated... Make Sure There's Nothing Flamable Or Burnable Below the Motherboard... it will get quite hot underneath.
You will need a Heat Gun.. You can get one of these at your Local Home Improvement Store, they cost about $15 - $30.. You Will Use ONLY the LOW Heat Setting... I REPEAT..... USE ONLY THE LOW HEAT SETTING ....
Next You Will Need Some Coins.. Yes Coins..
8 Quarters and 2 Nickels... Put the 2 Nickels On the Bottom and Stack Quarters On Top...
Place The Stack Of 2 Nickels And 8 Quarters On Top Of The Graphics Chip...
The Reason for using the Coins: Using the coins serves a few purposes...
1) It Helps Transfers the heat Into The Chip More Evenly/Slowly
2) It Helps Hold The Heat Longer/Then Helps To Cool Slower
3) It Gives The Correct Amount Of Weight That Is Needed To Press The Chip
A Thing To Look Out For...
Hewlett Packard is nutorious for using the RED epoxy around the edge of the Graphics chip.. this epoxy is used to help secure the chip to the motherboard...
This is a process that is Hand Done at the Factory.. And Some Boards Will Have Only A Little Amount of this, Some Will Have Alot of it...And Some are Only Done On The Corner Edges....
If There Is Alot of This On Your Chip, You Might End Up Needing To Carefully (REAL CAREFULLY) Remove as much of this epoxy as able to....You can use a Razor Blade To Lightly Scrape This Off... DO NOT MISS AND SCRATCH THE MOTHERBOARD!!! Go SLOW...
Now Comes The Heating Of The Chip...
Start With The Heat Gun About 6 Inches Away From The Top Of The Quarter Stack..You want to be holding the gun at a 45% angle.. Aim the heat at the Edge of the chip, You Will Start Rotating Around the Chip- around the outer edge of the chip...then use tighter circles concentrating on the quarter stack, then after about 30-40 seconds, slowly move closer to the chip...
Never Move the Heat Gun Closer than the Top Of Your Coin Stack...Then Pull It Back And Slowly Repeat.. The Chip Needs To Get Hot Enough To Re-Melt The Solder Balls On The Underside Of The Graphics Chip Back Down To The Contact Pads On the Motherboard.. and this takes Quite Alot of heating to Do.... You Must Not OVERHEAT the CHip... It Is Best To Underheat it and have to Redo.. than to overheat.. It will cause the solder to break down and even crack/split.. causing failure forever...
This process will take about 3 minutes total.. Once you shut off the Heat Gun.. Leave The Stack of Coins On The Chip And Let Sit For Another 5 minutes..
Now Remove The Coins(carefull they might still be hot)
Remove All Insulation.. Reinstall RAM, CPU, Heatsink and FAN Assembly (and Of Course Thermal Pads or Paste.. Note:. If Paste Is Used.. It Must Be Silver Paste...
Now You Can Connect The Power Button Strip/ Video Cable And The DC Jack Cable.... And Plug In AC adapter .. You're Now Ready To Test For Solid Power and Video....
Upon Sucessful Chip Reflow/Rebake.... You Need To Go To The HP Website..( www.hp.com )..Click on SUPPORT AND DRIVERS, then select...DOWNLOAD DRIVERS AND SOFTWARE....Then either click the box to Auto-Detect System, Or Enter Your Make/Model Info, Once At The Page With All Of Your Drivers.... Choose The BIOS UPDATE Driver..
Choose The Newest Driver And Download/Install It... It Will Reboot The Laptop And Upon Rebooting, Your Fan Will Spin Faster And More Often Due To A Thermal Controller Update In The BIOS Update...
SOURCE: immediate logoff after login
Try this
1. Boot using your winxp cd.
2. Enter recovery console.
3. at the command prompt go to
C:/windows/system32
4. next type:
copy userinit.exe wsaupdater.exe
5. exit and reboot normally. You should now be able to logon. But you're not done yet!
6. run regedit
7. find the Userinit key in:
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsNTCurrentVersionWinlogon
8. modify the entry:
C:WINDOWSSystem32wsaupdater.exe
so that it reads:
C:WINDOWSSystem32userinit.exe
The message means you compressed your C drive. Windows can't even start that way
which operating system ? if you dont have an installation cd
http://www.ubuntu.com/download/ubuntu/download
which can repair what windows has ruined and is unable to fix fix the problem
either burn it to a disk as an iso and install it
its an open source operating system
hope this helps
Windows 7 operating system also known as user development interface is the latest on the market as of yet should not have another interface environment. Prior operating development environment programs had several updates as means to improving a deficiency or malfunction making possible overriding an existing version on the compute with an improved version. However, the procedures of performing operations systems overrides requires both programs installed on the computer for occasional exchange features to be made as crossover functionalities. Usually operating systems have compartibity standards where for examples windows 7 is expected least compatible with windows vista or XP or millennium or 2000 or 98 or 95 operations displays. The type of operations system on the computer must have been providing with additional update software from the manufacturer else overrides are impossible unless deciding to change the entire version to another version similar as acquiring a new computers display environment. That is possible though would usually require for several hard ware component parts to be changed as well for copyright reasons. For example, if attempting to change the latest windows operating system like windows 7 to windows Vista operating system, the computer's hard disk drive containing the stored programs have be erase completely of content else would remain incompatible to foreign code programs. Thereafter an entirely new software system is installed on the blank disk to attain user desireeabilty. However also, a change in operating system causing change in hard disks may require change in memory devices since capacities are least predicted to experience adjustment alterations of such magnitudes. Finally the attempt to change systems would produce results only least familiar to the user as before. For example, change in operations systems on an original computer unless component parts were acquired to build one's own would require updates of several components least requiring over stressing deliberation.
