Question about GE Washing Machines
Why do my front load ge washer leave lint on the clothes?
Ge told me some things to try but I was already doing them, like use liquid soap instead of powder. And shorter wash cycles. Also to dry my clothes and see if the dryer catches the lint. It's really bad on the black clothes, that I don't put in the dryer. But it does it on all the clothes, just can't see it as bad on the lighter colors.
  • 3 Answers
A lot of build up from front loaders is caused from "scrud" excess detergent or constant cold water use. Place a cup full of Epson Salts in the machine and run through a hot wash cycle every 4 weeks or so and this will help keep bowl clean.
Posted on Dec 03, 2014
SOURCE: GE front load washer
Remove the front lower panel (3 screws on lower lip - lay on floor to see). Panel come right off. there is a round "dial" to the front housing. Put down a bath towel on the floor and unscrew dial - then pull it out.
Posted on Aug 28, 2008
duby1990
  • 367 Answers
SOURCE: Is powder or liqued detergent better for front
They are trying to make money off you!!!!!!! LIQUID!!!! Dont ever!!! use powder soap in your front loader. Powder soap doesnt dissolve all the way and then gets into the bearings of the washer and eats them away! This caused about a 450 dollar repair for your repairman. Never use powder soap.
Posted on Feb 20, 2009
  • 686 Answers
SOURCE: my stakable maytag washer leaves lint marks on the
new washer have what is called a washer drain protector, in other words it's a lint catcher for washers and your model has no such part. Do you use powder or liquid detergent? It seems to me that what you see is residue from too much detergent if you use powder. I've heard others with this complaint and to no avail can figure out the cause of this, at least from a view point of a simple wash.
Posted on Apr 06, 2009
  • 3600 Answers
SOURCE: Brand new GE Profile leaves clothes soaking wet
It is under warrenty call the store where you bought it and have them look at it. If you mess with it it will void your warrenty, belt may not be working or transmisson may not be shifting. The house call will be at no charge.
Posted on Sep 10, 2009
Testimonial: "thankyou for the help, I thought I had just made a bad buy. They sent someone out right away and it turns out this particular machine had a bad part."
SOURCE: Asko Washer/Dryer (WCAM 1812); Dryer not working.
Update: The dry cycle is now working! Apparently the automatic overload/shut off on the heating element got tripped. We had a technician out this morning. He unplugged the machine, removed the top of the unit, and simply pushed a little red/orange button that was on top of the heating element. When we plugged it back in the heating element worked again. The technician was able to troubleshoot this by checking the amps while running the dry cycle. But the proof was really when we did a load and the machine heated up (just like it used to) during the dry cycle. This was actually a relatively simply fix - though could be dangerous as you have to open up the electrical area. The reset button is rather inconspicuous and located on top of the heating element, which is long (runs front to back in the center part of the top of the machine - which you can get to by removing the lid/top outer housing) and silver - wrapped in insulation. It's pretty obvious. The button is in a little metal fixture on top of the heating element. The technician told us that the rest can get tripped when the unit overheats. (We think this happened when the laundry tub overfilled and the hose was totally submerged - the machine was working overtime to pump out the water.) The technician also warned that this can happen if the machine gets turned off suddenly mid-cycle - especially during the drying cycle. He said that the heating element gets so hot, it needs to have a gentle cool down period, which is marked on the dryer dial for the last 20 minutes of the cycle. I hope this helps others!
Posted on Dec 02, 2009
Why does my front load ge washer leave lint on the clothes?
We found that my family was not cleaning the kleenex and stuff out of their pokets. Once we checked all pockets very little lint appeared.
Dec 03, 2014 | GE Washing Machines
GE WSXH208FWW washer leaving spots on clothes
If you are getting round dark spots on your clothes after washing, the problem would be cause by a bearing seal leak. What happens is water leaks pass the seal into the bearings, and the grease leaks back into the wash water. To fix it would require the machine to be literally taken completely apart to get to the bearings. Very costly to repair. Sorry.
Aug 24, 2010 | GE WSXH208A Front Load Washer
Hi We Have a ge front load washer and dryer and it seems that our clothes smell musty at times. I've tried leaving the door open on the washer when not in use. Could there be another prooblem??
Try using vinegar, baking soda, or bleach in an empty load to counteract any residues left in onboard water. Also check for debris stuck in door baffle(rubber sleeve between door and tub).
Nov 17, 2009 | GE WSXH208A Front Load Washer
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
Ge front load washer model WSXH208A Will not spin
Mine kept stopping mid cycle also, pouring water on the floor, then the start/pause button flashed and the door unlocked. I found the solution to clean the lint filter on the GE Adora. Go to http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
I just did this and my washer is now running instead of the flashing start/pause and door unlocking. It was fairly easy. Make sure you have towels and a flat pan to catch the water if you don't have the machine on a riser. There may be water inside so a wet vac may be helpful too. Once my washer finishes what was in it, I have these funky towels to clean. You'll be very surprised what you find in the filter! Best of luck!
Oct 13, 2008 | GE WSXH208A Front Load Washer
Spin cycle not working
try the door switch the washer will do everything but spin if the door switch is faulty
Jul 13, 2008 | GE Profile WPSR3120WWW
GE FRONT LOAD WASHER
Plugged drain hose (which you can easily remove and clean) or slow running household drains.
The drain hose is the approx.2' diameter black hose on the back of the washer that is clamped to the washer and the other end goes into a standpipe or a wall drain. Be sure to turn off your washer and unplug it and have some old towels handy and maybe a bucket!
If there is nothing in the drain pipe, then I would suspect a plug somewhere else in your house that is preventing draining.
Thank you for using Fix Ya and for rating this solution.
May 21, 2008 | GE WPXH214A Front Load Washer
because the frontloaders are set up differently and use less water. The regular soap sudds to much and can cause a number of problems in front loaders.
which can be but not limmited to burned out pump, motor etc.
Mar 19, 2008 | GE WSXH208A Front Load Washer
GE front loader washer soap inside door
You can try using soap powders for 'front loading' machines......
Mar 03, 2008 | GE WSXH208A Front Load Washer
Amana Front Load Washer Soap Dispenser
I suggest you use soap powder for 'front loading washing machines'. The cartons at the market have them specially marked.
Feb 28, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
76 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
