Question about Proform Sport 1000 Folding Treadmill PFTL91205 - !
SPORT TREADMILL ERROR DISPLAY CAN YOU LIST FOR 1000 SERIES TREADMILL ERROR CODE 0
5 Suggested Answers
  • 18 Answers
SOURCE: i need a key to my pro sport 1000 treadmill, where
Refer to the user manual for contact details of manufacturer.The reatiker could have supplementary material for products traded. Contact retailer for alternative means to acquiring spare parts or imformation relating to issuies with your machine.
Posted on Dec 05, 2010
2manyhobbies
  • 128 Answers
SOURCE: Our Proform Sport 1000 treadmill
The incline operation and the walking belt operation are independent of each other. The walking belt should run regardless of the incline operation.
Although I have never had a problem with the gears in the incline motor being defective, you may need the motor replaced.. Try an incline calibration.
With the safety key in place, press start to start the machine. Press incline up. While the numbers are changing, remove the safety key. Release the incline up button. Reinstall the key, the machine should calibrate . After calibration, retry the operation normally.
Because the circumstances here are unusual, I would next disassemble the right upright and inspect the wiring harness for damage. During assembly, it is easy to pinch the harness (usually at the bottom of the upright), damaging the wiring to the console. The console may work, the the information may not get to the motor control PCB. The machine may have worked for a period of time before the damage became apparent, the flexing and movement of the frame eventually will eat through the wiring causing a number of unusual symptoms.
Posted on Dec 18, 2010
Robert Braun
  • 77 Answers
SOURCE: how hard is it to
When you order a new motor, you get complete instructions on how to install it. See Treadmill Parts
Posted on Dec 29, 2010
AJIN G
  • 6694 Answers
SOURCE: proform sports 1000 treadmill how to adjust the
HI,
Watch the following video to adjust the treadmill belt. All the treadmill's uses the same way.
Posted on Oct 10, 2011
What does treadmill error code E1 mean?
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Here's a link to more error codes:
Error Code List for Precor Fitness Equipment
May 26, 2014 | Precor Exercise & Fitness
Cyclone SX9 0 MAXPRO Treadmill
God bless you
Jun 03, 2013 | Exercise & Fitness
Error 0 problem
see the error +causes +remedy:God bless you
Description
Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and
EEPROM checksum during the power up test sequence. If a fault is found during the power up
test sequence, the appropriate error code will be displayed.
Possible Causes
1. These errors messages almost always indicate an upper PCA problem when they are
consistently displayed. Failures causing these error messages to be displayed are rare.
Possible Remedies
1. If the error message is consistently displayed when the unit is powered up, the upper PCA
should be replaced. It is possible to see one of these messages displayed intermittently due
the test could fail resulting in one of these messages being displayed. Treadmills operating
on non-dedicated A.C. circuits may see these messages displayed on an intermittent basis.2_4_2013_5_52_44_pm.gif
Feb 04, 2013 | Proform Sport 1000 Folding Treadmill...
Proform sports 1000 treadmill how to adjust the drive belt
HI,
Oct 09, 2011 | Proform Sport 1000 Folding Treadmill...
My exp 1000 sudenly stops , the counters reset to 0 all the lights are on but the control pannel is nonresponsive an error code 07 showed up once. Any ideas?
I don't have any suggestions for fixing it but I wanted to give you a resource should you need to purchase a new motor control board, you can choose your specific model and browse parts list here. Hopefully you can get it to work though, depending on the model it looks like a replacement can run you $100-$200.
Feb 21, 2011 | Nordic Track Nordictrack Exp 1000...
How hard is it to replace the motor on a proform sport 1000 treadmill?
Dec 28, 2010 | Proform Sport 1000 Folding Treadmill...
Landice treadmill 05 error code comes on when i hit start
LS Error on Landice L-Series Treadmills with Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. This error can occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring Corrective Action A) Speed sensor should sit parallel with the flywheel and gap between speed sensor and flywheel should be within 1/16". Adjust speed sensor if necessary.
B) Inspect speed sensor connector to relay board. Check for pushed pins or loose wires. Repair or replace speed sensor assembly if necessary.
C) Inspect upper harness or display cable connector to relay board. Check for pushed pins or loose wires, giving specific attention to pin 5 (brown) and pin 9 (green). Repair or replace display cable if necessary.
D) Inspect speed control wiring:
  1. Checking purple wire from V+ on pwm board to P3 on the relay board
  2. Checking orange wire from P1 on pwm board to P1 on the relay board
  3. Checking brown wire from P2 on pwm board to P2 on the relay board
  4. Confirm P3 on pmw board has no connection
Correct speed control wiring if necessary.
Details about LS Error on Landice Series Treadmills with Belt Movement
Jun 28, 2009 | Landice L8 LTD Pro Sport Trainer Treadmill
Proform Sport 1000 Folding Treadmill PFTL91205 - ! Logo
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
