Question about Epson WorkForce WF-2540 All-in-One Inkjet Printer
Some lines of print are missing as well as parts of lines so how do I correct that.
I have tried print head alignment and restoration to factory settings and tested it after each of those.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
Clean the print heads.
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_195f36f311cb10df
Posted on Dec 03, 2014
Testimonial: "Thanks Mike. I should have included the information in my first question about this. I did do the heads. Another clue that points outside of the printer is that it's on print responses generated from within the printer are perfect. Only those from the computer, even those that printed well a week ago have the faults. And the same document printed three times will have the same faults occur in the same lines."
SOURCE: Epson Photo RX620: Printing Pink Lines
None of these answers are accurate.  I know precisely what your problem is, and you aren't going to like what I have to say.  What you are experiencing will happen eventually to every Epson printer and there is nothing you can do about it other than to buy a new printer.  I have an Epson Stylus Photo 895 ( a 500 dollar printer in its day), which has the same issue.  I am just waiting for my ink cartridges to run out in order to buy a new one.
Endless research on google has turned up that there is no solution to this problem.  The issue you are having is with the Epson print head, which uses piezo technology.  What that means is that unlike HP or Canon printers which are thermal, piezo uses a small piezoelectrical cell to force ink out of the chamber.  It has advantages over thermal in that thermal requires a precise temperature to get ink on the page (what actually happens is that ink is heated, it forms a bubble, and the bubble bursts onto the page, hence the name BubbleJet).  Therefore, the ink has to have fairly precise thermal ink properties making it more expensive to manufacture.  Also, the ink on a BubbleJet (or HP) is wetter when it hits the page, and since the ink is heat resistant or order to properly form the bubble, the printer needs to incorporate a fast drying technology which consumes more energy.  The massive advantage of thermal is that the print head is on the cartridge, not on the printer itself; change your cartridges, get a brand new print head.  It makes cartridges more expensive, but reduces problems such as what you are experiencing.
Piezo on the other hand, always shoot ink through the same print head.  Once the head become damaged over time, the piezoelectric cell is no longer accurately pushing out the ink, and there is nothing you can do about it.  If you are lucky, it is only dried ink in the print head, but I can almost guarantee you that it is not.  Dried ink can be cleaned by repeated head cleanings, even manual ones involving rubbing alcohol.  However, I know that those pink lines are caused by the deterioration of the cell, and cannot be fixed.  If if were only dried ink, you wouldn't be limited to just pink lines on the page, you would see other colours.  If the cell is not doing its job, the lines are always pink (often called magenta when you google this problem).  The solution is to acquire a new print head.  Unfortunately, the cost of replacing an Epson print head is IDENTICAL to the cost of a new Epson printer.
So basically you have no choice, you need to buy a new printer.  Were I you, I would purchase a new thermal inkjet printer so that you get a new print head with every cartridge.  Look around before you buy to find out exactly how much the cartridges will cost, and then you will know which brand to buy.  Although piezo *can* make for a cheaper printer at the outset, Epson simply charged what HP and Canon do for their replacement cartridges because that is what people are used to paying, but you really do get more in a thermal inkjet catridge.
Sorry for the bad news,
DD.
Posted on Oct 25, 2007
night71
  • 328 Answers
SOURCE: Print Head Alignment
Get the driver here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14428&prodoid=9935&infoType=Downloads&platform=All
Posted on Oct 29, 2007
jaylex
  • 417 Answers
SOURCE: EPSON Stylus CX3810 thin white line in every printed line
Hi there the likely thing is that there is a small blockage in the print heads not allowing the jet to fire and causing a blank line. You could remove the print head turn it upside down using a soft cloth clean the print head also use a alcohol based fluid to aid you.
Try this if it's doesn't work then the print head will need replacing you will be able to buy online.
Thanks J
Posted on Jan 12, 2008
SOURCE: Lines on prints
Hi kids! I decided to have another go at sorting out my 'lines' problem and have sorted it. See if this might work for you: I had previously done the head cleaning via the printer itself - holding the central ink/paper black button for 3 secs. This time I went to the Epson 1290 window on my Mac and clicked on the utility box. Though the Nozzle check print came out fine I went ahead and did the head cleaning in this box. The next print came out almost perfect so I ran the Head cleaning again and it printed a perfect print. Hope this might work for you. Keep on trying! All the best. Trant
Posted on Mar 28, 2008
gwbm
  • 353 Answers
SOURCE: Black not printing about every 3rd line
You have the classic single nozzle failure it appears. You say you have done a nozzle check. This should reveal that one of the black nozzles is not working i.e. there is a single gap in your nozzle check printout for the black nozzles. Now, this may be due to a blocked nozzle. Try the following print head soak process.
Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. If still nothing, report back
Posted on Feb 01, 2009
After refiling ink, print is not getting corectly
Question is, was it printing correct before you refilled?
If not, the refill perhaps was not needed. Perhaps only cleaning the print head coulld have been enough. Print a head alignement page (just a little ink is used and only a few lines are printed) to check all the nozzles. When you see missing parts, you know you have to run one or a few cleaning cycles. When you don't use the printer often, please at least once a week switch it on and after a few minutes switch it of again. It will perform a cleaning cycle then, making the chanche of cloging minimal.
Apr 01, 2015 | HP PSC 1510 All-In-One InkJet Printer
THE EPSON STYLUS DX5050 MISSES LINES OUT WHEN COPYING, PRINTS SOME LINES PERFECTLY AND OTHERS PARTIALLY. WHAT IS THE PROBLEM?
You need to go to the Maintenance/Utilities menu and clean the print heads. Print a 'nozzle check,' and continue to clean the heads until the nozzle check print out looks like it should (no broken or missing lines. Once you're done with that (make sure you have extra ink on hand), go back to the utilities/maintenance menu, and print a 'head alignment' check. Adjust the head alignments, as necessary, and reprint. That should take care of your problem. Again, make sure you have extra ink, as you may run out, and then you can't finish the maintenance/cleaning. Good lick!
Oct 11, 2014 | Epson Office Equipment & Supplies
Missing lines of black print, parts of lines are missing
Go to printer properties, maintenance, and clean the print head. Then run the alignment tool. If that doesn't work, you probably have a faulty ink cartridge.
Jul 16, 2010 | Canon i860 InkJet Photo Printer
When I print tables, the lines come out crooked. Any idea what the problem could be?
do the print head alignment... to do this..first switch OFF the printer and then load paper, press the Pause button while switching ON the printer.. the printer will then print the instruction for you to align the print head. Just follow the instruction and select the best printed line.
If when you print text or line, and you notice there is some part missing, this show that you print head have broken pins. If this happen, you will have to replace the print head.
Jun 14, 2010 | Epson LQ 680 Matrix Printer
Printing is fuzzy.
try doing head alignment, this feature is located under the printer properties... goto Start, then Setting, then Printer and faxes, and point to the printer model, right click and select Properties... then select Maintenance and from there, you can clean head and head alignment... print the alignment sheet and select the best straight line.. that should help.
May 26, 2010 | Canon PIXMA MP470 All-in-One Printer
New ink cartridges installed and sometimes prints with missing horizontal areas(blank lines about 1/8 inch thick 20 plus randome down the page. The next time printing may be fine. Color is washed out...
Replace the print heads for the coloured inks you replaced, run the align printer head diagnotic from the printer menu. This should correct the print problem.
May 21, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
My sato cl408e is printing but 1/4 of the print on the inside of the label not readable. very dull and missing print. The other 3/4 of the print is perfect. Could this be a dirty print head or the...
It could be a print ehad problem, or an out of alignment condition between the platen and the head.
YOu can use a test mode to print a factory test print, that will put the print across the label. Settings and a barcode for alignment will be pirnted.
If you are using less than full width stock, only print 5 or less labels as the head will try to print across the full width, and if no label present, may harm printhead.
there are adjustments on the outside(right) of the platen support bearing that you can loosen the screw, and cam adjustment, to level the head across the platen.
Mar 02, 2010 | SATO CL408e Label Printer
Aligning print head doesn't fix the printing
You only need to clean the encoder strip. The plastic strip behind the carriage assembly. Wipe it gently with a damp Q-tip and the double lines will go away.
Jul 20, 2009 | Canon PIXMA MX310 All-In-One Printer
Red and blue lines across printouts
open printing preferences and click on maintenance. Run the print head alignment utility. Sometimes this will remove the horizontal banding. I had this same problem and had to uninstall the printer and reinstall just like it was new, running the alignment feature before it was corrected. Worked ok for a few days then started again. I assumed that the printhead is bad. To costly to repair and bought a new printer.
Jun 27, 2009 | Epson Office Equipment & Supplies
Canon i455 not printing properly
(i posted this for someone before)
When you remove the black cartridge there will be electrical contacts inside the printer that lines up with some contacts on your cartridge, make sure these are clean
Also, according to this printers manual, have you tried a printer head align?
"(1) Open the Printer Properties dialog box. See Opening the Printer Properties dialog box directly from the Start menu
(2) Click the Maintenance tab.
(3) Click Print Head Alignment.
Follow the instructions on the screen."
Oct 31, 2007 | Canon i455 InkJet Photo Printer
Epson WorkForce WF-2540 All-in-One Inkjet Printer Logo
191 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
