Question about Sewing Machines
The machine is letting the niddle go down but it want come back up how do I fix it
I've try the only things I know to do I've tryed to rethread and i've tryed the teachine
  • Sewing Machines Master
  • 1,860 Answers
You may need to have the machine checked to see if there is a part broken or maybe a adjustment is needed
Posted on Dec 03, 2014
SOURCE: The fabric keeps getting pulled
try these suggestions
1.make sure the needle is in the needle holder correctly
2.check to see if the needle is in backwards
3.make sure the thread is not slipping off the take-up lever
4.check to make sure the bobbin is not warped
5.check for lint in & around the bobbin case
6.check for loose thread in or around the bobbin case
Posted on Aug 01, 2010
SOURCE: I have a Singer 9117.
Hi, I have the very same problem with my 9117DV. Which I paid 300.00 for 2 years ago. It sews great when it works but for some reason it will bunch up and jam right in the middle of my sewing project.
I have the exact same machine in an older model and I have never had this problem.(which prompted me to get another).
The only solution I have to offer is take it to an authorized Singer dealer or sell in on eBay which is what I am doing!!!
Posted on Feb 15, 2011
  • 1788 Answers
SOURCE: I just bought a Brother
Call Brother at 1-877-276-8437 or take it back to where you bought it.
Posted on Apr 25, 2011
  • 20 Answers
SOURCE: Tension of pe770
Besides the other advice here, check your bobbin case. At first I didn't get my thread hooked into the bobbin case properly and had problems that looked like the bobbin tension was not adjusted properly. I have to take the case out, put in the bobbin to make sure it's caught properly and then put it back into the machine. This is what worked for me.
Posted on Dec 19, 2012
SOURCE: bobbin tension
adjust the top thread tension and see if that helps the bobbin tension
stitches.
here is a link for a free manual for the machine
http://www.singerco.com/uploads/download/545_7470-instruction-book-engfrespa.pdf
Posted on Mar 01, 2013
My Dreammaker VE 2200 is giving me message FO2 s/s sw on after needle broke. It will not do anything.
HAve a look through the manual (180 pages), it has a section (appendix) on troubleshooting. The manual is actually titled BP2100 but in the small print it also says VE2200 I hope it'sthe right one
Download manual
You could also try here Support Center for manuals and more personal support.
6.November.2015
Nov 06, 2015 | Brother Sewing Machines
Janome 3000 bobbin thread will not catch. It just quit while I was sewing. I've cleaned the bobbin case and anything else I could but when I put the needle down the thread does not circle the b
try changing the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not over wound
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin is not warped or damaged
if you've done all these things then it's also possible that the machine
is out of time & needs to be checked at a repair shop
Sep 01, 2012 | Janome Memory Craft 3000
I keep getting "check and rethread the upper thread" error message
Hi....I also kept getting the check and rethread upper thread message, I\'d sew about 15 stitches and it\'d stop. Here\'s what I did. On the left of the machine, in the back there is a screw....loosen that screw, take cover off, then lift straigt up and out on the cover that has the 3 on it in your threading seqence. Next, I started inspecting and cleaning the thread route from top to bottom. Lo and behold....I get to the place where you come down the front of the machine and turn to go back up and I spot a little slit in the plastic piece so, when I was threading the machine I guess I was pulling it to far to the left causing it to wear a little slit in that piece....so, I finished cutting it off with a utility knife, used an emery board to smooth it down, put the covers back on and it works GREAT!!!! Who would\'ve ever that it\'d be so easy and save me a bunch of money!!! I sure hope this helps someone.
Apr 23, 2012 | Brother SE350 Mechanical Sewing Machine
Tension of pe770
Mar 14, 2012 | Brother PE770 Computerized Sewing Machine
Blind Hem Stitch jamming
have you changed the needle lately?
have you tried rethreading the machine?
when was the last time it was serviced?
Feb 05, 2012 | Janome Sewing Machines
The bobbin thread is loops on top of the fabric even when the top thread is loosened to 2
if you've taking the machine in 4 times to be fixed,,sounds like you need a different sewing machine repair shop.
have you tried changing needles?
have you tried rethread the top & bobbin thread
is it possible the bobbin thread in not correctly inserted in the bobbin case?
try a top thread tension of 5 & see what happens?
Jan 20, 2012 | Brother Sewing Machines
I have a brand new 4423 that is frustrating me so much I'm tempted to return it and buy something else. It will not sew a seam without having "birdnesting" underneath. It's horrible!! ...
Take it back while its under warranty and ask the dealer to thread up and sew on it; this way you can establish if it is a faulty machine or if its some other variable causing it. Certainly if you are an experienced sewer and have used other Singers, then you would know if you've done it correctly and your instincts tell you the machine is faulty so I'd suggest you take it back to the store.
Oct 03, 2011 | Singer 4423 Sewing Machine
My bobbin keeps bunching up. I've changed the tension to 2, taken the bobbin case out, used a different bobbin....I don't know what to do. My machine is a month old and I've used it, maybe 4...
Put the tension back up to about 5. Rethread the machine entirely, and make sure you have the pressure foot in the up position when you rethread. If your getting bunching on the bottom, it's probably your top thread that's bunching up. After you rethread, put a small piece of fabric under the pressure foot, lower the pressure foot, and turn the handwheel in the forward direction and watch the thread as it comes around the bobbin case. If it goes around smoothly, try it with the foot control. If it hangs up as it goes around the bobbin case, you might have a burr on the black plastic bobbin case. Take it out, check for any burrs, sand them down, and try again.
May 07, 2011 | Brother SE350 Mechanical Sewing Machine
Singer futura CE-100 4 blinking reds lights
This error indictaes that the upper thread is broken. If it is not the sensor is telling the computer the thread is broken. Try tightening the upper thread tension some and rethread the upper thread.
Dec 23, 2007 | Singer CE-100 Futura Computerized Sewing...
Sewing Machines Logo
20 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
