Question about Westinghouse 22" LED 1080p HDTV
Show me a diagram of Westinghouse 22 flat screen 1080p tv
    Top Expert:
  • Westinghouse Master
  • 74,198 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 03, 2014
SOURCE: Westinghouse 1080P 42" LCD TV - HDMI stopped working
Just reset the TV found out how here: http://www.danielcoburn.com/uncategorized/westinghouse-1080p-42-lcd-tv-hdmi-stopped-working-fix/
Hold the power button for 10 seconds.
Posted on Jul 26, 2009
  • 8457 Answers
SOURCE: Westinghouse 32" TV NO Singal rabbit ears
Buy a digital antena,or a roof antena set it up plug it in,the in hole said Input or Ant..Go to the menu select where said Cable or Air.Select Air for free Air Tv.Scan for channels.
Posted on Sep 12, 2009
dave1645
  • 834 Answers
SOURCE: Westinghouse flat screen shuts off 3-4 time after
you have a leaky cap in the power board the can like device will have a puffed up top and the value is on the side replace it or them and your good to go
Posted on Nov 19, 2009
westytech
  • 120 Answers
SOURCE: 32" flat screen Westinghouse TV
Hello, it sounds like you need to replace the inverter board on this unit. I would recommend opening the unit from the back cover, get the part # for the inverter board (long green board normally running accross the edge of the TV) and go to www.shopjimmy.com, they should have it in stock and if not you can try www.invertercentral.com, they should also have it.
Posted on Feb 04, 2010
  • 8457 Answers
SOURCE: IHave a 32 inch flat screen Westinghouse TV that c...
Ur tv the LCD inverter board it dead.The LCD inverter is the board that help the LCD screen panel to get a backlight to produce a picture,the LCD inverter board is dead and it not working anymore that why u only get 8 sec.of the picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Posted on May 23, 2010
HOW CAN I FIX MY WESTINGHOUSE 22 INCH LED TV? IT HAS HORIZONTAL LINES COMING UP FROM THE BOTTOM 1/3 THE WAY AFTER IT HAS BEEN ON FOR 10 OR MORE HOURS.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 13, 2017 | Westinghouse Televison & Video
LD-2240 problem while trying to set up monitor all I get is no signal to any menu
Search Results
    Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240
    www.amazon.com/...1080p...LD2240/.../B007ATHRJ...
    Amazon.com, Inc.
    Rating: 2.9 - ‎21 reviews
    Amazon.com: Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240: Electronics. ...When I set it up I was disappointed with the sound but not surprised, it is a cheap TV... Apparently this is not an unusual problem for Westinghouse. ... Oh well, I tried. ...VideoSecu Articulating Arm TV LCD Monitor Wall Mount, Full Motion Tilt ...
    Amazon.com, Inc.Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240 ... When I first hooked it up to my cable connection, through the coax connector (TV ... When using as a computer screenthere's an auto adjust and full manual control .... have endured compromised sound and picture, but I've never had this problem. .... Oh well, I tried.
Jan 11, 2016 | Westinghouse 22" Class LED 1080p 60Hz HDTV...
How to reset westinghouse tv
Press menu key. With menu showing press 0 four times. A new menu should appear with factort reset as an option.
Dec 05, 2013 | Westinghouse Digital Westinghouse 39 LCD...
Need code for westighouse ld2240 serial 6616121805787
Just guessing you want to control your Westinghouse TV with some kind of remote, perhaps a programmable one. The codes are sent from the remote to the TV, therefore we need to know what brand of remote you want to use
Jan 17, 2013 | Westinghouse NEW 22" Class / LED / 1080p /...
22" flatscreen LCD Westinghouse TV.
try use a lowest resollucion 720p and after change to 1080
Sep 20, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
I have a 22" Westinghouse
Change the settings on your HDMI output to 720 progressive for resolution. The tv likely cannot handle the 1080 resolution, or the tv can only use interlaced (1080i or 720i) format.
Aug 21, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
My ps3 wont show up on my tv screen it is a 42 inch plasma it will not show up it keeps saying invailed format what do i do?
Your 22 monitor is set up (most likely) with a max resolution on 1650x1050 and you ps3 stays set to that even when you use it on your dads 1080p TV (1920x1080) and since your 22 in monitor is a non-standard resolution (in the TV world that is ) ie 720p = 1280x720 and 1080p = 1920x1080 it has to adjust to the closest resolution (your ps3) but sometimes the auto switching of resolutions doesn't work like it should..it just doesn't work sometimes. I suggest that when you take it to your dads you adjust the resolution to 720p ahead of time (a resolution both the 22 monitor and tv should be able to handle ) and when you get to his house it should work at least enough to see everything and then when already there you can adjust up to the higher 1080p (1920x1080). Then adjust back to 720p before you go home again. Sorry for the long winded post.
Here is a link to resolutions explained in case it helps.
http://en.wikipedia.org/wiki/File:Vector_Video_Standards2.svg
Mar 05, 2011 | LG 42LC2D 42 in. LCD HDTV
Westinghouse 22" LED 1080p HDTV Logo
32 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
