Question about Toshiba 50HM66 52" Television
Is my color wheel need replaced?
I recently replaced the lamp on my TV and it seemed to have great picture, for an hour or so. The screen began to flicker from light to dark and adjusting the lamp brightness help for a day or so and also the color is green and purple. I have managed to get to the color wheel and besides being dusty, it doesn't spin for long without stopping. Is this shot bearings and if so, how do I pull that little wheel out? Is it just the 2 screws holding down the assembly its attached too that holds it in?
    Master:
  • Toshiba Master
  • 687 Answers
The bearings of the color wheel could be worn. the screws hold it in place, & there is a plug-in wire connected to it.
for part# contact: http://support.toshiba.com/
Posted on Jan 03, 2015
4 Suggested Answers
SOURCE: DLP Light Engine out and going on 3rd Lamp
http://www.fixya.com/support/t251039-46_toshiba_dlp_projection_picture
Posted on Jan 27, 2009
SOURCE: The picture on my 2
I hope this helps you but you might wanna look into some other posts too cause it goes farther then the lamps and color wheels. Basically it's a bad product and the consumer should be fixing it. But your problem seems to be the color wheel. Or just a good cleaning. We replaced the lamb in ours and still had a color problem. We're gonna do an exstensive cleaning and dusting of our unit and if it don't work. We're going straight to the manufactor. This is enough with this product! It's costly to repair and still don't have the quality picture it should. It's more then a simple fix and too costly for ppl to just fix and move on. For how old these products are this all should not be happening.
Posted on Dec 09, 2008
SOURCE: Picture seems to be quite dark when watching
Turn ALS off. IT is in the same menu as brightness.
Posted on Feb 05, 2010
What would effect the picture quality the color wheel or lamp?
The color wheel is your suspect.......usually whines a bit
when bad. In a quiet room, you can hear it when the TV is powered on or off. It spins at 9,000 rpm ( wears out the bearing).
The lamp will not exhibit those symptoms....
Apr 26, 2014 | Televison & Video
Samsung hls5086wx/xaa turns off at random
Go to website Encompass Electronics.com type in your model number it will list part and part number ,you can also look for Lamp on E-Bay Encompass 1-800-638-3328 Also ck Color Wheel remove lamp take a flash light to watch when you turn TV on see if the color wheel is turning if it is defective set will shut OFF. But most likely its your Lamp.
Oct 05, 2009 | Televison & Video
Loud buzzing noise which became a very loud screech over the last week. Turning tv off and on seemed to remedy it. Today screen was only black and white, now no video only audio. Is this the picture...
This TV uses a lamp and color wheel. the color wheel is likely the problem since it is known to make noise over time and will eventually sieze. The repair is in the $400 range.
Sep 27, 2009 | GE 46GW945 46" Rear Projection Television
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
DLP TV starts to loose picture after 1 - 1/2 hours of use
This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. see which inputs have the problem to narrow it down. if only some inputs, suspect analog board. if everything flickers(all inputs and menu), suspect the dmd or engine. you can see the lamp shine out the back. if the lamp is flickering, suspect lamp or ballast.
Nov 22, 2008 | Samsung HLN5065W 50" Rear Projection...
DLP TV noise and picture
This is not with the problem of lamp.
Your light engines COLOR wheel is damaged.
Replace Color Wheel.
Good Luck
Dont forget to Rate!!
Dals123
Nov 05, 2008 | Televison & Video
Color fades out on tv
I have the same tv and the same problem (color banding, incorrect colors, colors blinking) occured after I replaced the lamp. I had a tv repairman take a look at my unit and he said the color index was incorrect, the tv doesn't know the correct colors to display. The best way to fix that problem is to replace the "light engine". The repairman replaced the "light engine" to my tv and everything is working great. My tv was still until warrenty so I don't know how much a new "light engine" would have cost.
Jul 27, 2008 | Mitsubishi WD-73732 73" Television
Samsung DLP HL-S5087W 56" Confused...
Mine did that when the color wheel didn't spin up...just give it a whack where you installed the light & the wheel should spin up. I had to replace my color wheel as the bearing was shot & was buzzing all the time. The light won't come on if the wheel doesn't spin up first.
May 08, 2008 | Samsung DLP HL-P5663W 56" TV
Motorized sound and picture quality poor and jumpy
your husband is correct it is most likely your color wheel very common and it will effect the picture. what will happen soon is your tv will not turn on. The cost is two possiablities. color wheel replacement 225,00 part is 80,00 complete light engine in rear cases cost is 650.00 dollars . I hope this helps
thanks doctor video leadingedgeeletronics since 1987
May 04, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Toshiba 50HM66 52" Television Logo
73 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
