Question about Frigidaire Heating & Cooling
I need to get a remote sensing switch for my Frigidaire 12000 BTU AC. I broke it while cleaning the filters. The model of the AC is FSC12CM6A. The part number is CE-KF32GW/iiY(S)
I need help in locating the part described above. I broke it while I was cleaning the unit. My Ladder came in contact with this art and it broke. Help Robin
  • 1,511 Answers
You would be better off going on line to the manufacturers web site. Seek Support and download the required documentation.
Posted on Dec 10, 2014
SOURCE: Frigidaire 12000 BTU A/C window unit
The reason that it's doing that is b/c at first its running only with the fan butwhen the compressor clicks on it trips the breaker if you have other items running off that circuit "unplug them" [even turned off items can still consume some power]. Then try to running only the ac unit see if it works a 12000btu takes a lot to run, if this doesn't work the ac may be to much for your circuit to handle and a smaller unit may be needed.
Posted on Jul 17, 2009
  • 45 Answers
SOURCE: frigidaire fac127p1a 12000 btu compressor
The compressor is probably going out on either a pressure related or heat related overload. Both are a result of low refrigerant. There may be a low pressure safety swich that protects the compressor. Otherwise it may be an internal thermal overload that is tripping. It resets itself and comes back on. The thermal overload heats up and shuts off the compressor to protect it from too much heat which is gernerated by not enough refrigerant in the system to keep the compressor cool. It may be cheaper to replace the unit than have someone try and fix it. It is pretty time consuming and you cannot try it yourself unless you have an EPA Certificate to buy the refrigerant. Check with your local appliance repair man to see if he will tackle it.
Posted on Jun 05, 2010
icemelts
  • 246 Answers
SOURCE: Celiera 12000 btu Mini-split ac unit blows cool
It's 'possible' but not likely that you need additional freon.
What is more likely is the 'filter' (for inside coil) is dirty and possibly the coil itself - and/or - the outside coil is dirty.
I would check out the filter - if dirty - I would change it and would also inspect the inside coil. If it's also dirty I would clean it the best I could (with a brush of some sort).
I would also check the outside coil and clean it if need be.
Hope this helps.
Posted on Jun 11, 2010
shastalaker7
  • 1515 Answers
SOURCE: I have an Intertherm split
Hi, the schematic would be in the indoor unit, but I am assuming its gone since you are looking for the ladder schematic for the heat strips and fan control. You might try this number for a schematic, 1-888-441-6942, Route A/C and they may be able to help you on this diagram. The number you are showing does not look like any model number at all. For both the indoor and outdoor units on the Intertherm, would look something like this...., P3RA-024k for the model number, and the serial number would be right below it. Both should be very easy for you to locate. It is very hard to find schematics for units once they are gone, as some tech's like to take them off units to go home and try and study them!!, unreal! Makes it hard to troubleshoot when you need it. Try to find numbers like I have noted, and call this number as they will answer questions you may have concerning yours. I hope the best for you and would like for you to rate me, as I know you will be kind. Please keep me posted on this as maybe I can help you solve this fan relay problem you have?
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Sep 18, 2010
Testimonial: "Thank you for assistance I will call maybe have some luck"
SOURCE: indoor a/c remote control will not work. How do I manually
If you lift the filter cover, on the right you will see a wiring diagram. Above the diagram and to the left , you will see a small hole that is about a fourth of an inch in diameter with a rod in the middle. Touch the rod and the unit will come on AUTO. Touch it again and the fan will reduce speed. One more time and it will go off.
Posted on Jul 13, 2011
I need to buy the compressor card for sankey air conditioner split model 12inv31
Most local home improvement stores do not carry AC components. I would try 1-800-269-2609 or google places in your area that sell AC parts. It could also be that it needs a cleaning. Can you provide any other details? I hope I can help.
Jul 28, 2016 | Heating & Cooling
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
How to know the tons of old ac unit from the model no?
36 is equal to 36000 btu. To find the ton divide by 12000 btu. 12000 BTU is a ton of refrigeration. This is a 3 ton unit.
Jun 17, 2014 | Weather King 10AJA6001AH Air Conditioner
Idylis 12000 btu manual
Find more information on this link:
http://pdf.lowes.com/useandcareguides/840206110031_use.pdf
Jul 13, 2013 | Heating & Cooling
Remote control
buy a cheap universal remote for ac will do.
Jun 03, 2013 | Norpole 12000 BTU Window Air Conditioner...
What extension cord should i use on window ac unit model number ASW12ALS1 12000 btu
http://www.appliancefactoryparts.com/search/part/1042383/116404 this is a link formthe extension cord you need.
Jun 20, 2012 | GE 12000 Btu Room Air Conditioner EnerStar...
Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Jul 21, 2010 | Frigidaire FAH106N1 Wall/Window Air...
Indoor a/c remote control will not work. How do I manually
Feb 05, 2010 | Heating & Cooling
Aug 06, 2008 | Frigidaire FAA065M7A Air Conditioner
Heating & Cooling Logo
46 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
