Question about Kidde Firex Smoke Alarm Model I12060 - In Box
Installed fresh battery in my Kidde smoke detector Model i12060A and after about 9 hours it started to beep . Disconnected it from power source and removed battery to silence it. Please advise how to
Installed fresh battery in my Kidde smoke detector Model i12060A and after about 9 hours it started to beep . Disconnected it from power source and removed battery to silence it. Please advise how to fix.
  • Jpopus Apr 30, 2017
    A lot late on this one but if a new battery was installed and same problem then the detector is bad. Even if it is fairly new.
    Scholar:
    New Friend:
  • 93 Answers
Two things I would suggest: 1. make certain the battery you are using is good; consider using 9V lithium instead of alkaline as they will likely last much longer and perform better 2. ensure you are following all of the instructions for battery replacement correctly; many smoke alarms and detectors have labels on the back with replacement instructions that specify leaving the old battery out for a minimum length of time, anywhere from about 10 to 60 sec; failure to follow this will often result in erroneous low battery indications. Of course, if the unit is over 10 years old, it must be replaced per NFPA72, the national fire code.
Posted on Mar 27, 2015
  • 4 Answers
SOURCE: my kidde smoke and carbon monoxide alarm keeps
You will need to remove the unit from the ceiling to reveal the battery compartment on the back. It should just need to be rotated counter clockwise a small amount and will then come loose from the bracket. When installing a new battey be sure to press the battery reminder finger down into the battery compartment or the battery door will not close. Call the Kidde (pronounced kid-a) hotline if you have problems 1.800.880.6788
Posted on Aug 05, 2009
  • 34 Answers
SOURCE: smoke detector won't stop chirping.
it may need to be cleaned or it is bad may need to be replaced
Posted on Oct 25, 2009
Divalici0us
SOURCE: My alarm and smoke detector keeps beeping a single
Ours keeps chirping even after we replaced the battery. I'm not sure how to fix it.
We are going to try and clean it but if it keeps doing it after that then I guess it means it needs to be replaced, right?
Posted on Jan 20, 2010
  • 13 Answers
SOURCE: kidde smoke alarm won't stop chirping
Most smoke detecotrs have a limited lifespan of 5-10 years. On the underside of the detectors should be a sticker with installed dated or replace by date. If changing the batteries doesn't stop the chirping it is most like time to replace the detector. If you check the manufacturer website they will give you a life expectancy for your detector.
Posted on Mar 23, 2010
  • 13 Answers
SOURCE: I just fixed a new Kidde alarm hardwired with both
The normal condition for the green LED is solid. A flashing green LED indicates memory of a prior alarm condition. Press the test for at least 2 seconds to reset the detector memory.
In new 3-alarm system just installed by electrician the alarms issue 3 long beeps and "FIRE" about every 10 minutes. Kidde is not available to help. Can you?
I think it could be one of three things.
The electrician may not have installed the back-up batteries.
The electrician may not have turned the primary power to the detector circuit on when he completed the work and now the battery is depleted.
The electrician may have tied the the detectors into a switched circuit which does not apply constant primary voltage.
Hopefully you can contact the installer to troubleshoot his work.
Feb 13, 2016 | Kidde i12040 Hardwire Smoke Alarm with...
How do I stop the beeping of smoke detector after battery has been replaced?
How old is it? It may be telling you that it's no longer reliable and must be replaced.
Sep 30, 2014 | Kidde 4618 Firex Hardwire Ionization Smoke...
Had customer with CO detector sounding quick double chirp about every five minutes. What is this?
This is not a beeping smoke detector. It is probably a CO detector that was installed by your alarm company. GE model 240-COE will give a double beep every 5.5 minutes when the device reaches end of life. Call your alarm company to have it replaced.
Jun 07, 2014 | Kidde DC Voice-Alert CO and Smoke Alarm
Our hard wire smoke detector model i12060 just beeped really lound a few times and stopped, it glows green and flashes red every few minutes?
Change the 9V backup battery,with a new one.Push and hold the reset button for a minute or two for the alarm to to go off like about 30-40 sec. for the smoke detector to dectected the 9V backup battery power sourced.The green power LED light indicator will stop flashing also the beeping sounds too.
Jul 12, 2011 | Kidde 120-Volt Front Load Battery Smoke...
One beep constantly on smoke and CO unit. says battery low but the system is wired into house panel. Help!
Most new smoke detectors work off of two power sources, electric and battery backup. The battery is used to power the detector if primary electrical AC power is lost. It would be a good idea to replace all detector batteries every two years or so. You'll access the battery by opening the unit, find out the type used and then purchase a replacement at your local store. Hope this helps.
Apr 15, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Home security alarm keeps beeping
Most wired-in smoke detectors work off of two sources of power, electric and battery. If the beeping occurs every 30 seconds or so it most likely means you need to replace the battery in the detector. On the other hand if by beeping you mean the alarm is going off, I would first try cleaning the unit with your vacuum. If that doesn't solve the problem then the next step would be to replace the unit. Hope this helps.
Apr 08, 2010 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Kiddie fire alarm model I12060, beeps once every
This happened to me, my smoke detector started chipping so I changed the batteries. A few seconds later it started chirping again. The answer is in the way you put the batteries in. The smoke detector allows you to put the batteries in wrong and makes a slight connector. This slight connector tricks the detector into thinking the batteries are weak. Simply turn the batteries around so the fat connector of the battery touches the skinny connector of the device. Mine was, fat side on the right.
Jan 28, 2010 | Kidde i12040 Hardwire Smoke Alarm with...
Kidde Firex Smoke Alarm Model  I12060 - In Box Logo
1,089 people viewed this question
Top Kidde Home Experts
Tre Elkins
 Mikey
Mikey
Are you a Kidde Home Expert? Answer questions, earn points and help others
