Question about Lifespan Exercise & Fitness
How do I stop my treadmill from interfering with my Directv signal?
When ever the belt is running on the treadmill the tv signal on the directive is interrupted, the tv freezes up and no signal is received from directive. when the belt is stopped, the tv signal returns??
SOURCE: Treadmill stops running
I had simillar problem. I have proform 830 QT. My trademill stops after 10 minutes of work out. Everything shuts down and the circuit breaker pops out.
Root cause:- no lubrication under walking belt. Caused the moter to over work (over heat) and hence te circuit breaker popped out to prevent blowing of motor.
Solution:- Apply the lubricant under walking belt and adjust the belt tension if needed.
Back ground:- Contact proform customer service at 1-888-533-1333 (http://www.iconservice.com/proform/faq_tread.html) and buy the treadmil cleaning kit or lubricant kit which comes with a wand for easy application. It may cost you 35 dollars including shipping. If you need to fix your treadmil right away, use NAPA silicon spray 8300. Proform actually tells do not use it as it may damage your belt. However the specialst who came to fix my treadmill just sprayed it and collected 100 dollars. When I called proform they told me lubricating will fix it and its my mistake to not trust them. I guess they knew exactly what they were saying.
Posted on Jan 03, 2009
  • 95 Answers
SOURCE: Treadmil stops or slows down upon walking.
Check both belts to be sure they are adjusted and not slipping.Check the underside of the walk belt to see if it feels frayed in the center as compared to the edges, the center always wears more than the edges a really worn belt must be replaced. if it is nor worn there is a wax lubricant for proform treadmills that can be purchased at retail stores that sell treadmills.Sears, dicks sporting goods and also treadmilldoctor.com are good places to buy it.
Posted on Aug 01, 2009
SOURCE: The belt on my ProForm Crosstrainer treadmill stops while using i
Sometimes the tread needs to be lubricated. This was the case with ours. You can get a lubrication kit at ****'s Sporting Goods or other larger sport stores and it will instruct you on how to do it.
Posted on Jan 26, 2010
SOURCE: treadmill belt runs very slow and stops when I get on
proform 625 belt slips cause
Posted on Jan 28, 2010
  • 16 Answers
SOURCE: belt stops running while standing on the treadmill
Either front roller may need to be replaced or the motor drive belt may need to be adjusted. This problems are caused when a walking belt is worn out and in need of replacement. Too much tension can cause bearing failure in the motor and the front roller and front roller pulley failure.
Motor drive belt adjustment: The motor drive belt is adjusted independently from the walking belt. Some newer models have an auto tensioner which is a lever that has a wheel that puts pressure on the drive belt and a spring on the other end that automatically loads the belt to the proper tension. You should not adjust these since they are preset. Tension can be affected slightly by adjusting the tension of the walking belt but if you have a slipping problem, the drive belt will require replacement. If your drive belt is too loose, it will slip on the front roller pulley or the motor pulley. If it is too tight, it will increase your amp draw to the point that you may have an electronics or motor problem. Due to this, it is better to be on the safe side and replace a drive belt rather than risk over tightening it.
Posted on Feb 20, 2010
My preform treadmill isn't starting, how do I fix this problem?
If it tries to run for a second or two and stops it will probably be the speed sensor. It is a small magnetic switch that is activated by a magnet on a flywheel that drives the belt. The control board looks for this signal to set the speed of the belt, without the signal the belt will stop. A competent DIYer could probably find and fix it but make sure the machine is unplugged from the wall before attempting any work.
Oct 05, 2014 | Proform Nordic Track Treadmill Pro Form...
Why does it say loss of speed signal
As you have not provided the make and model of the treadmill I can only suggest the cause is usually a loss of signal from the motor drive to the display unit.
To fully diagnose the problem I will refer you to page 24 of this service manual for a treadmill that explains the problem.
Not sure if your treadmill is similar. http://www.landice.com/sites/default/files/L-60_L8622SeriesDiagnosticAddendum.pdf
Aug 19, 2014 | Exercise & Fitness
The belt is slipping
This is a common issue. Over time the belt stretches. You will need to adjust the tension on the running belt to alleviate this issue. If there is no adjustment room left, then you will need to replace your running belt and deck surface. The link below will take you to the products for your machine. Please use your serial number to narrow down your choices.
Precor Repair Parts for 9 27 Treadmills Consumer SPORTSMITH net
Jan 04, 2014 | Precor 9.27 Treadmill
I get an error message E1 on my Athlon model Simplicity treadmill. Belt stops. Any ideas on what this means?
Step 1:
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Clean the s.speed , test for open or faulty-see the diagram for adjust. tight the connector very well.
God bless you
Step 2:
Feb 08, 2013 | Exercise & Fitness
I currently replaced the walking belt on my C954i/C956i treadmill. When I plugged it back in and turned on the power, the treadmill has no power. What could have happened?
Dear Sir:
I can read you trouble, and follow the next steps:
ALIGNING AND ADJUSTING THE RUNNING BELT
The correct alignment of the running belt is critical to the smooth operation of the treadmill. The belt is properly aligned at the factory. However, during shipping and handling or by use on an uneven surface, the belt may move off center and require a few simple adjustments. Before aligning the running belt, check its operation by following the procedure in Checking the Alignment of the Running Belt. If you determine that the belt needs alignment, follow the instructions here. CAUTION: Special care must be taken when aligning the running belt. Turn OFF the treadmill while adjusting or working near the rear roller. Remove any loose clothing and tie back your hair. Be very careful to keep your finger or any other object clear of the belt and rollers, especially in front of the roller and behind the deck. The treadmill will not stop immediately if an object becomes caught in the belt or rollers. Realigning the belt takes a few simple adjustments. If you are unsure about this procedure, call Precor Customer Support (see Obtaining Service.) Take the following steps to align the running belt on the treadmill. To ensure your safety, make all adjustments while the treadmill is OFF. 1. Make sure the treadmill is OFF and the running belt has completely stopped. 2. Locate the right belt adjustment bolt in the rear end cap of the treadmill. (To determine left and right, stand at the rear of the treadmill and face the display.) See Diagram 24. The direction you turn the bolt depends on how the belt is tracking. Make all belt adjustments on the right rear corner bolt using the hex key provided. • If the belt is off center to the RIGHT, turn the adjusting bolt ¼ turn clockwise, which moves the running belt to the left. • If the belt tracks off center to the LEFT, turn the bolt ¼ turn counterclockwise; this moves the belt to the right. Important: Do not turn the adjusting bolt more than ¼ turn at a time. Overtightening the bolt can damage the treadmill. 3. Turn the unit ON. 4. Stand beside the treadmill and press QUICKSTART. 5. If you are prompted for a password, press INCLINE ??¼, SPEED ??¼, SPEED ??². The running belt starts automatically after the 3-second countdown appears on the display. 6. Press the SPEED ??² key until the display shows a speed of 3 mph (5 kph). 7. Walk around to the rear of the unit and observe the running belt for a few minutes. The belt should run centered along the running bed. If the belt drifts off center, you will need to make adjustments. CAUTION: If you hear any chafing or the running belt appears to be getting damaged, stop the running belt immediately by pressing the red STOP button. Contact Precor Customer Support. 8. If the belt needs additional alignment, repeat steps 1 through 7 until the belt is properly aligned. 9. After aligning the belt, press the STOP button and RESET. Turn OFF the treadmill. Tighten any loose fasteners or other components on the equipment. If you hear unusual noises or you feel that the treadmill is in need of repair or service, contact Precor Customer Support. Refer to Obtaining Service.
Finally, check if the power cord is loose, connect it again. a) See if the breaker of Home is tripped? b) See if the breaker of the Treadmill is tripped. If do the Belt is very Tighted! loose a little. Try again.
Thank you in advance, if you need assistance, you can contact me, Blessing. sincerely.
E. CUADRA Managua, Nicaragua. C.A.
Sep 26, 2011 | Precor C954i Commercial Treadmill
The TV is not picking up signals from Directv remote or the tv remote. Can only turn tv on and adjust volume from console not remote as usual
Tries turn the Direct tv decoder box off/on button,or unplug and replug, so the software can run it upgrade.Take out the signal input as a HDMI or cable connect direct to the antena port in the tv. Check for wear and tear and reconnect,change all batteries in the remotes.That should get u up and running,not than u have electronics componnent defective somwhere.
Sep 26, 2009 | Vizio L32 32 in. LCD HDTV
No digital signal
You don't have anything to worry about. I have Directv too.
Just leave everything normal. The Directv box does all the work and puts the programs on the TV. The Directv System is not affected by the DTV Deadline.
Here's info from Directv web site on the subject.
http://www.directv.com/DTVAPP/global/contentPageNR.jsp?assetId=3460059
Jun 12, 2009 | iLO 3200 32 in. LCD Television
Direct tv passwords
call directv and ask them to send a signal to reset the lock. they will only do it if your are the account holder
Jan 02, 2009 | RCA DIRECTV Satellite Remote Control
Need owner's manual for ifit.com treadmill
1. When walking on the treadmill the belt abruptly stops.
2. As the speed increases so does the noise. Is this associated with the belt tension? Tightening the belt causes the belt not to move at all. What might be the solution to 1 & 2?
Dec 12, 2008 | Exercise & Fitness
Off Air?
The Scientific Atlanta box was a cable box and recieved CATV signals. The Direct TV box is satellite only. You might check if it has a built in ATSC tuner for off air digital signals. Direct TV in most locations offers the major networks in HD format.
Jan 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Exercise & Fitness Logo
129 people viewed this question
Top Lifespan Exercise & Fitness Experts
Shehu Pro
Shehu Pro
Mike
Mike
Electro Med Services...
Are you a Lifespan Exercise and Fitnes Expert? Answer questions, earn points and help others
