Question about Hoover Washing Machines
I have a hoover DYC8913B, its under 2 years old but I have moved to New Zealand so im assuming the guarantee won't be here. When we arrived it is working ok but not filling up the condenser in the door, the light for 'empty the condenser' came on, when I took the filter out the bottom all the water was sank at the back at the bottom and when I tipped it back more came out, so it was sitting right at the bottom of the machine. I checked the hose at the bottom but that's all intacked, but I can't see the other end of the hose which goes towards the back. Does anyone have any idea what the problem is or how I take apart the machine to find out?
  • 1462 Answers
SOURCE: Intermittent hot water valve not opening
problem may be low water pressure. try putting in a y-piece so cold water is supplied to both valves. only effect will be that wash cycle will be a bit longer
Posted on Mar 31, 2007
BIKER T
  • 909 Answers
SOURCE: AEG Lavamat W1450 2 years old,
possibly wire come loose or try disconnecting heater element and repeat spin cycle.if runs well then, replace heater.
Posted on Oct 24, 2007
murdozzz2
  • 75 Answers
SOURCE: washing machine wont empty
hi there this is a common fault empty the water into a bucket and remove the water pump to check for blockages, the pump is located at the rerar lefthand side of the w/m.
also check your drain hose where it connects under your sink.
hope this helps
Posted on Dec 11, 2007
buzzwood
  • 65 Answers
SOURCE: INGLIS WASHING MACHINE - WATER STOP
Either call the store where you purchased the machine or refer to your users manual, should have a trouble shooting guide in the back of the manual.
Posted on Jan 05, 2009
  • 41 Answers
SOURCE: hoover 600mb doesn't spin
Valve blocked in rear of drum. Switch off power supply before cleaning. If the problem still occurs it could possibly be the brushes in the motor. both jobs are simple and very cheap to repair
Posted on Sep 03, 2009
Could you tell me where the thermal limiter is situated in a DYC8913B please
Ian, Did not find your particular model, links below may help in changing and testing your thermostat.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Condenser Dryer Model No DYC 8913B Product Code 31100391
Hoover DYC8913B 80 Thermal Limiter
Dryer Isnt Heating High Limit Thermostat Testing Dryer Troubleshooting...
How to replace thermostat on tumble dryer how to diagnose the fault
Apr 24, 2016 | Hoover Dryers
Hoover dyc8913b works fine for a while then starts squealing for around 5 mins then fine again for a whileand so on. Can anyone give advice on how to stop this. Thanks
My guess is something is lodged in there causing the sound or perhaps the belt is dry and cracked and needs replacement.
Jul 14, 2014 | Hoover Vacuums
Hoover softwave not doing anything except clicking
It sounds like the rotating program controller has failed. It is telling other parts of the machine to do things as part of the wash cycle and the signal is not reaching them. This is an expensive part to replace. Get it fixed under guarantee if its new. If its old replace it, but do not buy a Hoover, they are very cheaply made and fail a lot. If you want a cheap one buy a Zanussi.
Dec 20, 2013 | Hoover HC6 110M Front Load Washer
Hoover 1400 door won't close
I would call hoover a service number should be located by the serial number or possibly on the door
Sep 04, 2012 | Washing Machines
Brushes won"t spin, Model F7452-900
SAME PROBLEM Hoover F7452 900 brushes won't spin; cleaned and move freely, under filter slid out and cleaned, still froze up....had it a little more than a year so probably no warranty.....assuming turbine related and will take it to dealer......how common is this problem with this model???
Jun 15, 2009 | Hoover F7431-900 SteamVac Vacuum
How do I put a new belt on Hoover Concept One vaccume cleaner?
you most likely have to remove the cover over the roller, which has screws usually. then you will see the belt. the roller slips out replace the belt by putting it over the roller and a metal rod that is up under the cover you removed. this will be a hard job putting the roller bar back in the vacuum because the belt is so tight.
May 18, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Brushes on My Hoover Steam cleaner will not spin
We had same problem,Had to have bearings replaced at hoover store/service center. If you bought it within the last year it is under warranty and you wont be charged.
Nov 24, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Brushes not going round
The brushes on my dyson have stopped going round. I have checked it and they move freely by hand. The belt is intact. What could the problem be? The Hoover is about 10 to 12 years old.
My dyson is a dc04
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
One of the main problems with vacuums are that the flat belts on the vacuums stretch and should be changed every 4 to 6 months or 3 or 4 times a year – you can tell by taking off the belt or belts on the vacuums and compare them to the old belts on the vacuum the new belts will fix inside of the old belts and you will be able to see the difference on how much they have stretched – if the belt is a geared belt – they stretch as well but should be changed about one a year – the cost is not that expensive and you cleaning will improve almost double – this also applies for the Dyson DC04 and the Hoover vacuum as well – some of the Hoover vacuums have two (2) belts and they both should be changed @ the same time.
Apr 15, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
