It trips breaker each time plugged in--
Washing tank out Trying diff plugs--trips the breaker
Think your going to need a service call-- to find a
short to ground, as the breaker is tripping
Best plan on a launder mat for the next couple weeks
Posted on Dec 03, 2014
Speedqueen heavy duty extra large capacity trips power
Does this happen simply plugging it in? Or is it when you try to operate it? If it occurs as soon as plugged in, you may have grounded something inside the unit during transport that is causing the power to trip. Or you could have a faulty breaker. If it is when trying to use it, determine if the circuit load is adequate for the unit. There may be other items on the circuit causing it to overload when operated.
Aug 01, 2016 | Washing Machines
Whirlpool washer machine WTW5790SQO washer trips circuit breaker half way through cycle
you are pulling to many amps see if breaker is faulty first.....see if washer is in the spin and jumping around when this happens run washer with out wash in it and see if it does it something is pulling to many amps to blow breaker or could be just a bad breaker,,,, pulg something else in the wall plug that the machine is plugged in to (like a toster) and see if it trips then if so probably the breaker
Nov 11, 2011 | Whirlpool Washing Machines
Machine keeps tripping out when starting wash cycle - electrics have been checked by electrician - no problems- have managed to get it to spin but not to wash
Hi
The washing machine is obviously drawing too much current for the breaker to handle. This could be due to the washing machine drawing more that it should or because the breaker cannot handle the current the machine needs, coupled with the other machines on the ring main. If the fuse on the plug of the washing machine does not blow, then it could be that there are too many appliances on the ring main. The fuse on the machine may not blow however, if the breaker has a faster blow time than the fuse in the plug. Try plugging the washing machine into another ring main. Or try plugging out all the other appliances on the same ring main and test it out.
If the ELCB (Earth Leakage Circuit Breaker) is tripping only when the washing machine is running then something in the machine is faulty.
One common problem is the heating element. Over time they tend to crack and when the water gets in, the ELCB will trip out. This can be problematic to diagnose as offten the element will only trip after a period of heating. Bottom line, if it is tripping the ELCB then it is dangerous and should be fixed before any further use.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 | Creda W120VW Front Load Washer
Breaker to Master Bedroom is tripped, will not allow to turn from "off" to "on" all the way. rest of power in home is working fine.
HI,
I will assume you have tried to first turn the breaker further to the "off" position before trying to turn it on.
If you have, then confirm that is is not immediately tripping, which it can do if there is still a short in something plugged in. Check the items plugged in, something mad it trip the first time.
It is not uncommon for the breaker to fail if its old or a cheap one (home depot) that has tripped several times. They are pretty easy to swap... as long as you have some skill, let me know if you have fully reset it or if you think it has failed.
Brett
Feb 08, 2011 | Garden
I'm trying to connect a GSW-SK door switch to an led rope light. The circuit breaker trips every time I plug the power cord into the outlet. Any ideas?
The circuit breaker trips because you have some sort of short circuit. Use a Meter set to OHMS, and try to find the "Short". Check the wiring in the Plug also.
Feb 11, 2010 | Gardner Bender #GSW-SK Door Switch
Washer fills but trips breaker when trying to start wash cycle. Does the same with rinse and spin cycles and when plugged into another circuit
Hi there
OK thank for writing to fix ya. Sounds like your breaker can't support your washer so you need to replace you breaker where it can handle you washer. just go up another 30amps on your breaker and try that. let me know how that goes.
Best regards Richard
Dec 08, 2009 | Washing Machines
OVERHEATED DIFFERENTIAL DUE TO LACK OF OIL
It doesn't have a drain plug. Yes the square plug is the fill plug. You have to remove the cover to drain it. To remove the fill plug try an open end wrench with a pipe over the end of it.
Apr 12, 2009 | 1998 Jeep Grand Cherokee
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
