Question about Kitchen Ranges
How can i fix my panasonic inverter model CS-S18JKQ the error code is F90
localwonder
  • 6784 Answers
SOURCE: error code f90, lock motor continuously runs. How
HI, this is a door lock switch failuer code. you will need to check the door lock mechanism for faults. check the wiring harness for lose fit and corrosion at the contact point. if the wires are in good condition and, the door lock mech is functional, replace the oven control board.
Posted on Jul 19, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: How do I change the battery in the remote control
slide the cover of the remote up higher. It is hiding the batteries.
Posted on Nov 26, 2009
hvac1960
  • 2133 Answers
SOURCE: panasonic inverter model no CS-E21HKR
In remote/thermostat there is option " FAN " press for low/med/high. Plz refer if any fault code is there.
Posted on Dec 10, 2010
SOURCE: Panasonic Inverter CS-E12EKU timer indicator blink.
Today I install a new unit Panasonic CS-S13KKP also have a same problem timer blink and the outdoor unit wont start. Error code is 11. after checking the problem, can not using a 3 cable cord, solve the problem using 4 Cable cord and its run !
Victor
Posted on Dec 11, 2010
hvac1960
  • 2133 Answers
SOURCE: WHAT IS ERROR CODE F96 ON A PANASONIC INVERTER AIR
F-96. Over heating protection. to solve it-------Check for • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor)
Posted on Jan 03, 2011
Panasonic a/c
F90 = PFC control
Abnormality judgement: 4 times occurrence within 10 minutes
Location to verify: Voltage at PFC
Jan 26, 2014 | Heating & Cooling
Panasonic ac unit keeps coming up with a fault.... the error code is F90 air con is 5kw
dont no the code but if you call pana and tell them the code they should no what it is. not always usefull as they can give a general response but worth a try. then post the answer.
Jan 20, 2013 | Panasonic Heating & Cooling
Hi, I want to know the meaning of the error code of an air conditioner panasonic s91 inverter.Grazie
Grazie, your question is rather confusing, because you listed to different model numbers for to different types of appliances. The "panasonic s91 inverter" is a cooking appliance. Whereas, the CW-X-C243HU is an air conditioner. So, which appliance are you inquiring about? And you didn't even say what the Error Code is.
Perhaps you can be bit more specific.
Jul 13, 2011 | Panasonic CW-XC243HU Air Conditioner
Hi, the timer light keeps flashing and the unit isn't operable.
As you have not mentioned any model/BTU/error code, i could help you only by giving this following site;
http://www.haddocktechnics.nl/panasonic/Servicemanuals/Servicemanual Panasonic CAS (HP) CS-F14 18DB4E5
thanks.
Feb 02, 2011 | Panasonic Heating & Cooling
Panasonic inverter model no CS-E21HKR fan appears to be working on high we cant get it to slow down
Dec 09, 2010 | Heating & Cooling
WHAT IS ERROR CODE F96 ON A PANASONIC INVERTER AIR CONDITIONER - MODEL CS-E28HKR ?
Nov 21, 2009 | Toyotomi TID-1800HP Air Conditioner
Panasonic Inverter CS-E12EKU timer indicator blink. The unit not work at all, I follow the manual instructions using the remote control but the instructions are not clear. Using other similar Panasonic...
Victor
Aug 21, 2009 | Panasonic Heating & Cooling
Error code f90, lock motor continuously runs. How
Jul 19, 2009 | Ovens
Oven went in self cleaning mode and shut off door unlocked f90 error code will not bake
During the cleaning cycle, there was a temp sensor malfunction that may have damaged the temp sensor. this is a common occurrence with this model. this is refereed to as a runaway temperature code. the sensor lost control of the cleaning cycle and it got to hot. the temp sensor is fried and it will need to be replaced.
May 22, 2009 | Stoves Ovens
I've got a pana inverter CS-E24FKR, and the timer icon is blinking. I have not set a timer and i can not get the unit to respond. I tried holding the "check" button down for 5 seconds, then...
I had the same problem with a Panasonic Inverter mini split model cs-e12eku and i had to turn it off using the main power breaker switch. ( I could never get the darn error code.) I left it off for a couple of minutes and it seems to reset. My uncle is in the ac business and he has heard from other ac techs that the Panasonic ac's are problematic, sounds like it might be true...I suspect that the time, my unit worked perfectly for from 11/06 to June 08 and living in the tropics I used it every day I havent called Panasonic but it sounds like a faulty circuit board.
Jun 03, 2008 | Heating & Cooling
Kitchen Ranges Logo
56 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
