Question about ACDelco 2002-2005 AC DELCO-FW293 Chevy Venture Wheel Bearing & Hub Assembly
How to unlock RSD radio - ACDelco 2002-2005 AC DELCO-FW293 Chevy Venture Wheel Bearing & Hub Assembly
Locked infinity rsd radio in 2002 chevy venture
Does the radio say "LOC" or does it read "000"? Which AC-Delco radio do you have? Are there 5 or 6 pre-set buttons for selecting a station?
Did you consult your Owners Manual? There is a procedure the dealer can do to unlock the radio, but I know how to get the unlock codes for free.
Dec 03, 2014 | 2002 Chevrolet Venture Passanger
Extract RSD files
Files that contain the .rsd file extension are normally associated with the RealSQLDatabase. The RSD file format that associated with this file type is a database file format that is used by the REALbasic software application.
The REALbasic software program is an application that is used to develop other software applications that use the BASIC programming language. These RSD files store the database information in a structured format. The information contained in the database can then be accessed using the various SQL commands.
The .rsd file extension is also used with Roland software program. These RSD files store sound files that are used by the application.
Or in simple terms you need the right software to use a RSD file.
Oct 23, 2013 | Rosetta Stone Computers & Internet
Hallo everyone Can you help me in unlocking radio FORD 5000 RDS EON in my Ford Focus serial no. M356552 PART NO.96AR-18K876-BC
Hallo everyone Can you help me in unlocking radio FORDarrow-10x10.png 5000 RDS EON in my FORD FOCUSarrow-10x10.png serial no. M440664 PART NO.98AP-18K876-BC
Aug 28, 2012 | 2003 Ford Focus
5000 RSD EON is LOCKED 13. Please help me
LOCKED13 means that there have been 13 or more wrong codes entered.
It can only be reset by the Ford Dealer or a Radio Decoding Service.
It will not be available for free or cheap from anywhere on the Internet
Jul 04, 2011 | Car Audio & Video
No. i need to unlock my motorola razor v3 for
My friend gave me a razor to unlock last night that he just bought from a long time user on Cingular network. Since I unlocked without trouble I thought I would help someone out. Basically you need to flash one software into your phone, then you need to run another program and unlock it. Here is how I did it. Download and install EMULE, a free program. Run EMULE and select edonkey network only and forget KAD network during setup. Don't upload with emule in chunks as I believe it takes more processing power from the PC. Now run EMULE and click Connect. After it connects search for a program called P2K.EASY.TOOL. It will be around 6.2MB file. Extract all the files and look for a file called P2K_Easy_Tool_v39 and extract this also. Next, you need to get the program called RSD Lite 3.0. Again get this file by searching emule for this and downloading. Then install the program by double clicking on .msi or right click and click install. Now get the program Motorola_Unlocker_2005.zip. This can be found quicker at themotoguide.com/unlocking.php. This file may not be necessary or this step! CHARGE the phone to full charge. I forgot two more file are needed! You'll need to USB drivers for the phone. The ones I used were v3_drivers.exe (search yahoo) and always click continue anyways. Finally, you will need bl_826-828_to_07d0_ for_V3_by_Archy.V2.shx (no space between 07d0_for_) and this file can be gotten at themotoguide.com/unlocking.php. If you attempt to communicate with the phone it may want to install drivers and you may have to do the operation again. When installing drivers, just specify the folder where you extracted USB drivers. Now lets get started. Plug the phone into USB cable and turn on. Run the program called RSD Lite 3.0 and then it should say connected and show your phones IMEI #. If not, you could restart phone, but press # and * with one hand then start up. Now it should say in RSD LIte 3.0 something different. You can leave it like that or restart phone and then you should definitely see IMEI #. Now click on FILE in RSD Lite 3.0 and search for the file bl_826-828_to_07d0_for_V3_by_Archy.V2.sh… and click OK. Now lets downgrade the bootloader, click START. Wait tell it is done and finished at 100%. Don't even mess with the computer during this time or any cables. Turn phone off and hold down * and # on phone again and turn phone on into Flash mode again. It should say 07d0 now or be a blank screen, which is fine. Now run the program Motorola_Unlocker_2005, click send to phone. It will do something and your phone will reboot. If it is unlocked then you are done. If it didn't work as mine didn't with this step then turn phone off for third time. Again boot up in flash mode by holding down both * and # and turn on with other hand. It will be in flash mode with black screen. Now run the program called P2K_Easy_Tool_v39.exe and there is one other file in this folder called winscard.dll. Click on LOCKS and then select your phone model. Now select Unlock SP. Click on DO SELECTED JOBS. It should show the status above and will do some work, then reboot phone do some more work and power off, I remember. That is it turn it on and you are done. Lets sum this up on what is needed. EMULE, P2K.EASY.TOOL, RSD Lite 3.0, Motorola_Unlocker_2005.zip, bl_826-828_to_07d0_ for_V3_by_Archy.V2.shx. You could probably skip the Motorola_Unlocker_2005.zip step. If for some reason you destroy your phone! You have a 80% chance of recovering it by going to www.themotoguide.com/downloadfirmware.ph… and getting one of these three files, extracting it. Then flash it into your phone with RSD LITE 3.0. Do not do any of these steps if it is illegal in your country or you don't deserve to use your phone yet or buy talk time from a network!!
http://www.themotoguide.com/unlocking.ph…
Hoped it Help.....
Aug 01, 2009 | Motorola Mobility RAZR V3i Cellular Phone
MY RAZR WONT UNLOCK
I had the same problem with a phone that was donated -- user forgot the pin to unlock the phone. There is a way around this. You will need to reflash the phone. I used RSD Lite, which is a Motorola Utility for flashing their devices.
But first, you will need a flash file to overwrite the one on your phone that is associated with the pini code. To find an appropriate flash file, search for "ModMyMobile" which is a forum that has various Razr flash files. You will need to enroll, but its free.
Locate and download the appropriate .shx file and unzip to a directory on your computer that you can easily find.
Run RSD Lite and connect your Razr with a USB cable. The program should locate your phone and put it into bootloader mode... don't panic, it is supposed to. Now click on the "..." button up top, locate the unzipped .shx file and hit "Start".
It takes about 5 minutes to reflash and presto - you phone is working again! :-)
Jul 02, 2009 | Motorola Mobility RAZR V3
I forgot my unlock code for my moto razr V3
your firmware is corrupt, the only way to revive your phone is re flashing it.Its hard to do, and by doing it wrong may damage your phone. To safely retrieve your phone is let the experts do it or go to a near cell repair shop and let them help you out,
if you want to do it your self, try this
first you need is a RSD lite program or flash and back-up to flash or reformat your Motorola,
to enter the bootloader
hold * then the # then power button, your phone will boot to bootloader, and you will see there the flash program of your phone,
start the program rsd lite or flash and backup
then connect it to your computer VIA usb, automatically the program will detect your phone,
i prefer that you first buck up your firmware by using F&B (Flash and backup) then use RSD lite to flash your Motorola,
RSD lite its much easier to use than F&B, but for safety backup first your firmware,
gudluck
Jan 16, 2009 | Motorola Mobility RAZR V3
Motorola l6i
gudluck
Aug 28, 2008 | Motorola Mobility L6 Cellular Phone
ACDelco 2002-2005 AC DELCO-FW293 Chevy Venture Wheel Bearing & Hub Assembly Logo
Top ACDelco Tools & Hardware - Others Experts
Lawrence Oravetz
Thomas Perkins
Thomas Perkins
Are you an ACDelco Tool and Hardware - Other Expert? Answer questions, earn points and help others
