Question about Car Audio & Video
The wire leading from the negative and possative on the out side of the sub to the internal part of the sub under the plate had broken can this be fixed
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
Yes.
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_195f36f311cb10df
Posted on Dec 03, 2014
  • Sam hall Dec 03, 2014
    But how as I don't want to cut the sub apart
I changed my battery on my 2008 honda connected the possative wire on negative termanal and negative on possative and now i have no juice notthing not even the lights will come on .
check main fuses the biggest ones you see if there still in tack then start looking on the positive wire for a broken fusible link
Mar 10, 2015 | 2008 Honda Accord
I changed my battery on my 2008 honda accord I made the mistake of connecting the possative wire on negative termanal and negative on possative and now I have no juice notthing not even the lights
Go get another battery. Try that 1st. Just make sure its a GOOD battery, not a we think its good. Get a you know its a good battery and start there. Let us know what happens after that.
Both subs quit at the same time
- kkkjohnson - Please clarify your question. Do you mean they stopped working all together.
-First make sure the amp going to the subs is still working. -If not, stop and trouble shoot the amp (fuse, loose wires,etc) -If it is working, check the wires going from the amp to the subs -If the wires are connected, your next step should be to dismount the subs and hook them up to a digital multi-meter (DMM) To use a DDM to test the subs ohms do the following:
Figure out what the specs of you subs are...ie...what ohms and voice coils the are (dual 2 ohm, 4 ohm, etc. After that, place the black/negative wire/lead coming from the DMM tol the negative terminal of the sub. The place the red/positive wire/lead to the positive terminal of the sub. Then set the DMM to the ohm symbol. It should look like a horse shore symbol. Then allow 5 or 15 seconds for a accurate reading of what the ohms are. For instance a dual 2 ohm sub should read anywhere from 1.6 ohms to 2.4 ohms...each sub is difference. Check both sides/voice coils if it is dual voice coil subs. For instance if your sub is dual 2 ohm sub and you get a read that is higher than the numbers listed above (ex. 8 ohms, .05 ohms, etc); this would indicate that you have a blown sub.
Oct 14, 2012 | Kicker Comp CVT 10 Car Subwoofer
Powers up but no speaker output
Hello montez1599,
That's a great amp.
You do not say what subs you are connecting or what wiring configuration you are using. But there should be no problem if the amp is powering up normally. I'd check the gain and crossover settings to make sure they match the subs.
Having 2 +'s and 2 -'s is just a convenience for connecting more than one sub to the amp. If you have just one sub, connect to either of the positives and either of the negatives (they're connected internally). If you have 2 subs, you can run separate wires to each sub or you can wire the subs together and then run just one positive and negative to the amp.
Hope this helps.
Aug 30, 2009 | Jl Audio 500/1 Car Audio Amplifier
Sub woofers and amp
first of all is the amp a four way amp? if so then you need to know what the watts of the subs are (you dont want to melt them) wire + and - of channels 1 and 2 to one sub and + and - of channel 3 and 4 to second sub, nice thick lead from battery positive (fused) to positive terminal on amp thick lead from a good earth point to negative terminal on amp run a set of rca leads down the opposte side to the positive wire to prevent interference, run thin wire from remote wire of radio to the remote terminal of amp, rca's are plugged in at stereo and at the am. may need a RCA splitter to be able to power all four channels
Good luck Davelee
Mar 24, 2009 | Car Audio & Video
My CA9 has protect recurrent problems.
if you are bridged in parallel instead of in series the amp wont support the load so it turns the power protect on till the amp cant handle nomore then the amp will go if you have two subs bridged run them left speaker possative to to the amp possative for bridged mode then laft speaker negative to the right speaker possative then right speaker negative to your amp negative for bridged mode if you have them left and right speaker possative to amp possative and left and right speaker neggative to your negative to your amp thats parallel the ampwont support the 2 ohm load
Feb 08, 2009 | Crest Audio CA9 Car Audio Amplifier
Car system
if you have dual voice coils connect on each seporate sub negative left channel to possative right channel of the subwoofer same to other sub then conect the left possative and the right neggative to your box power terminal same to other sub then conect the two sub outs on your box left speaker positive to your positive left channel bridge then conect left speaker negative to the right speaker possative then connect your right speaker negative to your right channel negative brigdeg to your amp is single coil hook the box its self up the same way to your amp i have two dual voice cooil 12" hooked up to the same amp that way and it rocks without the power protecter turning on
Nov 09, 2008 | Pyle PLA2200 Car Audio Amplifier
Crossfire amp 2ch, right side
Possibly an internal issue in the amp (i.e. broken solder joint on the circuit board). Also, check your RCA preout connections, too.
Mar 14, 2008 | Car Audio & Video
Sony amp bridging
Your amp, being a 2-channel amp, should have 2 speaker connections with a negative sign(-) and 2 with positive signs(+)...Take your speaker wires (You will need 4 of them) and twist the ends of 2 of the together and put them into the negative spot on 1 side of your amp. Assuming you have 2 subs, connect them 1 to each sub and be sure they are on the negative sides of the subs or both are on the same side of the subs. Then do the same with the positive leads except to put them in the positive spot on the opposite side of the amp. So you will have the negatives from one side's outputs (or channel 1) and the positives from the other side's outputs (channel 2). Thus, your amp will be "bridged" across both channels. Hope this helps...just comment back if you need a diagram or something. And be sure to leave feedback please.
Oct 05, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Verge VGA300M Speaker terminals
Mono amps often have two sets of speaker outputs; this is just to simplify multi-speaker connections. The two positive and negative terminals are connected together internally, so they're effectively the same as one terminal. There's no difference between connecting both subs to the same positive and negative terminals, or using different terminals for each sub; electrically they'll all be connected together either way.
Jun 06, 2007 | Verge VGA300M Car Audio Amplifier
Car Audio & Video Logo
42 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
