Question about NHN USA Soldier Front
Error:Failed to update XIGNCODE due to insufficient hard drive space or because the program is being block by a firewall or anti-virus software
Acer Aspire M5100 ..... Will not recognize EXE files (will not open most programs) ... Lags, freezes goes to blue screen and often completely and suddenly shuts of Everything (fan monitor etc.) except the...
This fault can be caused by so many different things:
You should start by tracing back through the recent history of hardware, software, drivers or settings changes to the computer between now and the last time that the computer was working properly to eliminate as many items as possible from the long list of possibilities below so you can isolate the precise cause.
Virus or spyware or other malware infection;Overheating due to insufficient number of internal cooling fans;Dry or insufficient paste between the Central Processing Unit (CPU) and the heat sink/CPU cooling fan;Failed or disconnected CPU cooling fan;Dust blocking input or output of cooling air inside the computer case;Dust blocking the input of cooling air to the CPU heat sink by the CPU cooling fan;Device conflict;Device driver conflict;Corruption of Windows system files;Corrupted Windows Registry during registry editing;Multiple installed anti virus programs in conflict with one another;Multiple installed Firewall problems in conflict with one another;Multiple installed anti malware programs in conflict with one another;Incorrect Firewall settings;Corrupted interrupted or incomplete Windows upgrade setup process;Corrupted interrupted or incomplete Windows repair installation keeping previous files and settingsCorrupted interrupted or incomplete Windows recovery operation;Corrupted interrupted or incomplete Windows Service Pack upgrade process;Corrupted interrupted or incomplete System Restore operation;Corrupted interrupted or incomplete Windows Automatic Updates shutdown configuration process;Corrupted interrupted or incomplete Windows Automatic Updates restart configuration process;Corruption of essential Windows system files by enabling compression to increase HDD free space;Accidental deletion of essential system files;Underpowered Power Supply Unit (PSU);Incorrectly installed Random Access Memory (RAM);Incompatible RAM;Incorrectly installed graphics card;Incorrectly installed expansion card;Internal devices incorrectly connected to the motherboard;Incorrect motherboard jumper settings;Basic Input Output System (BIOS) corruption;Incorrect device IRQ (Interrupt Request) settings in BIOS;Bad hard disk drive (HDD) sectors;Physically damaged HDD;Motherboard solder points short circuiting on a loose screw or a misaligned motherboard mount.
Aug 04, 2011 | Acer Aspire M5100 AM5100-U5313A AMD...
Tip
How to organize data on your computer
Organizing data is the best thing that a person can do, who likes to be systematic,professional and clutter free with regards to data.
There is no real meaning in keeping your computer disorganized which would result in malfunctioning and cost you money that you can save if you just organize your data effectively.
The best way to organize the data on your hard disk is as follows:-
Perfect Partitions·
  • First things first, when you install an operating system, for e.g. Windows Xp you get an option for partitioning your drive, make sure you make full use of this option to create as many drives as you feel are appropriate depending on your hard disk capacity.
  • If you want to have 1 partition which is small and the other 3 to be bigger, then you can just reduce the of the first partition which you would use mainly for operating system and installing applications.
  • So for e.g. a 500 GB hard disk can partitioned as 50 GB for operating system or the root drive usually c: drive ,and then the other three drives you can use for bulk storage i.e. 150 each ,which would result in 50GB+150GBx3 = 500GB Hard disk.
After installing the operating system, install only those programs which you use, and are essential for your use.·
  • There is no meaning in installing programs that you don't use often, or don't actually use, for e.g. some people would like to install CorelDraw application , when they are not working on it.· This does nothing but takes up unnecessary space on your hard disk drive which causes the hard disk to slow down or possibly get infected, if the software that has been installed is a pirated one.
Install Anti virus software as soon as you install an operating system
  • This is a prerequisite to make sure that you are safe from virus right from the time that you have your operating system installed. · Most of the time users want to install all the other application besides the anti virus software, this software could be infected by viruses, in case such software are pirated or you install them from a USB drive or a pen drive which has been infected.
Keep updating your anti virus while you use your PC·
  • As viruses are created daily, there is no way out but to keep updating your anti virus software from time to time, as and when they have an update.·
  • Usually the anti virus software is set on auto update mode, so when the time is due, the anti virus would download the latest update automatically, so if you disable auto update feature, it could potentially harm your computer.
Keep your desktop clean to have a nice relaxing look·
Now this depends on personal preferences but it has been observed that those people who fill their desktop with many shortcuts copy files on their desktop instead of a different folder of a hard disk or a different a partition realize that they have not organized their data.
The consequence about the above act is that,when your root drive gets infected by a potential virus, or it gets formatted or loses its data due to a power surge, and you find that you no longer are able to boot your operating system, the only option you have is to format the partition and install the operating system again.
There are ways to recover data but , many users are not experts in recovering data it could cost them much in terms of money when they ask someone for data recovery , but it's always better to be safe than sorry.
Maintain all shortcuts for applications in one folder in your desktop·
  • There are many applications which are usually installed by users, therefore, it is always better to have their shortcuts in one folder to keep the desktop clean and clutter free.
Uninstall the applications that you don't use·
  • This is very crucial, as many people don't liketo uninstall application, but just ignore them despite the fact that they know these application regardless of their are taking up space in their computer's hard disk as well as registry.· Uninstalling such applications helps you to control which programs are useful to you and which aren't.
Hope you enjoy organizing your data.
on May 13, 2011 | Computers & Internet
Tip
How to speed up computers.
**1The main reason which slowdowns system is VIRUS ATTACK.
Powerful tool to avoid this is installing Anti Virus.
Anyhow installing a anti virus is not sufficient.You need update the anti virus continuously(once for a week)
Updating means:-Hackers will generate the viruses and they will upload those viruses to internet data base every day.Which enters our computer when connected internet.The companies which provides the anti virus software will scans those viruses and they update those virus name our anti virus data base so that if any programs by those virus names which are in anti virus data base.Anti virus will block those programs.
So It's necessary to update the anti virus program continuously.
If you have genuine Windows operating system you can use "Microsoft Security Essentials" for FREE.
**2The reason which slowdowns PC is creation of unwanted sectors in hard disc.
For this Defragmentation is the best method to clear unwanted sectorsTo defragment the hard disc Select the partition>Right click>Properties>Tools>Defragment disk>Defragment>ok
Watch this...
**3)Another aspect which slow downs the system is creation of error sectors
you can use Check Now option to clear error sectorTo activate Check Now*Select the partition>Right click>Properties>Tools>check nowIt check for error during next reboot
**You can use "CHKDSK" command in DOS(instant check)
**3)You can use Disk Cleanup to delete temporary files,offline pages,log files, queued and error reports(These files are not important and files consumes much memory which can't cleared by us so we need to use Disk Cleanup.
To use this thisSelect the partition>Right click>Properties>select Disk
Cleanup (Disk Cleanup can be used for C: drive only effectively(Because temporary files,offline pages,log files, queued and error reports are saved in C: only)
**Options and Menu's are with respect to Windows7 & Windows related operating systems.
Thank you have a nice day
on Jan 30, 2011 | Computers & Internet
WD Software will not load up, and Windows keeps giving me an I/O error. With the I/O error, I am not able to see or access any files that I have on my WD MyPassport 1TB, SN WXD0AA9W6561
Have you tried another USB port.Try not using a USB hub and plug it into a different port on your PC. Also try temporarily disabling your virus and anti-spyware program. My virus program Antivir always blocks my WD software. There may have been an update that now blocks it. Check all your cables and plugs on the WD drive and if still not working try starting your pc in safe mode and see if the WD drive is recognized. Hope this was some help, Thanks for using FixYa
May 11, 2011 | Western Digital My Passport Essential SE...
How do i fix "Application
Normally, this error message indicates either your firewall or anti-virus program is blocking the application, or you have a deeply infected machine.
Scanning your computer with trusted spyware and antivirus software may find infections that are causing the problem.
If this doesn't help trying finding your firewall or antivirus' settings and look for an exclusions settings. Add the program you are having problems opening to the list and then reinstall the application.
May 05, 2011 | Computers & Internet
My site is blocked it just got blocked by an anti virus and now i want it unblocked but i'm not sure how to do that. the site is facebook. please help.
It is different for all firewall/antivirus programs.
Find the firewall or antivirus program you use on the Start Menu > All Programs
Open the program and find the Help menu.
Search the help for "blocking" and "websites"
In addition, the software company the program should have a website where you can also search for answers and contact their support group.
If this helps please vote for my solution.
May 25, 2010 | Microsoft Computers & Internet
How to remove trojan horse virus in usb 2gb
Connect USB drive to USB port.When icons appears in My Computer, right click on it. A popup menu appears showing option for virus scan.By clicking on it scan the entire drive.
But dont ever open that USB drive, if there is a possible trojan. because when you will open that USB drive, the trojan will be copied into your hard drive automatically.
Best way to remove trojan is to completely format your USB drive.
Oct 29, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Can't update or even find eTrust EZ Anti Virus on my computer
I was using SBC Global while in California. I moved to Oregon and am currently using Comcast. The problem was that my anti virus was part of my SBC Global package. I was able to contact SBC Global where they informed me that they use Symantac which uses Norton anti virus. I was able to contact and download Norton uninstall tool to uninstall the anti virus. I also uninstalled the SBC Global software (AT&T Yahoo) and that enabled me to install new anti virus software.
Apr 09, 2009 | Computers & Internet
Unable to get latest software version 2/-79
have you checked that your pc security software such as 'anti virus', 'firewall' ,'anti spyware' is not blocking access to downloading or installing software?
also sometimes little nags like this is due to a virus/spyware infection, when did you last scan & update?
Sep 18, 2008 | Computers & Internet
Computer is showing fatal error
That fatal error warning message is not coming from your operating system - it is coming from a virus. Do not follow whatever instructions boxes like that may tell you until after the following process.
Turn on your machine's firewall and tick NO EXCEPTIONS. Download an anti-virus product like AVG from download.com. Install it, update it until it says it has all updates, and then do a complete scan of your machine removing viruses.
Reboot.
Navigate to WINDOWS UPDATE on your start bar and allow it to install all updates it can, even optional ones.
Reboot.
Go to ADD REMOVE PROGRAMS from CONTROL PANEL and remove all security software besides the anti-virus you just installed, since this software has failed and is now unreliable.
Good luck...
Nov 18, 2007 | Compaq fs740 17" CRT Monitor
Video Game Consoles & Games Logo
110 people viewed this question
Top NHN USA Video Game Consoles & Games Experts
James Wishart
Are you a NHN USA Video Game Console and Game Expert? Answer questions, earn points and help others
