Question about Craig Televison & Video
How do I scan a Craig LED TV for digital channels?
I am scanning but I am not getting any channels, is this tv capable of playing digital tv?
    Master:
  • Craig Master
  • 423 Answers
If it is fairly new it should be able to scan for Digital Stations. Connect it to an antenna that you know works on another TV and you can go to www.TVFOOL.com and it will tell you what stations are available at your address and what type of antenna is needed.
Posted on Dec 21, 2014
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
19" Element HD Digital LED TV Model ELEFW195 Does not scan Digital Channels just Analog Channels.
Auto-channel search can't find digital channels - Community ...
community.insigniaproducts.com/...channel...can...digital-channels/.../13...
Aug 6, 2010 - When I ran the auto-channel search it could only find 4 analog ... Notgetting Digital Channels on NS-26L450A11 ... I've plugged the cable from the wall into the TV, and preformed the auto channel scan, with "cable" selected.
Troubleshooting Guide for Digital-to-Analog Converter Boxes
https://www.fcc.gov/.../troubleshoo...
Federal Communications CommissionIf you aren't receiving digital signals on your analog TV, you can purchase a ...antennas are designed only for reception of either VHF or UHF signals (but not both). ...The channel scan will automatically search for digital broadcast channels ...
Antennas and Digital Television ' Federal Communication
Jan 13, 2016 | Televison & Video
The analog tv picks up a lot more stations and correct channels than the LED TV. Is it possible to set the Insignia LED NS-19E320A13 to analog? Is there a device available?
.YES IF ITS A DIGITAL TV U WILL GO TO MENU GO TO ANTENNA CHANGE FROM DIGITAL TO ANALOG OR AUTO ENTER THEN SEARCH ANOTHER WAY GET AN ANALOG TO DIGITAL SET TOP BOX FIX YA ANTENNA TO IT CONNECT TO TV BY HDMI.OR AV CABLES GET THE SET TOP. ON GO TO SCAN OR SEARCH AND YOU WILL HAVE ANALOG CHANNELS ON YOUR LED TV
Oct 08, 2015 | Insignia Televison & Video
I run the auto scan and it is picking up 0 channels and say to please run auto scan
Where is your antenna hooked up? Thru a cable box? Direct to tv? Completely describe setup, maybe post photos
Apr 02, 2015 | RCA Lg 65lm6200 65" 3d Led Flat Panel...
Cant get dtv highlighted in menue on tv
Your TV must receive a digital signal in order for the DTV option to be available. Since you are not seeing all of the channels when you auto scan then it can be assumed that the signal cable connected to your set is not providing the digital signal. Make sure you are scanning for the proper source of your signal ( Cable TV, Broadcast TV)
Nov 29, 2014 | Seiki 32" LED TV - SE321FB
Digital noise filter off and on comes back after removing demo settings from picture options...how can i get rid of it off my screen permanently!!! i have series 5 samsung LED 40"
You have set up your tv in store (demo) mode. Go to settings then plug and play and scan channels again but this time select home mode before it searches for channels.
Aug 16, 2011 | Samsung UE40B7020 40 in. LED TV
How do we scan/program in local tv channels. We bought an external antenna, but get no picture. Typically, there is a protocol for scanning channels into the set. Model is Sansui TVS2746B, and the set was...
Okay, does this tv have a built in DIGITAL tuner? Most tv's only have an analog tuner. You can tell the difference while you are changing the channels. If the channel indicates 2.1 or 2.2 and so forth, it is on a digital channel mode. If you change the channel and it indicated 2, 3, 4, etc. it is analog. If it has digital capability change the input until you see 2.1, 3.4 etc. If you cycle through all the inputs on the tv like, input 1 (TV) input 2(DVD) input 3(HDMI) and so forth and you never see the digital channel you most likely do not have a digital tuner. You will need to purchase a digital converter which will convert it to analog and you can watch it by placing you tv on analog channel 3 just like the old vcr's. Hope this helps and please don't forget to rate this solution.
Jan 22, 2011 | Samsung TSL2793HF 27" TV
Lcd tv digital tuner
Welcome to the world of off-the-air broadcasting!
First, be sure you have the TV set up correctly and that is in fact capable of digital tuning. Just because a set was sold as HDTV doesn't mean it has a digital tuner. Small TV sets weren't required to have digital tuning until shortly before the switch from analog. This set may require a digital adapter. If the set does have digital tuning, be sure you have "air" selected and not "cable" for your tuning mode. Also let the set scan for channels.
With digital broadcasting, signal strength is critical. In the analog days, a weak signal would give you a fuzzy picture, but you could see something; with digital, a weak signal means you see nothing at all. You may live in an area where the signal is too weak without using an amplified indoor antenna or putting one on the roof. Your location, other structures around and weather conditions all affect digital reception as well. Many people were (and still are) upset to find that they just couldn't get any channels at all once digital broadcasts took over.
I hope this has been helpful. Thanks for using Fixya!
Jan 31, 2010 | Craig Televison & Video
Cannot get tv to scan digital stations. I have a
test test 18:30
test test test 18:31s rthsr thsty 3456234
Jun 27, 2009 | Televison & Video
How to scan for new digital channels small Philips flat screen
From the menu you should see set up the cannel scan should be there.. If all else fails unplug the TV for a few minutes then plug it back in. It should ask if you want to set up the tv, Say yes and follow the steps.
Jun 16, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Televison & Video Logo
79 people viewed this question
Top Craig Televison & Video Experts
Raj Patel
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
