Question about Vizio L32 32 in. LCD HDTV
Change remote sensor on tv - Vizio L32 32 in. LCD HDTV
If the remote sensor inside the tv stops working...is there something i can get....a box or something to change channels with another device..some tv cable can go thru before to tv so if tv is on a certain...
Check your remote control for its proper working first. Then think of the remote sensor inside your TV. To get more details about how to check remote control, click this link.
If remote control is Ok, replace the infrared sensor, which can be located just behind the infrared sensor window of your Tv. You have to open your TV, and desolder it out and solder a new one in position. The infrared sensor will look like these. There are sevieral types, and just confirm which type is used in your TV. Picures of some types are attached.
6_14_2012_6_34_32_am.jpg6_14_2012_6_35_11_am.jpg6_14_2012_6_35_33_am.jpg6_14_2012_6_35_53_am.jpg6_14_2012_6_36_17_am.jpg
Jun 13, 2012 | Samsung TV Set Top Box Remote Control
Tv shuts off by itself
change ur remote batteries, if no work still remove batteries see if help
tv may have a bad remote sensor, the sensor that tell tv go on, off, change chanel , change volume.... and so on.
or ur tv motherboard
or may be try factory reset ur tv if tv program bugged.
Jan 28, 2012 | Televison & Video
My remote does not work on my tv I have change the batteries but I notice that thre remote control sensor light does not blink or the OPC sensor. We have to turn on the tv manualy and to change channels...
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Good luck.
Mar 02, 2011 | Sharp Aquos LC-13S1U-S 13 in. EDTV-Ready...
Sensor for remote is not working on the tv
Tries a little Alcahol with a Q tip clean the tv IR sensor,do the same to the remote and change batteries,tv sensor saldom broken,only remote all the time.Tries this Website 1-800-Remotes Factory Original for new remote get the exact or very close to the original.
Sep 30, 2009 | Televison & Video
Rca 32 inch tv
Its proberally the main controll ic, or the remote sensor is malfunctioning. you will need to check the remote sensor by disconnecting it,, and if you still have the problem then you will have to change the main board.
Jul 22, 2008 | RCA 32V420T 32" TV
Can't change output source and tv sensor wont work
souns like the ir sensor board is gone, shopjimmie.com may have one ,they are probably around 15 bucks and real easy to change ,its one connector i believe ,i have not found any universal remotes that work with ilo yet either,good luck i hope i was of help
Apr 23, 2008 | iLO 3200 32 in. LCD Television
Vizio L32 32 in. LCD HDTV Logo
62 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
