This TV is not working I try to put the bb player on isn't showing nothing
My Acer Aspire X1200 DVD Player Isn't Working
- Did you Tried with another DVD? If yes. Then you can Go for the Lense Cleaner DVD once, which will Clean your DVD Player Lense.
You Can get it Purchased from any IT SHOP or Online also.
Jul 25, 2012 | Acer Aspire X1200 Desktop PC - Athlon X2...
RCA 60921 rear projection tv. Everything worked perfectly until today. It sometimes made a hissing noise on and off but nothing very loud. Today I turned on the TV and the audio works but there is no...
Bad FBT Flyback Transfomer.You need to also check the Hori output Transistor,chances are if FBT is bad then Hori output will be shorted.
Mats Electronics should have FBT 1-800-628-1118
ACME 1-800-575-9833
Jun 28, 2011 | RCA P60921 60" Rear Projection Television
I own an iview 2600hd dvd player and im trying to hook it up to my sony trinitron tv...however, no matter how i switch my cables, the dvd player just won't show any picture or audio on my tv...and when...
Try new cables. RCA cables have a tendency to have bad connections internally. Also, triple check that you're on the right input and the wires are properly connected to the DVD player. If all that fails, try the DVD player on a different T.V. and something that uses RCA cables on your T.V, such as a cable box to make sure the input jacks on the T.V. aren't bad, and the DVD player isn't bad.
Through out all of this troubleshooting, you should manage to get the DVD player hooked up.
Jun 20, 2011 | Televison & Video
I have a Haier HLC19K1 19" tv/ DVD combo that
If you have tried more than one commercial DVD and are getting the same results then the problem is the player has failed. Actually what happens is the heads go out of alignment and it doesn't have the accuracy to read the tracks any more. This is a typical failure of dvd players in desktop and laptop computers and standalone players. While the heads can be aligned it isn;t worth doing. It was when a dvd or cd player was $1500 but not now.
Unfortunately the only cost effective fixes are replacing the dvd drive or replacing the entire unit. The replacement dvd would cost more than a new replacement tv/dvd combo. So you can buy a new tv or buy an external player ($40ish).
Feb 02, 2011 | Haier HLC19K1 19 in. LCD TV
DVD Player doesn't work on DRC6355N VCR/DVD Combo
With most dvd/vcr combo units there is separate wiring. When I use my emerson combo unit I have it wired that I have to be on different inputs on my tv to view a dvd and a vhs. On some units the vcr portion is wired via a regular cable line, while the dvd portion is wired with the yellow, red, and white component cable. Try inserting a dvd and scrolling through your tv inputs until you find the picture or check your wiring to ensure nothing has come loose. If that has no result you could try wiring it differently if possible to eliminate that as a possibility.
Jul 10, 2010 | RCA DRC6355N DVD Player/VCR
Cd door won't work
Is there a buzzing noise (motor running ) if so either drive belt failed,or has been put out of time in mech
Jan 14, 2009 | Sony SLV-D251P DVD/CD Player w/Built-in...
My RCA TH1161-A mp3 player wont work at all
Ensure the key lock is not activated by sliding
"Power on/off ( )/Hold" towards the center
position. If your player isn’t already on, turn it on by
sliding "Power on/off ( )/Hold" to the left
and holding until the player turns on.
-Tha Mp3 Doctor
Jan 06, 2009 | RCA TH1101 MP3 Player
Recovery mode wont work
you should try to connect it to another computer sometimes the computer dont seem to connect to each other so try to connect it to another computer. hope it helps
Sep 06, 2007 | SanDisk Sansa e260 MP3 Player
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
