Linksys wireless prnt server
I recently purchased a Linksys wireless print server. I had difficulty trying to install so I phoned a Linksys technicain who tried a manual installation and also a CD installation. Neither process was successful. She said even if we managaed to get it installed, I would probably expereince problems when trying to print. She suggested I try to get an Epson printserver....if it was compatable with my Linksys Wireless router. (WRT54G V8)
My printer is an Epson Stylus Photo RX600.
I have a 2241 Neptoia modem.
Please tell me what I need to successfully make my printer wireless.
Thank you,
Paula Covington
    Brigadier General:
  • 6,966 Answers
Based on your post description, I am assuming that:
1. You can connect to the Internet through your 2241 Neptoia modem;
2. You can access your WRT54G V8 Linksys Wireless router @ 192.168.1.1;
3. Both 1 & 2 above could be done through a wireless connection from your PC.
Connect everything as they are supposed to be wired (printer, Print Server, modem, router etc)
Pls try:
a. Connect the Linksys wireless print server using a lan cable to the Linksys WRT54G Wireless AP/router. (Will tackle the wireless connection a bit later)
b. Reset your print server; &
c. Do a diagnostic print-out.
Instructions for b & c are in page 4 of your manual.
You need to verify that:
i. the Power indicator is contnously green
ii. the Ethernet indicator is contnously green
iii. the USB indicator is contnously green
iv. the Wireless indicator may or may not be contnously green
Pls post back with the generated diagnostic print-out before we can proceed with the other steps.
Additionally, try installing the Epson Stylus Photo RX600 direct to one of the USB ports of your PC. Use the installer/driver CD that came with it. Try using it as a regular printer. This will tell us status of the printer.
Good luck and kind regards.
Posted on Nov 12, 2007
I purchased a print server model: WPS54G. I have misplaced the set up CD. We have now two more computers in the house with the children having computers. I have misplaced the installation CD. Is there...
Manuals and software can be downloaded from:
http://homesupport.cisco.com/en-us/wireless/lbc/WPS54G
Then they could be easily burned to disc if you'd like a backup. Hope this helps!
Feb 19, 2011 | Linksys Wireless-G WPS54G Print Server
I have a netgear wireless network. I am trying to
you can use sharing printer.. even your are using wireless can print as long as you are connected on that network and secondly the same name of workgroup.
Sep 09, 2009 | Linksys Wireless-G WPS54G Print Server
Linksys Wireless G Print Server set up
Hardwire the wps54g to the router and disable all firewall installed on the compute.
Sep 07, 2009 | Linksys Wireless-G WPS54G Print Server
Wireless print server
If your WEP encryption key is turned on, it will not work. To correct this, go into Internet Explorer and type in the IP address of the printer. Type in the WEP key in the correct place and save the information to the print server, then restart the search program.
There is a detailed thread I posted on this last July on Fixa. You should be able to find it by searching under the Linksys print server by the model number.
Nov 17, 2008 | Lexmark P4350 All-In-One InkJet Printer
Wireless-G WPS54GU2 Print Server Lost disk
if you visit the LinkSys website you should be able to download all applicable drivers and files for this print server. Also you will likely be able to access a user manual (in PDF format) which should give you all the information you need.
May 27, 2008 | Linksys Wireless-G WPS54GU2 Print Server
Brother Print Server - nc-2200w
This week I'm slammed. Next week I should be free.
May 13, 2008 | Brother (NC2200W) Print Server
Wireless G print server Model # WPSM54G
Reset the Wireless print server , and run the setup cd once and check..press the hold the reset button for 60 sec with the power cable connected , that would properly reset your print server and then try to install it..contact linksys support for live assistance over phone 1800-546-5797
Jan 21, 2008 | D-Link DI 514 Wireless Router (DI-514)
Initial setup no password
use-ly it is user name is (admin) password is (admin)
Jan 09, 2008 | Linksys WPSM54G Print Server
Linksys Wireless-G Print Server
Dear Davisj, This is a typical problem that occurs when you have an active firewall. Try disabling the firewall and you should be able to print. Linksys is known for their customer service and expertise, I would suggest giving these folks a call at: 1-800-LINKSYS, they will walk you through the process of setting this up correctly. If you don't want to call, the problem lies in your firewall. Look for the IP address on the printed test page. If you are using a Linksys router with a default IP address of 192.168.1.1, the printserver should be getting an IP range of 192.168.1.x as well indicating that it is properly obtaining an IP address from the network. Once you locate your IP address all you need to do is go to your Firewall settings for your Mcafee software and add permission to add a specific IP address and you will enter your Print Server's IP address. This should fix your problem! Good luck! The following link should provide you with additional details to fix your Print Server: http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859942287&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=4228741076B05
Jan 20, 2007 | Linksys Wireless-G WPS54G Print Server
Computers & Internet Logo
344 people viewed this question
David Payne
David Payne
