Dynex flat screen 40 in tv. Have apx 3 in redish band across bottom of screen. Whole screen is flashing white shadow.
    Top Expert:
  • Televison & ... Master
  • 75,311 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Dec 03, 2014
  • 105 Answers
SOURCE: Shadow on Flat Screen TV
Projection TV correct? This may take some work but it is common for a spec of dust to settle onto the Mirror inside the TV, The back side of the TV screen or onto the Lens from which the Video image is projected. Some TVs have ports that allow you to access the inside of the TV from the side, others you must remove the screen.
This is not something to do every day or every week and it will not improve the picture. You only do this when you notice that it is dirty. Any more than that and you yourself will create a bigger problem. ONLY LIGHTLY DUST the screen. Soaps, water and windex will leave streaks, damage the screen and cause more trouble.
Projection TVs are the eqivalent of a big flashlight showing onto a wall. Put you hand in front of the light and you get a shadow.
Inside you TV there is a light (the TV picture) that bonces of a mirror attached to the inside of the back of the TV. The light reflects off the mirror onto the back of the screen. You view this refelected image from the front. Spiders commonly make webs inside the TV that appear in the picture. Dust Bunnies may get blown into an area and become stuck in the way. Sometimes a lite tap, shake or blow may remove this also.
Posted on May 21, 2009
  • 1779 Answers
SOURCE: Sharp aquos has green and white vertical lines
You must contact a svc co. This is a upper or lower buffer board problem and possibly a control board. Nothing you have done wrong, it just happened.
Posted on Feb 28, 2009
romsky79
  • 822 Answers
SOURCE: 3 horizontal lines across screen and triple shadow on left side
its a LCD connectors. re-connect it properly. some loose connection.
Posted on May 25, 2009
jrweighing
  • 183 Answers
SOURCE: 43'' SAMSONG FLAT SCREEN. SHADOWS RADOMLY APPEAR
Is your tv a plasma tv or an lcd tv? When you say shadow, do yo mean a band across or down the screen, or is it a patchy shadow?
Posted on Mar 17, 2010
  • 8457 Answers
SOURCE: No Picture-white screen
Ur Tuner board,that the tv signal came into that board.U have a little manchanical skill.Take ur tv aparts.Replaced that Tuner board ur tv will work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board to replacement.
Posted on May 11, 2010
Sharp LC-55LE643U - bottom 3/4 of my LCD TV is shadowed and purplish. How do I fix it?
Try a reset but unfortunately I believe it is a board cratered by the power outage. Try to get things shut down when the power goes
Feb 28, 2017 | Sharp Televison & Video
Bottom of screen purple "haze"
Check the site linked below, and see the screen shots of defective LCD TVs, Surf it with patience. This should be a panel fault I assumes. http://electronicshelponline.blogspot.com/
May 20, 2013 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
My zenith lcd tv has horizontal black lines whih form a band about 3 inches wide across the screen, sometimes the band looks more like a dark shadow than lines other times the right side of the screen...
This is either 1 of 2 things, first it could be faulty panel tabs , in this case, there is nothing you can do and is unrepairable....2) you could take the back off the tv and you will see 2 ribbons going from your t-con board to the panel tabs (top center of tv) remove them carefully and reseat them. This is a common problem. Tv repair tech 15 years! Best of luck.
Dec 05, 2017 | Zenith Televison & Video
For several months we would get bands of lines across our screen. We thought we were experiencing some kind of outside interference as it would come and go. Two days ago the bands began to cover most of...
You're verical output IC is dead, this might because of a leaky capacitor on that section which causes the lines across the screen.
The processor shuts down the unit automatically to avoid further damage to your tube.
Send it to repair shop to isolate the problem. This is fixable.
Thanks for using fixya.
Jan 18, 2011 | Hitachi Televison & Video
Mar 17, 2010 | Televison & Video
When you switch the tv on there are vertical white lines across the screen and shadowing aswell
Panel problem. Need to replace whole matrix as verical drivers have gone faulty
Feb 04, 2010 | Televison & Video
TV worked fine one night, next day screen is white.
The LCD Panel failed. There is no easy fix but try to get the T-Con board to fix the issue. However, this part is usually only available with the whole LCD Panel. This is usually the most expensive part in the TV and the whole TV needs to be taken apart to replace the panel.
Might be economically viable if you can find a place that carrys the T-con but Dynex parts are usually hard to find. The LCD Panel part alone will exceed the cost of the TV.
Oct 07, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
May 25, 2009 | Samsung LN-T4071F 40 in. LCD HDTV
Philips big screen hd tv
TV repairs are generally much too expensive to undertake given the great prices out there for new ones with warranty.
I would not bother with it.
May 03, 2017 | Philips Televison & Video
Televison & Video Logo
Top Televison & Video Experts
