I recorded as per manual instructions. The tv is not recording pvr. According to my laptop it is a undf file that is recorded. It will not play on any device including the tv which tells me &#
Recording from the tv as the instruction manual tells. Approximately 5 times. Checked file type using laptop on USB. I have recorded on several USBs which have been formatted. No error codes.
When I cancelled my extra view do I lost the option of record and play back on my PVR
probably will . we here at FIXYA have no idea what that company does
Aug 12, 2016 | Televison & Video
How do you record from my tv and what channels will I get?
Has this ever worked?
When you mention channel I assume you mean the channel on your TV set. Normally an S-Video input will be an aux input channel and not a numbered station on your set. How do you select the player chanel/ input when you watch the DVD?
Is the arial connected to the PVR then to the TV or direct to the TV It needs t pass through the PVR.
Jun 24, 2014 | GoVideo R6750 DVD Recorder
Bell pvr 5900 won't work
I think you have the wrong category, unless it's a PC-Laptop?
Apr 07, 2013 | Computers & Internet
I have a 2.0Tb Seagate external hard drive that will not record from my Bauhn TV. I have transfered SQ files to it and they play, but requests formatting to record.
To use the PVR record function on Bauhn TV's you MUST "Format" your Hard Drive or USB device as "FAT32" using the formatting options built into and supplied with the said Bauhn TV. There have been relatively recent changes made to the FAT32 formatting system which now allows you to format very large drives to FAT32. These changes were made after requests from manufacturers like Bauhn so that they could incorporate PVR functions into the TV set itself. I run a 1.5 Terabyte Drive with my Bauhn and it performs beautifully. I won't say that I hope this helps because "I know it will" :) Cheers.......
PS: The resultant files will have the extension SQ rather then MGP of FLV etc etc. I can't get these SQ files to play back on my PC albeit that they do play back perfectly on the Bauhn TV. If anyone knows of a program/player that will allow playback of SQ files on PC's then it would be great if you could post it up here.
Aug 10, 2011 | Televison & Video
Nd.comI have a set top box awa DT 2030 trying to connect to a standard tv through a video recorder/player what are the instructions as I cannot get it to work
Hi, With new DTV's these days, there will be problem running old players.(VCR) Video cassette recorders will not be able to record Digital signal. You will have to get (PVR) personal video recorder which can record and play Digital programs with great picture.
Jun 11, 2011 | Televison & Video
Looking at a Matsui ELCD32USB LDC tv would like to know if usb port is play back only, or as told by sales at Curry's can record also ???? spec for TV limited info, a user manual would help possible
Bought TV on previso usb recording is a true function ---- happy to say this tv does indeed record to usb file format is MPG so all good
Sep 18, 2009 | Televison & Video
Machine appears to record per instruction manual but will not play anything back and the instruction manual includes NOTHING on playback except to hit STOP when we're through recording, back up to the...
it appears to be recording but is it really?
when you are recording there are two levels you should see moving up and down on the screen. the input volume and the recording volume per track. dont forget to arm the track. tascam has a silly way to arm the track on some of there unit. its combination of buttons. something like hold down the record button and press the track arm button then release both. when youre ready to record press play.
Feb 22, 2009 | Tascam DP01 All-In-One Recording Package...
Can I record from the hard drive of a pvr
YES.
Connect the PVR to the DVD recorder via scart or RCA phono connection.
Select the relevant input on the recorder, press play on the PVR and record on the recorder.
May 02, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
