Question about Bosch Factory Reconditioned PB10 Cdr Rt Power Box Advanced Job Site Radio With Cd Player And Remote Control
The fuse is good but no power ,on my Power Box PB10-cd thanks for your time . Tim
I just had the fuse checked and it was OK
The radio stopped getting power
If you remove the front face (radio side) you will see a black box. remove the screws and cover and inside upper left corner a little pcb, check the fuse.
Mar 14, 2011 | Bosch PB10-CD Radio/CD Boombox
I have a Bosch Power Box PB10-CD, the GFI outlets clicks on/off
Disconnected the GFCI outlets, and everything works just fine. Ridiculous that Bosch manufactures GFCI outlets that does not last for 2 years. The cheepest American made GFCI outlets last practically for ever. Beeing "Bosch", the replacement outlets cost $38 plus shipping.
It is ridiculous.
Sep 16, 2009 | Bosch PB10-CD Radio/CD Boombox
Jbl pb10 subwoofer will not come on, that is the two lights in the front will not come even though it is plugged-in
1/ Check the power outlet, dont laugh i have been caught by this one
2/ Is the power cord removable (2 or 3 pin) if so then try another cord.
3/ If not check to see if there is a power switch in the vicinity of the cord
I know it sounds stupid however it does happen.
4/ Check to see if there is a fuse in the same area.
5/ If not you will have to remove the cover back, front, or bottom
to gain acess to the internal power supply, there should be a fuse in
the power supply and or a fuse in the amplifier circuit and or the speaker line.
binary6
Sep 16, 2009 | JBL PB10 Subwoofer
No power to radio, fan, light on front panel.
Hi Tim,
It may be because of the fuse being blown up. You will find the fuse box in the front or in the bannet. Please check for the same. The fuse box will contain all the fuses together. Remove them and check if the connectivity between the two ends are still there. If not, buy a new fuse and enjoy! :)
Regards,
HP
Aug 29, 2009 | 2004 Chevrolet Suburban
When radio is plugged in only the gfi outlets work not the radio.
Mines similar, outlets work but radio will only work on battery. Radio will not work on mains only. Charger works at same time so ok. SORTED IT TONIGHT. Inside the charger inside the box there is a fuse (240v 2A) I think, tiny radio fuse. Changed that tonight and radio now works on mains only or battery. Very awkwark job but better than watching a load of cr** on tv. Hope this helps someone.
Aug 12, 2009 | Bosch PB10-CD Radio/CD Boombox
Bosch Power box radio PB10 radio wont work
This might sound daft but does radio work with a battery in it ?
Aug 02, 2009 | Bosch PB10-CD Radio/CD Boombox
Bosch Factory Reconditioned  PB10 Cdr Rt Power Box Advanced Job Site Radio With Cd Player And Remote Control Logo
65 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
