Question about Steamist Electrical Supplies
Can I convert a SM-12 slave steamist unit to a primary unit, My primary does not work and I would like to change the slave to a primary unit.
Trying to make my slave steamist unit into my primary unit.
5 Suggested Answers
  • 1019 Answers
SOURCE: ide channels not working right after updating
usually when you update or re-flash the dvd rom.
it will state :- ensure that the drive to be flashed should be jumper set as master. if there were other drives connected to the same ide channel. this could have caused damage to the other drives connected. Or the IDE Channels themselves.
The only suggestion I have for you. is to remove all the drives. disconnect the power from the computer. and remove the cmos battery, for 10-15 seconds. resetting the computers bios back to defaults. then re-settup the drives ensuring that the jumpers are correct for each drive. i.e 1 slave and 1 master on each ide cable.
Mike @ Compurepair.
Posted on Mar 26, 2009
Crankstart
  • 696 Answers
SOURCE: PC will not see Maxtor 80GB DiamondMax Plus 9 as seconary slave.
Two thing,
First, never use a Maxtor HDD as a slave to a CDROM/DVD, doesn't work and tends to cause stability issues. So try swapping the jumper on the CD/DVD to slave and setting the Maxtor to Master, this should get it working.
Second, if it is showing up as 33GB, you have the Jumpers set to limit capacity(designed to avoid troubles on older systems. If this is the case, you likely have a single jumper in the center row of pins between the power and data cables. If it only works as master at the moment, then you likely have the neter row(limit size pins) and the one closest to the data cable(Master Pin) both plugged in.
Change your DVD/CD to slave, remove the limiting jumper and ensure the Master jumper is installed on the Maxtor, then be sure the end connector on the ATA(likely marked master) is plugged into the Maxtor and the middle connector(Slave) is plugged into the DVD/CD, this should have you all fixed up.
Hope this helps FixYa,
Chris
Posted on May 20, 2009
SOURCE: I have a Steamist SM-8
1) Steamist SM-8 is a Steambath steam generator with 5 year parts warranty and 2 years labor
http://www.faucetdepot.com/prod/Steamist-SM-8-IM-InstaMist-Steambath-Steam-Generator-29984.asp
2) Steamist website does not have manuals that we can immediately download and look at error codes alongside you.
http://www.steamist.com/
3) However your manual has that information, and you can add a comment and say what the manual suggests as troubleshooting, so we can offer some level of do-it-yourself help.
4) Perhaps you could scan your manual into pdf format and post your manual on your website.
And then add a comment with web location of manual so we can download and read your manual, alongside you, and perhaps offer additional do-it-yourself solution for you.
For example check that circuit breaker is delivering 240V to product, and element is not burned out, and there are no loose wires, and condensing reservoir is not clogged with sediments that can be cleaned with CLR.
5) The manual is key: I'm sure the manual also shows regular maintenance needed to ensure long life of product. For example avoid exposure to hard water, use water filter, clean reservoir and lines regularly. Avoid freezing.
I always tell people to save product manual like gold and read it cover to cover because it will save money and trouble long-run.
6) Steamist website has contact us link: With direct e-mail to 'troubleshoot' and 'literature'
I suggest next step should be contact manufacturer and request each of the following: a) a manual b) do-it-yourself assistance c) warranty information d) name of authorized technician to make repairs.
http://www.steamist.com/contact.htm
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on steamer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 05, 2011
SOURCE: primary slave drive fails
Go into the BIOS and make sure you are trying to boot from the Primary Master Drive first. If not, move the Master Drive to the 1st boot position.
If the above fails, you could just remove the power cord, remove the case and notice how the two drives are connected and remember it. There will be one cable that provides power to the drive from the power supply on each drive. Also, there might be one cable that connects both drive, or there might be one in each drive, etc. I would disconnect the power and cable on one of the drives and try rebooting. If it fails and you have one cable that connects both drives, try the other cable connection and reboot. If it still fails, then I would try doing the same thing with the other drive.
If all the above fails and your system has the IDE (whereas the cable has about a 2 inch end with about 20 holes that plug into the 20 pins on the hard drive) interface, remove the drive to check and see if the little pin on there along is set to Primary, Master or Cable Select. Normally on a two drive system they will be set to CS for Cable Select and the IDE Cable based on how it is plugged into the drives determines which is Master and Slave, but older systems might have the Master and Slave setup.
Posted on Apr 09, 2012
How do I repair a leaking Steamist SM-79?
I WAS ALSO LOOKING TO SOLVE MY SM-79 WATERLEAKS BUT NO LUCK. WHAT I THINKED IS THE WATER SOLENOID HAS A CRACK AND NEED TO BE REPLACE. SOMEHOW WATER FREEZED WHEN NOBODY WAS LIVING AT HOUSE FOR A WHILE. I HOPE THIS HELP.
Feb 10, 2012 | Steamist SM-79 7900
I have water going to unit, but it will not fill.
Contact company directly for product manual and troubleshoot help from manufacturer
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-amil or phone while you work on Steamist or any do-it-yourself project.
Feb 23, 2011 | Steamist SM-79 7900
I have s SM-79 unit, serial S79 23866 never used from a yard sale. I wish to use it where a previous installation had a half inch steam line, exiting at nine inch above the floor. Can I use this...
Contact company directly for product manual and help from manufacturer
Feb 23, 2011 | Steamaster Steamist SM7900 Dual Kilowatt...
E6 Display on the control unit
You posted question under Steamist:
Sample Steamist manual says:
"Error messages E4, E5 and E6 indicate a communication problem with the steam generator. If this error occurs, check both ends of the control cable for clean, dry and secure connections.
Dirty contacts can be cleaned with alcohol and a cotton swab or a toothbrush. This can also happen if the control is not sealed and the cable connections get wet."
Error codes change as technology changes, and sample manual may not include your model:
For a price, expert works with you via e-mail or phone while you work on Steamist or any do-it-yourself project.
Feb 22, 2011 | Steamist 11 KW Steam Unit SM11IM
I have a Steamist SM-8 and I am receiving an E4 error message on the control panel. What does this mean?
Feb 03, 2011 | Steamist Hardware & Accessories
Do I need to install a water softner before installing sm-79
you should not have to, but if the steamist is not gernerating the right amount of steam then you should put a sofftner on. you will be able to tell because it might have a hard time producing steam, but don't jump the gun right away.
Dec 09, 2010 | Steamist SM-79 7900
I purchased a new controller TC135 snd connected it via the telehpone like plugs and it still doesnt work. How do I test the unit itself?
If the unit is new, there is likely a problem in the generator it connects to. Since this is all a proprietary interconnection it is unlikely you can find any way to test the parts individually.
Nov 10, 2009 | Steamist SM-79 7900
Electrical Supplies Logo
51 people viewed this question
Top Steamist Electrical Supplies Experts
ray gallant
Tom Chichester
Are you a Steamist Electrical Supply Expert? Answer questions, earn points and help others
