Question about LG Televison & Video
How do I shut of my internal speakers on my LG 55" model 55 LM8600 OR LM8650
Can't find anywhere in manual how to turn on or off
    Top Expert:
  • LG Master
  • 75,178 Answers
There is no such control at the menu of this set. Electro help
Posted on Dec 03, 2014
How do I check if my element 40" internal speakers are on/off and if it may be set to sound bar only? I didn't see that in the manual anywhere then again the manual doesn't explain much of anything.
The initial set up procedure may have an option for turning internal speakers off and on. If set to off, audio output is directed from the rear of the TV to the inputs of the sound bar.
Dec 09, 2016 | Element Televison & Video
INTERNAL SPEEKERS do not work external speekers work when pluged in
Check the menu. In almost flat panel tvs there is setting that allow you to select in between internal speaker and external speaker. If the selected setting is external speaker the you wont get sound from the internal speakers.
www.electro-medical.blogspot.com
Sep 01, 2015 | LG 55GA6400 55" LED TV 1920x1080, 120 Hz,...
Turn off internal speakers in LG 55LM8650
Some models do not have a feature to turn off the internal speakers. If it is not in the menu, then this is not available for you, only other option is to turn the volume all the way down or physically disconnect them(not recommended if under warranty).
Dec 03, 2014 | LG Cell Phones
How do I turn off internal speakers in Haier L55B2181 TV?
The only time the internal speakers are disabled is if you have headphones plugged into that 3.5 mm jack. So the internal speakers will be disabled if you use any computer speakers that use only the computer audio out jack or headphones. You may be able to use a 3.5 mm to RCA audio adapter and the related cables to use other speakers in the same way. (The adapter could be 3.5 mm M to RCA F/F and a RCA audio cable to the speaker control (receiver) or 3.5 mm F to RCA M/M and a 3.5 mm audio cable. The difference will be in where you plug in the adapter.) For other external audio options, your only choice is to manually reduce the speaker volume to low. See page 6 of the manual; page 16 confirms the fact that there is no option to disable the speakers in the OSD menu. The manual is available online here: http://www.manualslib.com/manual/418427/Haier-L55b2181.html . (In this file, the relevant pages are 9 and 18.)
I hope this helps.
Sep 13, 2014 | Haier L55B2181 55 Class LCD HDTV - 1080p,...
How do i turn off the speakers on my toshiba 55tl515
There is no way to disable the speakers on the 3DTV 55TL515U, I would just turn the volume all the way down on the TV. If you are using the opticla output this should not be affected. If not than you have no worries anyways. Mute or Volume Down.
Apr 09, 2014 | Toshiba 55tl515 55 1080p Led 3d Tv...
How do you turn on the internal speakers for a toshiba regza 55 inch tv
some of these sets do not have internal speakers. If they have red and black connectors on the back marked speaker out it has external speakers. that being said, if yours has internal speakers go to the set up menu and fallow down to audio. IT will be found there. SPEAKERS ON /OFF
Feb 20, 2011 | Televison & Video
Inputs randomly stop registering, screen goes blank
Code 12 indicates no error. Push the Menu and Device buttons after the TV has shut off to get the proper code, not after you unplug and plug it back.
It seems your set is not Mitsubishi WS-55819 so it will help if you can give the exact model.
Dec 12, 2009 | Mitsubishi WS-55819 55" Rear Projection...
My phillips magnavox big screen tv model number 55p8288 doesnt have any sound when i turn it on
Check the audio setting to make sure the internal speakers aren't turned off. Check to see if it's set to use external speakers. If it is setup to run sound through an av receiver check all connections, make sure the receiver is on the correct input setting, and speaker wires.
Jul 05, 2009 | Philips Magnavox 55P9271 55" Rear...
LG 47 External Audio Control
This is the only way a bose works
May 01, 2009 | LG 47 in. Flat-Panel LCD HDTV
Turning on Internal TV Speakers
either your model tv ,doesnt have that option,,or its on the back,,check the rear of the tv,,good luck
Oct 01, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Televison & Video Logo
161 people viewed this question
Computer Repairing
Computer Repairing
