Hi i have a SIMPSON ESPRIT 600 TOP LOADER WASHING MACHINE. The wash cycle works fine however during the drain and spin cycle, the water wont drain. The machine makes a noise during the drain cycle but nothing happens. Does anybody know what part i should replace? The drain pump or the drain pump motor?
    Sergeant:
  • 149 Answers
My guess would be replace the pump, it is normally driven by the motor and if the wash cycle is good the motor is operational. You have to investigate to find the actual part to replace.
Posted on Dec 03, 2014
Maytag317
  • 1136 Answers
SOURCE: Front loader washing machine is not draining
Hi Is this a whirlpool? Sounds like something is in the pump or the pump is bad.
Get me model # and I can help you further. Thaks
Vic
Posted on May 16, 2009
Karthik316
  • 187 Answers
SOURCE: Simpson Esprit 6.5kg front loader wont spin
Try these steps
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt (belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
pls rate my suggestion
Posted on Jul 06, 2009
  • 41 Answers
SOURCE: Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Posted on Jan 09, 2010
aaronfitzy27
  • 12 Answers
SOURCE: Simpson 700L Top loader washing machine won't spin
If this machine is not belt driven, then more than likely is the motor coupler. To give you an idea of this problem follow this link....
http://www.youtube.com/watch?v=WLPGs2UMUJc
Aaron
Posted on Jan 24, 2010
SOURCE: simpson esprit 450 washing machine top loader
your drive belt is brobably loose or broken
Posted on Aug 10, 2010
My washing machine spins but doesnt complete the spin cycle
does it drain all the water out/ If not then check your pump filter.
Oct 04, 2014 | Simpson Esprit 750 Top Load 7.5kg
How do I get my washing machine to spin
Check the interlock tab (upright models) or the hinge or latch switch (front-load.) Sometimes these switches break or simply come loose.
Aug 03, 2014 | Simpson Esprit 750 Top Load 7.5kg
My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Jul 14, 2012 | Simpson Washing Machines
Hi, Weve got a simpson esprit 700 washing machine and the cold water tap seems to be blocked. I've disconnected the hose at the washing machine end but when I've turned it on in the sink it works fine so...
Hi just read your posting.There are 2 types of SIMPSON ESPRIT washing machines,There is a top and front loader version.Which one is yours?Please reply and I will guide you on replacing the water valve.Looking forward to your reply.
Sep 19, 2010 | Washing Machines
Main power flicks off when starting my simpson esprit 750 washing machine
Hi just read your posting,Now there are two types of Simp esprit,Is yours a top loader or a front loader? Does the machine trip the fuse when you select the spin cycle or only when it starts to fill?Have you tried putting it on a spin cycle?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Aug 28, 2010 | Washing Machines
Try these steps
  8. Test the motor
Jul 06, 2009 | Washing Machines
Simpson esprit 450 washing machine top loader
Apr 11, 2009 | Washing Machines
Washing Machine won't stop filling and then won't stop emptying
Does your machine fill with water even if the machine is off? In this case your inlet valve at top of machine is defective & can be easily replaced (will tell u where to get spares, if your dealer cannot) by yourself.
If water does not stop, after filling machine at a low level(is this a front loader?) and is flowing away - check your exit pipe, it has to have a certain height (approx 3 feet) up before going down to your drain pipe.
Feb 24, 2009 | Washing Machines
My simpson esprit 600 is not agitating during wash cycle it only goes one way
Im having troubles with mine. Just not sure what to replace..
The wash cycle is fine however when it comes to drain and spin cycle, the water doesnt drain. It does make a noise during this cycle but im not sure whether the drain pump need replacing or the drain pump motor?
Can anybody help?
Aug 18, 2008 | Washing Machines
Open Questions:
Washing Machines Logo
94 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
