Question about Peavey Music
When I play my peavey valve king 100 watt amplifier, it cuts out and all you hear is a scratcy,distorted,hissing sound. What's causing this?
I've had to reset the safety switch on extention cord. After a few minutes it resumes playing correctly but does the same thing over and over. I tried adjusting gain and overdrive levels,but it didn't solve the problem.
    Top Expert:
  • Peavey Master
  • 3,141 Answers
I wouldsuspect the input jack needs cleaning/replacing.
Posted on Feb 18, 2016
Ajkill
  • 2035 Answers
SOURCE: PEAVEY ECOUSTIC 112 W/ NO SOUND ----muted?
Please the the amp with PA again then if it plays then and cable is fine you get the guitar circuit as it may have loose circuit you need to get it serviced...
Posted on Sep 01, 2008
  • 17 Answers
SOURCE: PEAVEY 6 CHANNEL MIXER (PV6) - Right Fader Crackles
its obvious that the fader in question needs replacing ..parts are available from www.peavey.com
Posted on Feb 02, 2009
SOURCE: Peavey KB 100 Keyboard Amplifier How to remove chassis?
I figured this out myself. I was just babying it too much. Some tolex had bunched up between the metal chassis and the cabinet making it feel like it was caught on something. I used a flat edge screwdriver to flatten out the tolex, and then I was able to pull the chassis out the back of the cabinet.
Posted on May 18, 2009
  • 11 Answers
SOURCE: The Overdrive channels stopped working
Probably a blown opamp
Posted on Dec 07, 2009
  • 3 Answers
SOURCE: Marshall MG250dfx's sound fades out
I have read that the problem is in the FX send/return jacks which oxidize if not used much. All you have to do, apparently, is ram a jack plug in and out a bunch of times. This breaks up the oxidation, and allows the amp to work properly again.
Posted on Jun 23, 2010
Peavey solo series SPECIAL 112 ; Loud him , intermittently
Most of the time amplifier hum is caused by the outlet that it's plugged into, maybe no ground or there's other appliances on the same circuit causing interference? And sometimes it's as simple as a little internal feedback, certain C notes on the Guitar cause distortion with tube amps, the best fix is a $100 power conditioner like made by Monster cables or others.... hope this helps?
Feb 27, 2015 | Peavey Music
Question about Peavey Escort 3000 300 watt portable PA, both right and left mains work fine, but the right speaker has distortion sound. Even if I change speakers the right out speaker circuit is dist
sounds like an internal connection problem. open access panel and check the solder connection is not broken or loose. Be sure the metal mesh jacket is not touching the lead wire as that would cause a scratchy noise and feedback, or maybe near the internal cable causing feedback
Aug 06, 2014 | Peavey Escort 3000 300 Watt Portable PA...
I have a TNT 115 S that is distorting when i play E string on my bass. What might be causing that?
Please add more information to improve help, does the amp just distorts in that particular note or teh entire sound is distorted? does the amp distorts at low volumes?
Sep 05, 2013 | Peavey Electronics Peavey Tour Tnt 115...
Where 's the fuse for my kb 100/200 watt amplifier
The fuse is INSIDE the unit and if it blows, then there are other damaged components that require going to a repair shop to repair before replacing the fuse.
Aug 14, 2011 | Peavey Electronics Peavey PR15D 15" 200...
This is on a 15 watt Peavey Vypyr. I have a buzzing at the bottom end of my amp, when playing on the low E string. I plugged in my headphones and the buzzing went away while playing. I have also raised my...
The voice coil on the cube speakers must be scraping against the magnet.Or the speaker cone must be damaged causing it to flutter at low frequency where there will be large cone movement. Try removing the phono jack from your musical instrument/ guitar and touch the tip of the jack with your finger. You will hear a hum, now turn down the volume and listen to the speakers very closely and see if you can identify the flutter. All the same you will have to fix the speaker or replace it. Have you ever dropped the speakers, if so the speaker frame could have warped causing the scraping noise.
Aug 08, 2011 | Peavey Vypyr 100 Guitar Combo Amplifier...
I'm having some crazy feed back with either my amp and i'm not sure what its from or if its my guitar but, every time i go to practice or to play a show i kill peoples ears. Now i play death metal and i...
If the guitar can "hear" the sound, the strings can resonate from the sound and result in feedback. Running at maximum gain is asking for trouble. That causes distortion which drive the speaker as a square wave and worsens the problem. Also back off the treble as you can have supersonic feedback that you can't hear but will heat up your amp.
Test by allowing the feedback and then dampen the strings... if this stops the feedback you need to move the amp away from the guitar. Being a passive pickup makes NO DIFFERENCE about the problem.
Nov 22, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Peavey amp shut down
The output stage has a problem. From your description, I'd guess that the high voltage supply has failed. The low volume and distortion suggests that you are trying to power the speakers from the driver section rather than the outputs. There is a resistor that fails in some of this series. If I remember correctly it is either a 2K or 3K resistor 10 watts in size. If you have no experience with repairs, I'd seek a service shop that is familiar with these units. The part runs between $5-$10.
Dan
May 07, 2010 | Peavey Pv 2600 Power Amplifier
I have just bought a used Marshall VS65R. When I
Make sure that when the audio from the speaker cuts, the headphones are still working (try it several times). If this is correct the problem isn't at the preamp or driver tubes. Try to locate the wire that is connecting the speaker with the amplifier. There must be a bad connection at this cable or at the speaker's coil itself. Try hiting with a solid tool (the back of a screwdriver for example) the parts and the connections (not the tubes, just the mountings) while the amplifier is working in order to locate a loosing contact. Once you find it use a soldering gun to fix the connection.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Apr 22, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Music Logo
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
