Question about Mustek R100A DVD Recorder
My dvd keeps coming back with no disc what can I do
Well tryng different discs but sti will not acccept discs
    Sergeant:
  • 470 Answers
Clean the laser, you might hAvr to take it apart
Posted on Dec 03, 2014
Keep getting unsupported when I put disc in
Not all disc players will play all the different types on the market. Some DVD's will only play in certain areas of the world. This is called region coding. The number of this is found on the back of the player and on the disc or case it comes with. If you have a region 2 player it can only play 2 discs. It is possible to make some DVD players play another region or all. Search the web for information on how to change the region code on your model DVD player.
Another thing that will cause that response is using a "+" or "-" disc type in a machine that can only play one type.
Yet another cause is dirt on the disc or lens of the player.
Oct 10, 2015 | RCA Audio Players & Recorders
Will not record and also keep geting error nodisk
Did you try a disc cleaner? Maybe the lens is just dirty.
Jan 03, 2008 | Televison & Video
My acer aspire z5700 will not take any disc keeps coming back out
TRY THIS ,CLEAN THE CD/DVD-PLAYER WITH COMPRESSED
AIR.KEEP YOUR DISCS CLEAN.
Jan 16, 2014 | Acer Aspire Z5700 PC Desktop
DVD NOT RECEIVING DVD DISCS
Hello
The loading mechanism has the trouble. The inserted CD or DVD does not engage into the laser assembly unit properly. It may be due some fault with its loading motor or loading belt. Check these.
Mar 02, 2012 | Jamo DMR 60 DVD Player/Receiver
My DVD-HR753 will not read discs. A message comes up saying 'this disc cannot be played or recorded'
Original dvd disc,not copy or not another countries datas disc?Same country as the DVD player was bought and formatted Disc?Most likely the disc u trying to play it is in a difference formatted of recording or finalizing data codes inbeted by some patent coded program.Tries play many more other DVD discs,should work find,than the original disc,u trying to play have protected datas or difference format and not same as of ur DVD player main programming firmware.
May 27, 2011 | Samsung DVD-HR735 DVD Recorder/HDD...
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have a DVDR70 DVD recorder and i have been experiencing problems with philip DVD+RW discs. Seconds after recording starts it comes up with 'Disc Error' and no matter what i seem to do all the discs of...
if you didn't experienced same problem with different brand of DVD+RW discs, than it could be a bad batch of discs you have there. I would return them to where ever you bought them from, and get your money back - or swap them for different brand
Nov 22, 2010 | Philips Televison & Video
The machine keeps stating bad disc, for all dvds. We have the GoVideo DVD VCR combo... we tried playing several different dvds and the machine keeps coming up with "bad disc".
It could just be dirt on the lazer/lens. Try cleaning it with a good brand name lens cleaner for DVD/CD. If that doesn't do the trick there might be damage to the lens, or an electrical fault.
Jan 04, 2010 | GoVideo Go Video DVD/VCR Combo
No disc read on dc100
There are only 4 possible solutions,
1. Dirty or faulty discs, but as you've tried different discs this doesn't seem likely.
2. Condensation has developed in the camcorder, leave it in a dry indoor temperatured place for a couple of hours and try again.
3. Dirty lens won't let the laser read the disc. Look for lens cleaning camcorderkit in a store.
4. Manufacturing error
Hope this will help you.
Jul 14, 2008 | Canon DC100 DVD Camcorder
Disc drive keeps spitting the discs back out after a few seconds
Do you have another drive laying around that you can try, just to make sure it isn't your OS or your motherboard. Most likely, this is a sign of a dying or dead drive, but lets not skip to that conclusion yet.
Apr 06, 2008 | Computers & Internet
Mustek R100A DVD Recorder Logo
55 people viewed this question
Top Mustek Televison & Video Experts
Tom Chichester
richie46
Are you a Mustek Televison and Video Expert? Answer questions, earn points and help others
