Question about KitchenAid Washing Machines
Top load Kitchenaid washer KAWS850LQ wont spin. Took off back, found broke belt. Best way to replace belt
Won't spin. Found broken belt. How do I replace it
    Master:
  • 742 Answers
It won't spin without the belt. You need to place the belt from the motor to gearbox and there may be a tension pulley. Most are adjusted by loosening the motor and pulling it tight
Posted on Dec 03, 2014
Why Washer wont spin
Loose belt, belt broke, belt came off, transmission bad, wires are broken.
Jun 12, 2014 | Kenmore 22422 Top Load Washer
KAWS677EQ0 washing machine.KitchenAid. It Wont agitate,spin,drain,hum,nothing.It stopped in the rinse cycle with wet clothes and all the water. what is wrong . the outlet works.
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging.
Mar 21, 2011 | KitchenAid KAWS700L Top Load Washer
The top load washer wont spin or drain the water.
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging. I want to thank you for reading and I hope this helps you. Best regards and thanks for reading
Feb 22, 2011 | Frigidaire FWS1339A Top Load Washer
Machine wont drain or spin to end the cycle
HI,
This problem is caused by either a broken washer tub drive belt or a broken washer tub drive coupler, look under the machine for evidence of this.If it is found to be true you have to go for a replacement of that particular unit.
Thank you!
May 11, 2010 | GE WBSR3140DW Top Load Washer
Hi, I have a Sears model 110 top load washer. When spinning the drum shakes violently. I took a look and found a belt looking flat piece of rubber shaped like a lemon. It was broke on one end. Could this...
What you are describing sounds like the rubber bushing on your motor coupling. The coupling is located between the drive motor and gearcase (transmission) and takes the place of a drive belt. This type of system is known as "direct-drive". If it has broken, this will cause agitation and spin problems. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
This is a very simple repair, but if you have any questions, please let me know. The part number is inlcuded in the link I provided and can be purchased at appliancepartspros.com for about $11 or $12. I hope this helps you.
Nov 02, 2009 | Kenmore 24032\24036 Top Load Washer
Wont engage to spin mode
most likely a broken washer tub drive belt or coupler.
Oct 30, 2009 | Roper RAS6233KQ Top Load Washer
I OVERLOADED THE WASHER AND NOW IT WILL NOT DRAIN OR SPIN
your washer doesnt have a belt, it is a direct drive with a coupling on the motor, so that is not likely your problem.
i would look to see if the lid switch is broken, when the switch wont work it wont spin or drain. if the coupling is broken it wont agitate or spin, but will drain the water.
just look under the top and see if the switch is just hanging loose. it has 2 screws holding it to the cabinet and a wiring harness that goes to the control panel.
Jan 08, 2009 | Roper RAS8445KQ Top Load Washer
Kitchenaid top load washer wont agitate or spin
you have a direct drive washer with a coupling broke.Here is a good article on it http://repair2000.com/coupling.html
Dec 11, 2008 | KitchenAid KAWS700L Top Load Washer
Kitchen aid washer
Hi , washer is not spinning . found motor coupler had broken . need help on the best way to replace .
Jun 08, 2008 | KitchenAid KHWS01PWH Global Horizontal...
Whirlpool Ultimate Care HD Plus Model #LSR8233EQ0 won't agitate or spin
It sounds like the coupling between the motor and gearbox has worn out. It should cost around $15 plus shipping and handling.
Aug 04, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
61 people viewed this question
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
