How to reset my tv?
I got a shock touching the power button on my tv and eversince it blinks off and on. I can`t even stop it.
    Sergeant:
  • 163 Answers
I think the static shock has destroyed the control chip. Time for a service call. I think the repair will be more or close to the cost of a new TV. Good luck.
Posted on Dec 03, 2014
Testimonial: "I'm more happy to receive an answer then to read about it but thank you."
    Master:
  • 742 Answers
Unplug it and have it serviced before you hurt someone
Testimonial: "At leat you gave me a good laugh. Thank you"
Green light is blinking over "start & resume"
It sounds like he didn't run it completely through try holding the cancel button down for a few secs.
Mar 22, 2011 | Magic Chef DU6500 Dishwasher
Power will not come on even after system reset. Pushed reset and LED flashes then after it stops flashing TV will still not turn on.
do self check: when it shuts off and power light goes off:
On front of set press and hold both menu and input (device) buttons for at least five seconds and release both buttons.
Power light will blink a two digit error code, like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code and I will assist you
SD TECH
Sep 24, 2010 | Mitsubishi WS-55513 55" Rear Projection...
I have a HDTV 1080 and the power to our neighborhood went out over the night and now the green light on the TV just blinks. I can't get the TV to turn on. I have reset the system reset button on the from...
try this ... if there is a reset button on your 'front' control panel..maybe 2 - 3 positions to the left of your blinking timer light..
try inserting the tip of a mechanical pencil or tip of a straighten paperclip into the 'tiny hole' of th ereset button ...hold pressure on that button until yout blinking light starts blinking RAPIDLY .. this
rapid blinking should continue for several seconds or a minute.
then it should stop .. may even go off ... now ..hopefully.. you will be able to turn your set on
Aug 20, 2010 | Mitsubishi Televison & Video
I am getting no response when i push the power button. I have a mitsubishi medallion 65'' 1080p tv. This just happened out of nowhere. there is no blinking light nothing. i noticed that there is power...
Front buttons . Remove the lower front speaker covers/panels by pulling . Then unplug connector ZF to the keypad . Then wait 3 minutes and try to turn it on with the remote . You may have to remove the access panel to find connector ZF (just follow the wiresdown from the front keypad). Don't touch , turn or break anything else while inside the access panel!
Let me know if that works
Oct 21, 2009 | Televison & Video
Electrical shock on audio video jack
there is a current if you dont use is sleeper or shoes and if your hand is weat of water. its normal. be sure that your TV is not fix eversince.
May 31, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Tv blinks out when front buttons are pushed. model#ws-65511
If the TV is turning on and working regularly, but power button does not shut down and buttons on TV do not work, then it is a faulty touch control (button) board on TV.
If instead the TV does not even turn on, then tv is on protection mode, in that case it can be any internal fault.
If instead the problem is with remote buttons, then it is either a faulty remote or a faulty IR sensor.
May 03, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Sony KP-43t75 - Front panel buttons and IR sensor stopped working
TRY UNPLUGGING THE SET FROM THE WALL FOR 2 MINUTES THIS WILL ACTIVATE THE AUTO RESET WHEN YOU PLUG THE SET BACK IN.
Dec 28, 2008 | Sony KP-57WS500 57" Rear Projection...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Timer light blinks on and off and tv wont turn on
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
If ever resetting is no effect then the problem is in the "DM board"
The constant blinking green light means that the TV is not booting up. This is a common problem on this set. Hope it may help you; Regards, VOTIT
Sep 25, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
