Question about DeLonghi ESAM 5500M
How do I replace the front door assembly in a Delonghi esam 5500
Tried to unscrew the top screws and back cover screws
  • 2039 Answers
SOURCE: Stuck filter screen screw on DeLonghi BAR32
i got a saeco vienna digital i got the same problem that screw jam the same as our i clean the filter with water and air if you whant to try something try to soak in decalcifier it gonna melt the calcium cheers
Posted on Jan 16, 2008
  • 3 Answers
SOURCE: need to replace steam valve on delonghi magnifica coffee machine
the steam valve will pop off it comes straight out
Posted on Dec 05, 2009
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
Posted on Jul 08, 2010
SOURCE: hello i have an Delonghi esam
I had this problem until I realised that you need to switch the machine off by pressing the on/off button on the front of the machine first *before* switching it off at the back and unplugging it. This moves the infuser unit further to the bottom and then allows you to take it out.
Posted on Nov 11, 2010
murdozzz
  • 41 Answers
SOURCE: how to replace Delonghi magnifica
ha this is the same problem i had just last week at a customers house with the same machine , the knob does pull off but it is hellish tight and you feel like the valve is about to burst through the front of the machine but it does pull off, when fitting the new knob it is a good idea to put some grease over the shaft before pushing the new knob on as it's nearly as hard pushing the new one back on as taking the old one off.
regards
Ian
Posted on Apr 17, 2011
DELONGHI ESAM 5500 WON'T MAKE CAPPUCCINO SAYS GRINDS TOO FINE, BUT WILL GRIND AND MAKE REGULAR COFFEE
have you tried cleaning it as described in your user manual,, can you hit the button for regular grind? there are alternatives, a coffee grinder if failry cheap at 10 dollars US,,
Jun 07, 2016 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Hi i have a esam5500 coffee and cuppuccino maker. How to remove the front cover of the machine because the cappuccino BUTTON is not in place (loose) or if is possible to fix it
I had the same problem but with the power button on the front panel.
It's a major operation involving opening the machine.
Disconnct completely from mains power.
On the rear there are 2 screws middle top and middle bottom When they are removed the back can be slid upwards and removed. Then there are four screws on the back holding the side panels.. When removed the sidepanels can be slid backwards and of.
Pry of the little plastic button on top of the grinder adjuster in the bean container. Underneath is a screw that needs to be removed.
The top is held by 2 screws on the forward part along the top. When removed the top plate can be pried upwards.
The front is the held by 2 extra screws half way down along the front. When you removed these the front along with the panel can be taken of.
The panel is connected with the electronics with a flat cabel that runs along the left side. Pry the cabel lock open at the electronics board and fre the cable.
Now you have the front panel free and can work with it.
On the cabk there are 4 bigger screws. remove these and notice how the back plastic cover and the front are layered.
With the 4 screws removed you can lift the panel with the buttons out forn the front panel and se how the buttons a mountet.
My power button was broken of the little tabs that held it and had fallen down behind the panel. I reattached the button with som gaffer tape loosely on the back so it stayed in place but had movement enough to be usable.
Clean out the interrior while you are in there.
Assembly is the reverse and everything is back in order.
There is a youtube video with a complete dismantle process:
ffnen Dichtungs und Raccordtausch Delonghi Perfekta Pronto Cappuccino ESAM...
Feb 14, 2016 | DeLonghi Perfecta ESAM5500 Fully Automatic...
How to install samsung Part Number DC31-00054A (AP4202690)
1. Unplug the washer. 2. Unscrew the 2 screws at the top back of the washer that secures the top of washer pane, slide it back and lift off, remove and set aside. 3. Pull out the dispenser tray and depress the tab at the back to full remove. 4. Remove the dispenser mounting screws, slide the dispenser back. 5. Carefully pull the control panel off from the top, disconnect the two wire harnesses and set the control panel aside. 6. Use needle nose pliers to remove the retaining wire and spring from the door boot seal, pull the seal away from the lip of the front panel. 7. Remove the 3 door mounting screws to release door latch assembly from the front panel. 8. Open and detach the filter access door and release the drain tube from the retaining tab. 9. Remove the screws inside the filter housing securing the front panel. 10. Carefully lift the front of the washer up and support it. 11. You can now remove the screws at the bottom securing the front panel(if your has these, mine were missing). 12. Now is also a good time to detach the pump assembly wire retainer from the base(small white plastic tab sticking downward). 13. Remove the support and gently lower the washer back down. 14. Remove the mounting screws on top of the front panel. 15. Now, use a flat head screw driver to depress the locking tabs to release the front panel from the frame. 16. Detach the recirculation hose from the retaining brackets on the inside of the front panel and set the panel aside. 17. Uncap the drain tube, and drain the excess water, then recap the tube. 18. Release the retaining clamps securing the hoses to the pump assembly and slide the hoses off.(be prepared for some water to spill). 19. Remove the two screws securing the pump assembly to the mounting bracket. 20. Now, push the assembly back to release it from the base. 21. Next, detach the drain pump cover(top white plastic cover) and disconnect the wires, now remove the 3 mounting screws and pull off the old pump. 21. Install the new drain pump by properly aligning it on the assembly. 22. Replace the mounting screws to secure. 23. Connect the wires to the new pump and snap on the cover. 24. Position the pump assembly into the cabinet base by inserting the mounting tab into the slots in the base, then push forward. 25. Replace the screws to secure the assembly to the mounting bracket. 26. Snap the wire retainer into the base. 27. Reattach all of the hoses to the appropriate ports on the assembly and position the retaining clamps to secure. 28. Replace the front panel, by aligning the slots in the panel with the tabs on the base. 29. Secure the recirculation hose in the retaining brackets, making sure the door latch is inside the cabinet and snap the top half the panel into position. 30. Replace the screws on top. 31. Lift and support the washer, then replace the screws on bottom. 32. Remove the support and lower the washer. 33. Replace the 2 screws in the filter housing. 34. Secure the drain tube under the retaining tab. 35. Reattach the filter access door and snap it closed. 36. Now, realign the door latch assembly in the front panel, and replace the mounting screws. 37. Align the boot seal on the front lip of the panel. 38. Replace the retaining wire and spring to secure. 39. Replace the control panel, by first reconnecting the wire harnesses. 40. Now, insert the control panel tabs into the slots into the trim and snap the top half of the panel into place. 41. Reposition the dispenser and replace the mounting screws. 42. Slide the tray into place. 43. Reposition the top panel by aligning the edge of the panel with tabs on the support bracket, then push forward.
44. Replace the screws at the back. 45. Plug the power cord back in. Your done!
Your washer should be ready to use now!!! Good Job!
You should find this video useful, even if it is for a different model washer, it is what I used as a reference. Drain Pump Replacement part DC31 00054D Samsung Washer Repair
Sep 06, 2014 | Samsung WF448AAP Front Load Washer
How do I remove the cover of a delonghi ec270
Prise the back cover off with a flat head screw driver. Sides first, then ease top and bottom off. Remove two push in caps by gently squeezing out with a plier, align the groove to the same direction as plier. Locate two screws holding cover, unscrew, and off it comes.
Aug 25, 2012 | DeLonghi EC270 Espresso Espresso Machine
How can I change the mirror control panel?
Firstly, get a replacement switch. Carefully take off the cover of the door handle (mine is the diagonal kind - 2002) and then unscrew the two screws at the top and bottom of the handle. Then Unscrew three screws at the very bottom of the door panel - they are the "star" kind - a tork screw. Carefully pull out the snaps on the sides of the door panel. They just pop out of holes in the door frame. Be carefull not to pull too fast or suddenly. Then pull straight up on the door panel. It can be very sticky at the top but gently work it out of the rubber slot at the top. OPTIONAL: Now that the panel is free, disconnect the electrical and door pull cables. Make a note of what connected where! You can skip this step if you can do the next step in a tight spot... You'll see the assembly for the door handle, lock, and mirror switch. There is a screw by the door handle. Unscrew that, then carefully pry open the clips that hold the assembly in. The whole assembly will come forward out of the door panel. Now, carefully unclip the mirror switch. It will come forward out of the assembly. Place the new switch back in its place, and re-clip. AT THIS STAGE, RE-CONNECT THE ELECTRICAL WIRE TO THE SWITCH AND TEST! Replace the assembly back in the door panel. Replace the screw by the door handle and re-connect the wires and cables. Then "Hook" the top of the door panel on the rubber slot. You can check the other door to make sure it's right. Carefully snap back in the sides of the door panel then reconnect the three screws at the bottom. Finally, replace the two screws in the door handle, and replace the door handle cover.
Best of luck
Jan 11, 2011 | 1999 Volkswagen Beetle
How do you change a pump on a Samsung WF448AAP washer? Need to get in from the back?
Dec 07, 2010 | Samsung WF448AAP Front Load Washer
Maytag front load washer Neptune MAH5500B codes FL and DO
There is an emergency access cord provided for the manual unlocking of the washer door and can be accessed by removing the dispenser bezel. Open the dispenser cover and remove the four screws securing the dispenser bezel to the top cover then lift the bezel off. Once the bezel is removed, look for the nylon cord near the door lock assembly through the opening left by the dispenser bezel. Pull the cord away from the door lock assembly to pivot the mechanical opener and push the locking lever into the open position. Open and close the door several times then start a new cycle.
Check the door lock assembly if the problem persists and replace it when necessary. Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
Access to the door lock assembly requires the removal of the front panel, dispenser bezel, and lifting of the top cover.
Open the washer door and remove the two screws securing the door hinge and the front panel to the front shroud assembly. Do the same to the two screws on the opposite side of the door opening.
Disengage the front panel posts from the clips located on the face of the cabinet by grasping the upper part of the front panel posts and pressing in on the outer edges then twisting it inward. Once the front panel posts are released from the cabinet, tilt the front panel away from the cabinet and remove it.
Remove the two 5/16" hex-head screws securing the two top cover hold down brackets; one on each side. Swing the brackets to the outside to unhook it from the lip of the top cover then lift the top cover to expose the door lock assembly. Prop up the top cover to prevent it from falling back into position while accessing the door lock assembly.
Disconnect the wiring harnesses from the door lock assembly and the two mounting screws then rock the top of the assembly forward and lift it off the front shroud assembly.
Clean the wiring terminals and the connectors then reseat the connectors several times. Replace the door lock assembly when the problem is not resolved.
Install the new door lock assembly in reverse of the steps given above. Review the steps thoroughly for easy reassembly of the washer. Make sure the wiring harnesses are properly and firmly seated to the door lock assembly terminals. The door lock assembly is part number 22004435.
Mar 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
Have LG 1812 front load washer, it is making noise when water tries to drain out, we were able to drain the hose but unable to remove the drain pump filter-just spins
Unscrew the drain pump filter counterclockwise to remove it from the pump assembly. If it cannot be removed, you need to replace the pump casing (part #3108ER1001B) and the pump filter (part #383EER2001A).
Remove the two screws at the rear of the top panel attaching it to the cabinet. Slide the panel rearward then lift it off the washer.
Disconnect the control panel wiring harness from the main board assembly. Pull the dispenser drawer out until it stops then press the locking tab and pull the drawer out completely.
Remove the two screws from the drawer opening then lift the left side of the console and pull it off the cabinet.
Remove the three screws from the upper part of the front panel and the screw from the filter cover.
Insert a putty knife blade or similar flat tool in both sides of the filter cover then pull it out of the cabinet. Remove the screw from the lower side of the front panel.
Open the washer door and remove the wire and spring holding the door gasket to the outer lip of the door opening. Stretch the spring with a pair of needle-nose pliers to clear the wire off the lip of the door opening then remove the wire and spring assembly.
Peel off the door gasket into the drum then tilt the front panel and disconnect the door switch wiring harness from the door switch terminals. Lift the front panel and remove it from the cabinet.
Compress the spring clamps holding the pump inlet and outlet hoses then move the clamps away from the pump casing.
Remove the two screws securing the pump to the base of the washer. Press down the tab at the back of the pump assembly and push the assembly into the washer then lift the pump assembly up and out of the washer. Remove the hoses from the pump assembly.
Unscrew the pump from the casing and inspect the impeller for any damage. Rotate the impeller to check whether there's restriction. Replace the pump (part #4681EA2001D) if the impeller is broken or does not rotate freely.
Install the pump assembly and reassemble the washer by reversing the given disassembly steps.
Mar 20, 2010 | LG WM1812C Front Load Washer
DeLonghi Magnifica always asks "Insert Infuser Assembly"
DeLonghi "Insert infuser assembly" error
Easy Fix - Delonghi Coffee machines which have built-in coffee grinders often suffer from a problem that produces an error, "Insert infuser assembly" that appears at random times.
The problem is usually caused by distortion of infuser lifting mechanism limit switch mounting (Orange colored plastic)!
The mounting is very close to the water heater so with heat and pressure from the infuser lifting mechanism the mounting gets bent over time. The switch mounting (Orange colored plastic) gets permanently distorted so the striker arm on the lifting assembly only just presses the micro switch button causing the error message "Insert infuser assembly".
To easily fix the problem on ESAM 5500 machines and should work on other similar machines:-
    1.Unplug the machine and remove the rear cover screws and remove.
    2.Slide out the two side covers.
    3.Remove the grinder lever screw in the top cover coffee bean compartment.
    4.Carefully lift the top cover pushing it slightly back so it does not stick under the front cover (you may have to loosen the 4 front cover screws on the side).
    5.The limit switch is clearly visible on the top (see photos).
    6.Wedge some insulated material (wood, plastic etc, I used bamboo) between the heater assembly and the switch mounting so the switch is in a VERTICAL position. The thickness of the packing is around 3-4mm (see photo).
    7.Re-assemble the machine and enjoy your coffee. JTS
    Alwar, Rajasthan
    India
Apr 01, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Need to replace door gasket
Remove the top cover by removing the 2 screws in the back.
Remove the dispenser drawer completely.
Remove the 2 screws on front of the panel where the dispenser drawer was removed.
Remove the screw on the right side behind the front panel.
Disconnect the wire harness behind the panel.
Starting on the dispenser side with your finger, pry forward the top of the control panel until it unsnaps.  Continue this all the way to the right and remove the control panel.
Go to the bottom filter door and remove the door.  Unscrew the one screw below the filter cap.  Remove the plastic insert covering around the filter cap.
Locate a small screw at the very bottom of the frame just below the filter cap and remove.  Sometimes there may be 2 but usually there is only one.
Open the door and locate the spring clamp usually located at the bottom of the door seal.  Remove the spring clamp.  This will loosen the front of the door gasket for removal from the frame.
On the right of the door gasket is the door latch assembly.  Unscrew the 2 screws and set the latch hanging by the wire harness.
Remove the 4 or 5 top screws holding the front panel assembly.  Once they are removed, the front panel will lift up and out.
NOTE!!!  THIS JOB REQUIRES 2 SPECIAL TOOLS FROM LG TO REMOVE THE SPRING CLAMPS ESPECIALLY THE REAR CLAMP.  THE SPRINGS ARE SET VERY TIGHT SO IT IS NOT EASY TO REASSEMBLY WITHOUT THE SPECIAL TOOLS.
Sep 23, 2008 | LG WM1814CW Front Load Washer
DeLonghi ESAM 5500M Logo
230 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
