Question about ASUS 32GB TF701T 10.1" Transformer Pad Tablet Gray
Why is my ASUS transformer Pad saying to 'connect a camera' when I tap the camera icon or try to use skype?
I recently got the ASUS transformer pad (the one without the back camera) and whenever you go to the camera icon it says 'connect to a camera'. I don't understand why it's saying that, it has a front facing camera that you can skype and take pictures with. it just isn't working for some odd reason. I'm not sure if I should take it to get fixed or if the camera simply needs to be 'set up'. Please help! thanks so much!
  • Jennifer Reed
    Jennifer Reed Dec 31, 2014
    mine had been working and now it does not. tells me load or install camera.
    Master:
  • 742 Answers
If the tablet rooted or has a custom rom the correct camera drivers are not installed. Set it up with the stock rom and you should be good. Problem with custom roms is most of the time they were not set up for that specific model and some things are not going to work
Posted on Dec 03, 2014
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
Asus Memo Pad HD 7 won't turn on or charge.
1. how old is your tablet 2. have you tried another charger such as a phone charger. My blackberry charger works fine for my tablet. Also with your tablet you should have had a usb cable that connected from mini usb to the asus plug in transformer.
Jul 20, 2014 | ASUS MeMO Pad HD 7
I want to clean my eepad prior or giving to my granddaughter
The way to Hard Reset ASUS Eee Pad Transformer TF101-A1 to Full Factory Reset: For those who have any troubles with your ASUS Eee Pad Transformer, use the 10-12 sec force power off trick to attempt a fix. If that doesn't help, backup whatever you want to keep and perform a full factory reset.
Some times you will discover error when asus transformer hard reset, like not responding to your device or your gadget not responsible. Don't be worry, simply just restart this and wait a minute. I think's it's side-effects of hard reset ASUS Eee Pad Transformer TF101-A1.
Mar 05, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
My asus transformer pad isn't charging ?
IF cable is not an fault, try to replace the power adapter, even if fails try in the desktop or laptop rear USB ports. Hope this may helps U
Feb 28, 2014 | ASUS Transformer Pad TF300 10.1" 32GB...
How to rotate asus tablet webcam display 90 degrees?
turn on the auto rotate screen and if that doesnt go in the top right hand corner there should be a button there, click on it and it says rotate just keep tapping it until it rotates to your desiered position.
Nov 30, 2013 | ASUS Eee Pad Transformer TF101A1 Tablet...
My asus transformer pad will not connect to wifi. I have done the factory reset and it will not even list a wifi list to connect to.
Obviously your WiFi is not enable. Check your settings and make sure your enable your WiFi. Then you will be able to see all computers (WiFi) around you.
Nov 02, 2013 | ASUS Transformers Pad Infinity TF700T
Need Asus EEE Pad Transformer Manual in English
Here is a link to ASUS support for you pad. you will need to put in the OS, and then scroll down and you will see manual. In my case 43 were available. Eglish was the second one down. Follow the instruction on the page, it looks like you have to do this via your phone.
http://support.asus.com/download.aspx?SLanguage=en&p=20&m=Eee+Pad+Transformer+TF101&hashedid=gHh4q7I8dvWJzhdV
Hope this helps
Mar 21, 2012 | ASUS Eee Pad Transformer TF101A1 Tablet...
ASUS 32GB TF701T 10.1" Transformer Pad Tablet Gray Logo
89 people viewed this question
Top ASUS Tablets & eReaders Experts
Alun Cox
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
