Question about Coleman Heating & Cooling
My coleman heater will light then when i turn it to high med or low it goes out it burns as long as i hold to light position
It burns as long as i hold the switch to start position the i move it high,med,orlow and it goes out.
    Master:
  • 742 Answers
Replace or clean the thermocouple.
Posted on Dec 03, 2014
My gas Dearborn model#drc40mc pilot light stays lit.when I turn to on position and heater comes on , it burns high , even on low number setting, then after few seconds goes out taking pilot out also
clean/replace the flame sensor. Your heater doesn't recognize that it has lit and continues to try and light the gas. when the sensor doesn't tell the 'brain' it lit? it shuts down the gas for safety reasons.
Oct 19, 2014 | Heating & Cooling
How do I wire blower moter
Black- high speed Red- low speed Blue- med. high Yellow- med. low White- neutral Usually black on "cool" terminal on board, red on "heat" terminal on board, and remaining 2 on the "park" terminals on board. White goes to the neutral terminals. Hope this helps!
Nov 14, 2012 | Goodman GMS90703BXA Heater
Low does not work, medium and high do
You probably cant fix it, this sounds like a multispeed blower with hi/medium/lo settings. You
can either replace the motor or connect one of the
working speeds to low/med or low/hi. or bump med to low and high to medium.
Jan 12, 2010 | Desa International Blower Glow Warm Wall...
When I light my Coleman Catalytic Heater, it burns
The wick isnt drawing up any fuel? Does this heater have a primer?
Could the wick be sitting above the fuel inside the tank?
You might just try changing wicks and restarting.
Dec 12, 2009 | Coleman Heating & Cooling
ProCom blueflame heater pilot light difficult to light
You pilot ignator is plugged.I take a small wire and run it in the hole every year and I also Blow the heaters out real well with air.THis has always worked far me.I need a phone number or email address to Pro Com because i'm having problems with a new one i just bought and I can't find the papework.Could you pleas eif you have this info email it to me
Good Luck
Jay
jaycalk@yahoo.com
Jan 07, 2009 | Procom (177653) Utility Heater
Toyota tacoma heater fan runs slowly in the 3rd & 4th positions
Using a voltmeter, the resisted voltage values for the fan motor are as follows:
LOW- 3 VDC
Med LOW - 6 VDC
Med HIGH - 9 VDC
High - 12 VDC
The fan resistor gets 12 volts from each position of the fan switch, and the 12 VDC is then lowered thru each of the 3 internal resistors inside the fan resistor. My guess is that the resistor has failed, and the resistance wires contained on it may have meshed together. The resistor is on the black box between the blower motor housing and the center of the dash. 2 phillips screws hold it in. Easy to remove/replace. Hope this helps, and thanks for choosing FixYa.
Nov 23, 2008 | 1983 Toyota Camry
Propane forced air heater
Need to make sure you are supplying a minimum tank supply of 100lb cyclinder. If smaller,you are producing co due to low gas flow
Nov 02, 2008 | Reddy Heater RLP100 Portable Forced Air...
Pelonis model HO157C0110 will not turn on
Bypass the 3 way (hi, med, low) switch, unfortunately it'll always be in the high position when you do this. I have done this with one of my heaters and as long as the thermostat is working properly then it will work as it should on the high setting. I took the extra step of connecting the LED light to the bypass so I know when its on.
Just remember to turn it off you'll need to unplug it.
Oct 12, 2008 | Heating & Cooling
Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
May 30, 2008 | Coleman (5040B750) Patio Heater
Fahrenheat baseboard heater knobs
go to a radio shack to find replacement knobs. get something called a "bar knob." this has a set screw which holds the knob on the thermo shaft. use a marker and print lo med high and off on the unit or use a brother p touch label maker.
Jan 10, 2008 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
80 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
